- Distrowahl
- Linux Mint
- System:
Kernel: 6.8.0-53-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
Desktop: Cinnamon v: 6.4.7 Distro: Linux Mint 22.1 Xia
base: Ubuntu 24.04 noble
Type: Laptop System: Dell product: Latitude E5450 v: N/A
serial: <superuser required>
Mobo: Dell model: 0DCPV1 v: A00 serial: <superuser required>
UEFI-[Legacy]: Dell v: A23 date: 11/25/2019
Battery:
ID-1: BAT0 charge: 51.0 Wh (100.0%) condition: 51.0/51.0 Wh (100.0%)
volts: 8.5 min: 7.6 model: LGC-LGC4.20 DELL HK6DV status: full
Info: dual core model: Intel Core i5-5300U bits: 64 type: MT MCP
arch: Broadwell rev: 4 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 574 high: 798 min/max: 500/2900 cores: 1: 500 2: 500
3: 500 4: 798 bogomips: 18356
Device-1: Intel HD Graphics 5500 vendor: Dell driver: i915 v: kernel
arch: Gen-8 bus-ID: 00:02.0
Device-2: Sunplus Innovation Integrated_Webcam_HD driver: uvcvideo
type: USB bus-ID: 1-1.6:4
resolution: 1920x1080~60Hz
v: 24.2.8-1ubuntu1~24.04.1 glx-v: 1.4 direct-render: yes renderer: Mesa
Intel HD Graphics 5500 (BDW GT2)
Device-1: Intel Broadwell-U Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:03.0
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Dell
API: ALSA v: k6.8.0-53-generic status: kernel-api
Device-1: Intel Ethernet I218-LM vendor: Dell driver: e1000e v: kernel
port: f080 bus-ID: 00:19.0
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel bus-ID: 02:00.0
IF: wlp2s0 state: up mac: <filter>
Bluetooth:
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
bus-ID: 1-1.3:3
Report: hciconfig ID: hci0 rfk-id: 2 state: down
address: <filter>
RAID:
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 bus-ID: 00:1f.2
Local Storage: total: 268.29 GiB used: 34.73 GiB (12.9%)
ID-1: /dev/sda vendor: LITE-ON IT model: LCS-128L9S-HP size: 119.24 GiB
ID-2: /dev/sdb vendor: Toshiba model: MK1652GSX size: 149.05 GiB type: USB
ID-1: / size: 145.65 GiB used: 34.73 GiB (23.8%) fs: ext4 dev: /dev/sdb1
System Temperatures: cpu: 48.0 C mobo: 43.0 C sodimm: SODIMM C
Fan Speeds (rpm): cpu: 0
Memory: total: 4 GiB available: 3.7 GiB used: 1.97 GiB (53.2%)
Processes: 226 Uptime: 11m Init: systemd target: graphical (5)
Packages: 2096 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Erst einmal ein herzliches HALLO an alle Experten hier!
Seit ca. einem Monat teste ich nun intensiv Linux Mint 22.1 auf einem Laptop und es gefällt mir sehr gut.
Ich habe hier nun die folgende Situation:
- Laptop mit interner SSD (WIN 10, 128 GB)
- Mint auf einer externen USB-Platte installiert (alte Toshiba MK1652GSX, 160 GB, lag hier noch einsam rum).
- Linux booten und Arbeiten funktioniert einwandfrei.
- auf dem Laptop wird eigentlich nur gesurft und Libre Office und Telegram genutzt.
- alle wichtigen Daten befinden sich auf einem Fritz-NAS, auf das ich auch vollen Zugriff habe (zwar "nur" per ftp, smb hab ich nicht hinbekommen
- Cinnamon und weitere Kleinigkeiten habe ich natürlich auf meine persönlichen Vorlieben eingestellt - und das bringt mich zur eigentlichen Frage...
Frage:
Wie kann ich die auf dem USB-Laufwerk gespeicherten individuellen Einstellungen übernehmen, wenn ich Mint NEBEN Windoofs auf dem Laptop installiere.
Konkret: Welche Dateien muss ich von der USB-Platte rüber ziehen.
(Ich weiß: TimeShift bringt mir in dieser Sache nix.)
Bin leider trotz intensiver Suche im Netz in drölfzig Foren nicht fündig geworden. Kann aber auch sein, dass ich nur zu doof zum Suchen bin... ![]()
P.S.: EDV-Erfahrung habe ich seit MS-DOS 3.schlag-mich-tot...
... aber vor allem mit Windows. Und das möchte ich nun irgendwann verlassen.
Herzlichen Dank für alle Antworten.
Grüße vom Herbert aus der Vulkaneifel
