- Distrowahl
- Linux Mint
- System:
Kernel: 6.8.0-54-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
base: Ubuntu 24.04 noble
Type: Laptop System: AWOW product: AK41 v: N/A serial: <superuser required>
Mobo: AWOW model: AK41 PC BOX serial: <superuser required>
UEFI: American Megatrends v: AWOW-BI-MINIPC-M9GR200-GF60A-101-B
date: 03/25/2020
Info: quad core model: Intel Celeron J4115 bits: 64 type: MCP
arch: Goldmont Plus rev: 1 cache: L1: 224 KiB L2: 4 MiB
Speed (MHz): avg: 943 high: 992 min/max: 800/2500 cores: 1: 796 2: 992
3: 992 4: 992 bogomips: 14284
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: Intel GeminiLake [UHD Graphics 600] driver: i915 v: kernel
arch: Gen-9.5 bus-ID: 00:02.0
loaded: modesetting unloaded: fbdev,vesa dri: iris gpu: i915 resolution:
1: 1920x1080~60Hz 2: 1920x1080~60Hz
v: 24.2.8-1ubuntu1~24.04.1 glx-v: 1.4 direct-render: yes renderer: Mesa
Intel UHD Graphics 600 (GLK 2)
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 00:0e.0
API: ALSA v: k6.8.0-54-generic status: kernel-api
Server-1: JACK v: 1.9.21 status: off
Server-2: PipeWire v: 1.0.5 status: active
Device-1: Intel Gemini Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:0c.0
IF: wlo2 state: up mac: <filter>
driver: r8169 v: kernel port: d000 bus-ID: 02:00.0
Bluetooth:
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
v: 0.8 type: USB bus-ID: 1-9:6
lmp-v: 10
Local Storage: total: 1.03 TiB used: 98.69 GiB (9.4%)
ID-1: /dev/nvme0n1 vendor: Foresee model: P900F128GBH size: 119.24 GiB
temp: 47.9 C
ID-2: /dev/sda vendor: SanDisk model: SDSSDH3 1T00 size: 931.51 GiB
ID-1: / size: 116.32 GiB used: 98.68 GiB (84.8%) fs: ext4
dev: /dev/nvme0n1p2 label: N/A
dev: /dev/nvme0n1p1 label: N/A
System Temperatures: cpu: 65.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 8 GiB available: 7.58 GiB used: 2.38 GiB (31.4%)
Processes: 258 Uptime: 30m Init: systemd target: graphical (5)
Packages: 2521 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Moin,
Google Fotos hatte ich unter Windows genutzt und einige Funktionen fand ich richtig gut, nutzte sie auch auf anderen Geräten.
Zum Sortieren und arbeiten damit ist es aber mit der Deskto-App angenehmer. Unter Umbutu kann man das mit snap installieren, unter Mint leider nicht.
Kann man den snap Manager auch in Mint mit einbinden - und wenn ja, dann wie?
Google help empfielt bei Linux Mint muss eine Datei namens verschoben oder entfernt werden, bevor Snap installiert werden kann.
sudo mv /etc/apt/preferences.d/nosnap.pref ~/Documents/nosnap.backup
Da kommt aber eine Fehlermeldung:
mv: das Verschieben von '/etc/apt/preferences.d/nosnap.pref' nach '/home/....../Documents/nosnap.backup' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
Ist es überhaut richtig, es zu machen?
