- Distrowahl
- Sonstiges
- System:
Kernel: 6.9.3-76060903-generic x86_64 bits: 64 compiler: N/A
Desktop: GNOME 42.9 Distro: Pop!_OS 22.04 LTS base: Ubuntu 22.04 LTS Jammy
Mobo: ASUSTeK model: ROG STRIX Z790-E GAMING WIFI II v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1801
date: 11/30/2024
Info: 24-core (8-mt/16-st) model: Intel Core i9-14900KF bits: 64
type: MST AMCP arch: N/A rev: 1 cache: L1: 2.1 MiB L2: 32 MiB L3: 36 MiB
Speed (MHz): avg: 1193 high: 5700 min/max: 800/5700:6000:4400 cores:
1: 2421 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 3241 10: 800
11: 4418 12: 800 13: 5700 14: 800 15: 800 16: 800 17: 800 18: 800 19: 800
20: 800 21: 800 22: 800 23: 800 24: 800 25: 800 26: 800 27: 800 28: 800
29: 800 30: 800 31: 800 32: 800 bogomips: 203980
Device-1: AMD vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 03:00.0
Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: amdgpu,ati
unloaded: fbdev,modesetting,radeon,vesa gpu: amdgpu
resolution: 1920x1080~60Hz
OpenGL: renderer: AMD Radeon RX 7900 XTX (radeonsi navi31 LLVM 15.0.7 DRM
3.57 6.9.3-76060903-generic)
v: 4.6 Mesa 24.0.3-1pop1~1711635559~22.04~7a9f319 direct render: Yes
Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3
Device-2: AMD driver: snd_hda_intel v: kernel bus-ID: 03:00.1
Device-3: ASUSTek USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:5
Sound Server-1: ALSA v: k6.9.3-76060903-generic running: yes
Sound Server-2: PulseAudio v: 15.99.1 running: no
Sound Server-3: PipeWire v: 1.0.3 running: yes
Device-1: Intel driver: iwlwifi v: kernel port: N/A bus-ID: 07:00.0
IF: wlo1 state: up mac: <filter>
Device-2: Intel vendor: ASUSTeK driver: igc v: kernel port: N/A
bus-ID: 08:00.0
IF: eno2 state: down mac: <filter>
Bluetooth:
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-14:10
address: <filter>
RAID:
Hardware-1: Intel Device driver: vmd v: 0.6 bus-ID: 00:0e.0
Local Storage: total: 3.01 TiB used: 24.93 GiB (0.8%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 990 PRO 2TB size: 1.82 TiB
temp: 32.9 C
ID-2: /dev/sda vendor: Intenso model: SSD size: 232.89 GiB
ID-3: /dev/sdb type: USB vendor: Micron model: CT1000X9SSD9
ID-4: /dev/sdc type: USB vendor: Intenso model: Rainbow Line
ID-1: / size: 862.61 GiB used: 15.41 GiB (1.8%) fs: ext4
dev: /dev/nvme0n1p3
ID-2: /boot/efi size: 1020 MiB used: 218.4 MiB (21.4%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) dev: /dev/dm-0
mapped: cryptswap
ID-2: swap-2 type: zram size: 16 GiB used: 0 KiB (0.0%) dev: /dev/zram0
System Temperatures: cpu: 27.8 C mobo: N/A gpu: amdgpu temp: 33.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 518 Uptime: 37m Memory: 46.83 GiB used: 6.65 GiB (14.2%)
Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 1828 Shell: Bash
v: 5.1.16 inxi: 3.3.13
Moin,
bin seit kurzem mit Pop_os 22.04 am Gange.
Nun wollte ich wie unter Windows kontrolle über die GPU (RX7900XTX) erlangen. Deshalb habe ich CoreCtl nach folgender Anleitung installiert: https://gitlab.com/corectrl/corectrl
Den Befehl sudo kernelstub -o "amdgpu.ppfeaturemask=0xffffffff" habe ich auch ausgeführt.
Soweit so gut. Nun bekomme ich aber keine Lüftersteuerung für die Graka angezeigt.
Vielen Dank im Voraus für die Unterstützung!
LG Peter
