Alle Funktionen von Google Foto nutzen geht nur mit Snap? Kann ich Snap unter Linux Mint installieren?
    Linux Mint
    Kernel: 6.8.0-54-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
    base: Ubuntu 24.04 noble
    Type: Laptop System: AWOW product: AK41 v: N/A serial: <superuser required>
    Mobo: AWOW model: AK41 PC BOX serial: <superuser required>
    UEFI: American Megatrends v: AWOW-BI-MINIPC-M9GR200-GF60A-101-B
    date: 03/25/2020
    Info: quad core model: Intel Celeron J4115 bits: 64 type: MCP
    arch: Goldmont Plus rev: 1 cache: L1: 224 KiB L2: 4 MiB
    Speed (MHz): avg: 943 high: 992 min/max: 800/2500 cores: 1: 796 2: 992
    3: 992 4: 992 bogomips: 14284
    Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
    Device-1: Intel GeminiLake [UHD Graphics 600] driver: i915 v: kernel
    arch: Gen-9.5 bus-ID: 00:02.0
    loaded: modesetting unloaded: fbdev,vesa dri: iris gpu: i915 resolution:
    1: 1920x1080~60Hz 2: 1920x1080~60Hz
    v: 24.2.8-1ubuntu1~24.04.1 glx-v: 1.4 direct-render: yes renderer: Mesa
    Intel UHD Graphics 600 (GLK 2)
    Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
    driver: snd_hda_intel v: kernel bus-ID: 00:0e.0
    API: ALSA v: k6.8.0-54-generic status: kernel-api
    Server-1: JACK v: 1.9.21 status: off
    Server-2: PipeWire v: 1.0.5 status: active
    Device-1: Intel Gemini Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:0c.0
    IF: wlo2 state: up mac: <filter>
    driver: r8169 v: kernel port: d000 bus-ID: 02:00.0
    Bluetooth:
    Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
    v: 0.8 type: USB bus-ID: 1-9:6
    lmp-v: 10
    Local Storage: total: 1.03 TiB used: 98.69 GiB (9.4%)
    ID-1: /dev/nvme0n1 vendor: Foresee model: P900F128GBH size: 119.24 GiB
    temp: 47.9 C
    ID-2: /dev/sda vendor: SanDisk model: SDSSDH3 1T00 size: 931.51 GiB
    ID-1: / size: 116.32 GiB used: 98.68 GiB (84.8%) fs: ext4
    dev: /dev/nvme0n1p2 label: N/A
    dev: /dev/nvme0n1p1 label: N/A
    System Temperatures: cpu: 65.0 C mobo: N/A
    Fan Speeds (rpm): N/A
    Memory: total: 8 GiB available: 7.58 GiB used: 2.38 GiB (31.4%)
    Processes: 258 Uptime: 30m Init: systemd target: graphical (5)
    Packages: 2521 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
    Moin,
    Google Fotos hatte ich unter Windows genutzt und einige Funktionen fand ich richtig gut, nutzte sie auch auf anderen Geräten.
    Zum Sortieren und arbeiten damit ist es aber mit der Deskto-App angenehmer. Unter Umbutu kann man das mit snap installieren, unter Mint leider nicht.
    Kann man den snap Manager auch in Mint mit einbinden - und wenn ja, dann wie?
    Google help empfielt bei Linux Mint muss eine Datei namens verschoben oder entfernt werden, bevor Snap installiert werden kann.
    sudo mv /etc/apt/preferences.d/nosnap.pref ~/Documents/nosnap.backup
    Da kommt aber eine Fehlermeldung:
    mv: das Verschieben von '/etc/apt/preferences.d/nosnap.pref' nach '/home/....../Documents/nosnap.backup' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
    Ist es überhaut richtig, es zu machen?
  • Ist zwar für LM 21, aber könnte gehen. https://de.linux-console.net/?p=14442
    Ich würde dir aber raten auf Snap und insbesondere auch Google Photos zu verzichten, aber das musst du entscheiden. Ansonsten kann der Linux-Assistant von Jean https://www.linux-assistant.org/ das glaube ich auch. Und vorallem kann er es grafisch. Aber den Linux-Assistant habe mich mir irgendwann deinstalliert, denn bei mir gabs Probleme mit der Darstellung.
    Erst wenn der letzte FTP Server kostenpflichtig, der letzte GNU-Sourcecode verkauft, der letzte Algorithmus patentiert, der letzte Netzknoten kommerzialisert ist, werdet Ihr merken, dass Manager nicht programmieren können.
  • DenalB February 28, 2025 at 6:49 PM
    Changed the title of the thread from “Alle Funktionen von Google Foto nutzen geht nut mit snap? Kann ich snap unter Mint installiere?” to “Alle Funktionen von Google Foto nutzen geht nur mit Snap? Kann ich Snap unter Linux Mint installieren?”.
  • Wenn du ein Deutsches System hast wäre der Pfad: ~/Dokumente/
    Danke! Ich habe aber die Ursache selbst nun gefunden, das Verzeichnis APT und die Datei ist geschützt und kann nur mit höheren Rechten verschoben werden.
    Die Frage für mich ist offen: Sollte ich SNAP installieren und funktioniert es neben dem Flatmanager?
    Antworten im Netz habe ich gefunden, die sind aber zt. widersprüchlich.
    Edited once, last by DenalB: Ein Beitrag von Richard Stallmann mit diesem Beitrag zusammengefügt. (March 2, 2025 at 12:28 AM).
  • Snap und Flatpak funktionieren problemlos nebeneinander.
    Snapcraft liefert eine Anleitung wie man es unter Linux Mint installiert: https://snapcraft.io/docs/installing-snap-on-linux-mint
    Viel Spass.
  • Die Frage für mich ist offen: Sollte ich SNAP installieren und funktioniert es neben dem Flatmanager?
    Die mint Macher wollen snap mit aller Gewalt entfernen und Du möchtest es wieder hinzufügen. Ich könnte mir vorstellen, dass Du irgendwann Probleme mit Updates oder Upgrades bekommen könntest. Wenn Du unbedingt snap nutzen willst, solltest Du in Betracht ziehen auf Ubuntu zu wechseln!
  • kann nur mit höheren Rechten verschoben werden.
    Deshalb hat deine Zeile ein sudo davor!
    Der einzige Berührungspunkt von Snap und der Paketverwaltung ist die Installation von snapd, sonst läuft das unabhängig voneinander.
    Nach einem Upgrade von zB Linux Mint 22 auf 23 kann man nochmal nachsehen ob die Datei nosnap.pref wieder angelegt wurde.
  • Da haben wir hier im Forum eine Anleitung:
    nicoletta
    August 18, 2022 at 3:52 PM
    Static Badge GitHub-Projekte
    nicoletta
    Ja, danke, hab ich auch so gemacht.. aber 1) rm geht nicht, musste händisch mit Systemrechten die Datei verschieben.
