Hallo
Ich habe folgendes Problem mit Linux Mint XFCE nach dem aufwecken aus der Bereitschaft,
ist das system weg,
wer von euch könnte mir dazu etwas sagen ?
oder hat meine SSD ein Problem ?
Danke
Info
PID: 3348 (tumblerd)
UID: 1000 (frank)
GID: 1000 (frank)
Signal: 6 (ABRT)
Timestamp: Sat 2024-03-16 15:51:23 CET (18h ago)
Command Line: /usr/lib/x86_64-linux-gnu/tumbler-1/tumblerd
Executable: /usr/lib/x86_64-linux-gnu/tumbler-1/tumblerd
Control Group: /user.slice/user-1000.slice/user@1000.service/app.slice/tumblerd.service
Unit: user@1000.service
User Unit: tumblerd.service
Slice: user-1000.slice
Owner UID: 1000 (frank)
Boot ID: a24a60c87fd64272b6e2640c86d3059d
Machine ID: 757a7764fced4f368091811f892afc20
Hostname: frank-Aspire-XC-705
Storage: /var/lib/systemd/coredump/core.tumblerd.1000.a24a60c87fd64272b6e2640c86d3059d.3348.1710600683000000.zst (present)
Disk Size: 11.7M
Message: Process 3348 (tumblerd) of user 1000 dumped core.
Found module linux-vdso.so.1 with build-id: 1b5f65732dbffa7abb7873f64eb02bbab1c8b8a5
Found module libgstbadaudio-1.0.so.0 with build-id: 295bd05b3fbe31152507870799b8fe12bc0ad5ca
Found module libgstopenmpt.so with build-id: 04df2a2f08211da21296e3eceef3ddb917a8a4fe
Found module libgstsubparse.so with build-id: 42441adc882f7fe70cf75b2eb0221fb92b8b1891
Found module libdatrie.so.1 with build-id: 128b6874a47f2b783d9e9060d3caaee4110bfd3d
Found module libquadmath.so.0 with build-id: 0971ec4ac32513fe5d63a58cbe14d0719568098a
Found module libthai.so.0 with build-id: afa54530349e68380815d606d15dbfda8952799f
[New LWP 3351]
[New LWP 3350]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Core was generated by `/usr/lib/x86_64-linux-gnu/tumbler-1/tumblerd'.
Program terminated with signal SIGABRT, Aborted.
#0 __pthread_kill_implementation (no_tid=0, signo=6, threadid=140051358934592) at ./nptl/pthread_kill.c:44
44 ./nptl/pthread_kill.c: No such file or directory.
[Current thread is 1 (Thread 0x7f603f7fe640 (LWP 3359))]
Thread 12 (Thread 0x7f60628a2640 (LWP 3350)):
#0 0x00007f6063b6fbcf in __GI___poll (fds=0x55a943906f70, nfds=2, timeout=-1) at ../sysdeps/unix/sysv/linux/poll.c:29
sc_ret = -516
sc_cancel_oldtype = 0
sc_ret = <optimized out>
#1 0x00007f6063d3d1f6 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
No symbol table info available.
#2 0x00007f6063ce72b3 in g_main_loop_run () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {140727053380368, 1437682947906399497, 140051802293824, 11, 140051965982672, 140727053380720, -1354705116110197495, -1354622122489877239}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}}
not_first_call = <optimized out>
#6 0x00007f6063b7d850 in clone3 () at ../sysdeps/unix/sysv/linux/x86_64/clone3.S:81
No locals.
Thread 6 (Thread 0x7f60596cf640 (LWP 3356)):
#0 syscall () at ../sysdeps/unix/sysv/linux/x86_64/syscall.S:38
No locals.
#1 0x00007f6063d36b43 in g_cond_wait () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#2 0x00007f6063cb73fb in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#3 0x00007f6063d19687 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#4 0x00007f6063d16a51 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#5 0x00007f6063aebac3 in start_thread (arg=<optimized out>) at ./nptl/pthread_create.c:442
pd = <optimized out>
out = <optimized out>
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {140727053380368, 1437682947906399497, 140051793901120, 11, 140051965982672, 140727053380720, -1354704016061698807, -1354622122489877239}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}}
No locals.
Thread 5 (Thread 0x7f605a6d1640 (LWP 3354)):
No locals.
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {140727053380368, 1437682947906399497, 140051810686528, 11, 140051965982672, 140727053380720, -1354710629237592823, -1354622122489877239}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}}
No locals.
Thread 4 (Thread 0x7f60630c6640 (LWP 3349)):
#0 0x00007f6063b6fbcf in __GI___poll (fds=0x55a9438ebdd0, nfds=2, timeout=4403) at ../sysdeps/unix/sysv/linux/poll.c:29
sc_ret = -516
#2 0x00007f6063ce53e3 in g_main_context_iteration () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#3 0x00007f6063ce5431 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {140727053382768, 1437682947906399497, 140051955344960, 2, 140051965982672, 140727053383120, -1354621283717288695, -1354622122489877239}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}}
No locals.
800017408, 8691991333959810048}}
old_mask = <optimized out>
tid = <optimized out>
resultvar = <optimized out>
__arg3 = <optimized out>
__arg2 = <optimized out>
__arg1 = <optimized out>
_a3 = <optimized out>
_a2 = <optimized out>
_a1 = <optimized out>
__futex = <optimized out>
__private = <optimized out>
__oldval = <optimized out>
result = <optimized out>
#1 __pthread_kill_internal (signo=6, threadid=140051358934592) at ./nptl/pthread_kill.c:78
No locals.
#2 __GI___pthread_kill (threadid=140051358934592, signo=signo@entry=6) at ./nptl/pthread_kill.c:89
No locals.
#3 0x00007f6063a99476 in __GI_raise (sig=sig@entry=6) at ../sysdeps/posix/raise.c:26
#4 0x00007f6063a7f7f3 in __GI_abort () at ./stdlib/abort.c:79
save_stage = 1
act = {__sigaction_handler = {sa_handler = 0x0, sa_sigaction = 0x0}, sa_mask = {__val = {0 <repeats 16 times>}}, sa_flags = 0, sa_restorer = 0x0}
sigs = {__val = {32, 0 <repeats 15 times>}}
#5 0x00007f60618e2692 in ?? () from /lib/x86_64-linux-gnu/libstdc++.so.6
#6 0x00007f60618ed89f in ?? () from /lib/x86_64-linux-gnu/libstdc++.so.6
#7 0x00007f60618ed9c7 in __gxx_personality_v0 () from /lib/x86_64-linux-gnu/libstdc++.so.6
#8 0x00007f6060e33fe9 in __libunwind_Unwind_Resume () from /lib/x86_64-linux-gnu/libunwind.so.8
#9 0x00007f602bb5810a in ?? () from /lib/x86_64-linux-gnu/libopenmpt.so.0
#10 0x00007f602bc3329a in ?? () from /lib/x86_64-linux-gnu/libopenmpt.so.0
#11 0x00007f602bc24585 in openmpt_module_create_from_memory2 () from /lib/x86_64-linux-gnu/libopenmpt.so.0
#12 0x00007f605860c003 in ?? () from /usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstopenmpt.so
#13 0x00007f6024806e1b in ?? () from /lib/x86_64-linux-gnu/libgstbadaudio-1.0.so.0
#14 0x00007f6024806f86 in ?? () from /lib/x86_64-linux-gnu/libgstbadaudio-1.0.so.0
#15 0x00007f6060f587cd in ?? () from /lib/x86_64-linux-gnu/libgstreamer-1.0.so.0
