- Distrowahl
- Linux Mint
- EasyNote-TS11HR:~$ inxi -Fxxxz
Kernel: 6.8.0-53-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
clocksource: tsc
Desktop: Cinnamon v: 6.4.7 tk: GTK v: 3.24.41 wm: Muffin v: 6.4.1 vt: 7
dm: LightDM v: 1.30.0 Distro: Linux Mint 22.1 Xia base: Ubuntu 24.04 noble
Type: Laptop System: Packard Bell product: EasyNote TS11HR v: V1.18
serial: <superuser required> Chassis: type: 10 v: 1.18
Mobo: Packard Bell model: SJV50_HR serial: <superuser required>
uuid: <superuser required> BIOS: Packard Bell v: 1.18 date: 02/02/2012
Battery:
ID-1: BAT0 charge: 5.8 Wh (100.0%) condition: 5.8/47.5 Wh (12.2%)
volts: 12.2 min: 10.8 model: SANYO Li_Ion_4000mA type: Li-ion
serial: <filter> status: full
Info: dual core model: Intel Core i3-2350M bits: 64 type: MT MCP
smt: enabled arch: Sandy Bridge rev: 7 cache: L1: 128 KiB L2: 512 KiB
L3: 3 MiB
Speed (MHz): avg: 799 high: 800 min/max: 800/2300 cores: 1: 798 2: 800
3: 800 4: 800 bogomips: 18360
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-6 ports:
active: HDMI-A-1,LVDS-1 empty: DP-1,VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0116 class-ID: 0300
Device-2: NVIDIA GF108M [GeForce 610M] vendor: Acer Incorporated ALI
driver: nouveau v: kernel arch: Fermi pcie: speed: 2.5 GT/s lanes: 16 ports:
active: none off: VGA-2 empty: none bus-ID: 01:00.0 chip-ID: 10de:0dea
class-ID: 0300 temp: 47.0 C
Device-3: Suyin 1.3M HD WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 bus-ID: 1-1.3:3 chip-ID: 064e:d20c class-ID: 0e02
serial: <filter>
loaded: modesetting unloaded: fbdev,vesa dri: crocus gpu: i915,nouveau
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3286x1200 s-dpi: 96 s-size: 869x318mm (34.21x12.52")
s-diag: 925mm (36.43")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: top-left model: Lenovo P24h-2L
serial: <filter> res: 1920x1200 hz: 60 dpi: 93
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: max: 1920x1200
min: 720x400
Monitor-2: LVDS-1 pos: primary,bottom-r model: AU Optronics 0x21ec
res: 1366x768 hz: 60 dpi: 101 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") modes: 1366x768
Monitor-3: VGA-2 mapped: VGA-1-2 note: disabled size-res: N/A modes:
max: 1024x768 min: 640x480
API: EGL v: 1.5 hw: drv: intel crocus drv: nvidia nouveau platforms:
device: 0 drv: crocus device: 1 drv: nouveau device: 2 drv: swrast gbm:
drv: crocus surfaceless: drv: crocus x11: drv: crocus inactive: wayland
API: OpenGL v: 4.5 compat-v: 3.3 vendor: intel mesa
v: 24.2.8-1ubuntu1~24.04.1 glx-v: 1.4 direct-render: yes renderer: Mesa
Intel HD Graphics 3000 (SNB GT2) device-ID: 8086:0116
Device-1: Intel 6 Series/C200 Series Family High Definition Audio
vendor: Acer Incorporated ALI 6 driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:1c20 class-ID: 0403
Device-2: NVIDIA GF108 High Definition Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel pcie: speed: 2.5 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:0bea class-ID: 0403
API: ALSA v: k6.8.0-53-generic status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
status: active 2: wireplumber status: active 3: pipewire-alsa type: plugin
Device-1: Broadcom NetLink BCM57785 Gigabit Ethernet PCIe
vendor: Acer Incorporated ALI driver: tg3 v: kernel pcie: speed: 2.5 GT/s
lanes: 1 port: N/A bus-ID: 02:00.0 chip-ID: 14e4:16b5 class-ID: 0200
IF: enp2s0f0 state: down mac: <filter>
Device-2: Qualcomm Atheros AR9287 Wireless Network Adapter vendor: Lite-On
driver: ath9k v: kernel pcie: speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
chip-ID: 168c:002e class-ID: 0280
Local Storage: total: 298.09 GiB used: 33.08 GiB (11.1%)
ID-1: /dev/sda vendor: Western Digital model: WD3200BPVT-22JJ5T0
size: 298.09 GiB speed: 3.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 1A01 scheme: GPT
ID-1: / size: 291.85 GiB used: 33.07 GiB (11.3%) fs: ext4 dev: /dev/sda3
ID-2: /boot/efi size: 512 MiB used: 6.1 MiB (1.2%) fs: vfat dev: /dev/sda2
ID-1: swap-1 type: file size: 3.96 GiB used: 32.9 MiB (0.8%) priority: -2
file: /swapfile
System Temperatures: cpu: 54.0 C mobo: N/A gpu: nouveau temp: 48.0 C
Fan Speeds (rpm): N/A
Memory: total: 4 GiB note: est. available: 3.68 GiB used: 2.6 GiB (70.7%)
Processes: 234 Power: uptime: 1h 8m states: freeze,mem,disk suspend: deep
wakeups: 0 hibernate: platform Init: systemd v: 255 target: graphical (5)
default: graphical
Packages: 2211 pm: dpkg pkgs: 2204 pm: flatpak pkgs: 7 Compilers:
gcc: 13.3.0 Shell: Bash v: 5.2.21 running-in: gnome-terminal inxi: 3.3.34
Hallo ihr Lieben,
erstmal freu ich mir ein Loch in den Bauch, dass meine private Welt seit ein paar Tagen ent-windowt ist. Ich habe es endlich hinbekommen, dass 3 sehr altersschwache und unter Windows nicht mehr nutzbare Notebooks unter Linux Mint wie geschmiert laufen.
In Bezug auf zwei kleine Wehwechen benötige ich Eure Hilfe - bitte. Bitte habt ein wenig Geduld, ich bin wirklich Laie und es kann sein, dass ich Antworten nicht auf Anhieb verstehe.
Hier die Fragen:
1. Thunderbird Kalender:
Thunderbird brauche ich nur auf einem Rechner. Ich habe vor der Umstellung auf Linux (noch unter Windows) mehrere Backups auf einer externen Festplatte erstellt. Linux installiert und die Daten wieder eingespielt. E-Mails und Adressbücher laufen perfekt. Nur der Kalender ist leer. In den Backups ist auch keine Kalenderdatei zu finden - warum auch immer. Ich hatte noch ein weiteres Backup unter Paragon Backup erstellt, welches auch die Kalenderdatei enthalten sollte. Wahrscheinlich blöder Denkfehler: Hab gelesen, dass ich das Paragon-Backup unter Linux nicht mehr öffnen kann. Stimmt das? Frage also: Hat jemand eine Idee, wie ich unter Linux an die Backup-Dateien komme? Oder müsste ich mich an jemanden mit einem Windows-Betriebssystem wenden?
2. Bildschirmeinstellung:
Wenn ich nur mit Notebook (ein Bildschirm) arbeite, werden mir 2 Bildschirme angezeigt. Wenn ich mit Notebook+1 Bildschirm arbeite, werden mir 3 Bildschirme angezeigt. Das ist nicht wirklich schlimm - neugierig wäre ich aber trotzdem, wie sich das korrekt einstellen lässt. Bildschirm Nr. 2 gibts nicht, nur 1 und 3..., siehe:
Ich sag schon mal Dankeschön für Hilfestellungen und Ideen!
