Hallo liebes Forum
Ich habe ein Problem damit Metasploitale 3 zum laufen zu bringen.
Wenn ich vagrant up eingebe erscheint folgendes:
Traceback (most recent call last):
25: from /usr/bin/vagrant:23:in `<main>'
24: from /usr/bin/vagrant:23:in `load'
23: from /usr/share/rubygems-integration/all/gems/vagrant-2.2.6/bin/vagrant:177:in `<top (required)>'
22: from /usr/share/rubygems-integration/all/gems/vagrant-2.2.6/lib/vagrant/environment.rb:290:in `cli'
21: from /usr/share/rubygems-integration/all/gems/vagrant-2.2.6/lib/vagrant/cli.rb:66:in `execute'
20: from /usr/share/rubygems-integration/all/gems/vagrant-2.2.6/plugins/commands/up/command.rb:87:in `execute'
19: from /usr/share/rubygems-integration/all/gems/vagrant-2.2.6/lib/vagrant/plugin/v2/command.rb:186:in `with_target_vms'
18: from /usr/share/rubygems-integration/all/gems/vagrant-2.2.6/lib/vagrant/plugin/v2/command.rb:186:in `each'
17: from /usr/share/rubygems-integration/all/gems/vagrant-2.2.6/lib/vagrant/plugin/v2/command.rb:204:in `block in with_target_vms'
16: from /usr/share/rubygems-integration/all/gems/vagrant-2.2.6/lib/vagrant/plugin/v2/command.rb:180:in `block in with_target_vms'
15: from /usr/share/rubygems-integration/all/gems/vagrant-2.2.6/lib/vagrant/environment.rb:715:in `machine'
14: from /usr/share/rubygems-integration/all/gems/vagrant-2.2.6/lib/vagrant/vagrantfile.rb:81:in `machine'
13: from /usr/share/rubygems-integration/all/gems/vagrant-2.2.6/lib/vagrant/vagrantfile.rb:81:in `new'
12: from /usr/share/rubygems-integration/all/gems/vagrant-2.2.6/lib/vagrant/machine.rb:141:in `initialize'
11: from /usr/share/rubygems-integration/all/gems/vagrant-2.2.6/lib/vagrant/machine.rb:259:in `communicate'
10: from /usr/share/rubygems-integration/all/gems/vagrant-2.2.6/lib/vagrant/registry.rb:27:in `get'
9: from /usr/share/rubygems-integration/all/gems/vagrant-2.2.6/plugins/communicators/winrm/plugin.rb:15:in `block in <class:Plugin>'
8: from /usr/lib/ruby/2.7.0/rubygems/core_ext/kernel_require.rb:92:in `require'
7: from /usr/lib/ruby/2.7.0/rubygems/core_ext/kernel_require.rb:92:in `require'
6: from /usr/share/rubygems-integration/all/gems/vagrant-2.2.6/plugins/communicators/winrm/communicator.rb:6:in `<top (required)>'
5: from /usr/share/rubygems-integration/all/gems/vagrant-2.2.6/plugins/communicators/winrm/communicator.rb:6:in `require_relative'
4: from /usr/share/rubygems-integration/all/gems/vagrant-2.2.6/plugins/communicators/winrm/shell.rb:8:in `<top (required)>'
3: from /usr/share/rubygems-integration/all/gems/vagrant-2.2.6/lib/vagrant/util/silence_warnings.rb:8:in `silence!'
2: from /usr/share/rubygems-integration/all/gems/vagrant-2.2.6/plugins/communicators/winrm/shell.rb:9:in `block in <top (required)>'
1: from /usr/lib/ruby/2.7.0/rubygems/core_ext/kernel_require.rb:92:in `require'
/usr/lib/ruby/2.7.0/rubygems/core_ext/kernel_require.rb:92:in `require': cannot load such file -- winrm (LoadError)
Alles anzeigen
Ich habe schon einige Anleitungen zur Hilfe genommen, es aber noch nicht geschafft zum laufen zu bringen.
Ich benutze Linux Mint 20.2 x86_64
packer 1.3.4
Vagrant 2.2.6
Virtualbox 6.1
