Zram usw
    Linux Mint
    nudels@nudels:~$ inxi -Fz
    Kernel: 6.8.0-52-generic arch: x86_64 bits: 64
    Desktop: Xfce v: 4.18.1 Distro: Linux Mint 22.1 Xia
    Type: Laptop System: Dell product: Latitude 7390 v: N/A
    serial: <superuser required>
    Mobo: Dell model: 09386V v: A00 serial: <superuser required> UEFI: Dell
    v: 1.41.0 date: 11/06/2024
    Battery:
    ID-1: BAT0 charge: 60.0 Wh (100.0%) condition: 60.0/60.0 Wh (100.0%)
    Info: quad core model: Intel Core i5-8350U bits: 64 type: MT MCP cache:
    L2: 1024 KiB
    Speed (MHz): avg: 2000 min/max: 400/3600 cores: 1: 2000 2: 2000 3: 2000
    4: 2000 5: 2000 6: 2000 7: 2000 8: 2000
    Device-1: Intel UHD Graphics 620 driver: i915 v: kernel
    Device-2: Sunplus Innovation Integrated_Webcam_HD driver: uvcvideo
    type: USB
    loaded: modesetting unloaded: fbdev,vesa dri: iris gpu: i915 resolution:
    1: 2560x1440~60Hz 2: N/A
    API: EGL v: 1.5 drivers: iris,swrast platforms: gbm,x11,surfaceless,device
    v: 24.2.8-1ubuntu1~24.04.1 renderer: Mesa Intel UHD Graphics 620 (KBL GT2)
    Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel
    API: ALSA v: k6.8.0-52-generic status: kernel-api
    Device-1: Intel Ethernet I219-LM driver: e1000e
    IF: enp0s31f6 state: down mac: <filter>
    Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi
    IF: wlp2s0 state: up mac: <filter>
    IF-ID-1: wwan0 state: down mac: <filter>
    Bluetooth:
    Device-1: Intel Bluetooth wireless interface driver: btusb type: USB
    Report: hciconfig ID: hci0 state: up address: <filter> bt-v: 4.2
    Local Storage: total: 1.02 TiB used: 205.98 GiB (19.6%)
    ID-1: /dev/mmcblk0 model: MSSD0 size: 117.04 GiB type: Removable
    ID-2: /dev/nvme0n1 vendor: Western Digital model: WD BLACK SN770 1TB
    ID-1: / size: 883.83 GiB used: 188.07 GiB (21.3%) fs: ext4
    dev: /dev/nvme0n1p2
    ID-2: /boot/efi size: 511 MiB used: 6.2 MiB (1.2%) fs: vfat
    dev: /dev/nvme0n1p1
    ID-1: swap-1 type: partition size: 32 GiB used: 868 MiB (2.6%)
    dev: /dev/nvme0n1p3
    System Temperatures: cpu: 70.0 C mobo: 64.0 C
    Fan Speeds (rpm): cpu: 6311
    Memory: total: 32 GiB available: 31.09 GiB used: 28.62 GiB (92.0%)
    Processes: 452 Uptime: 1d 20h 39m Shell: Bash inxi: 3.3.34
    nudels@nudels:~$
    sudo swapon -p 80 /dev/zram0
    Lm 22.1 xfce nutze haufen browser tabs usw dadurch ram uft aus gelaste was kan eisntlerugn määsieg noch ruach holen mit zram usw sosnt noch idee lmu auch gepostet
  • Lm 22.1 xfce nutze haufen browser tabs usw dadurch ram uft aus gelaste was kan eisntlerugn määsieg noch ruach holen mit zram usw sosnt noch idee lmu auch gepostet
    Kannst du das bitte wenigstens von einer KI korrigieren lassen? Ich kann jedenfalls nicht erkennen, was du uns mitteilen möchtest. Oder ist da gar eine Frage versteckt?
  • Ich versuche mal eine Übersetzung: Linux Mint 22.1 XFCE: Ich nutze einen Haufen Browsertabs usw. Dadurch ist der RAM oft ausgelastet. Was kann man leistungsmäßig noch herausholen, mit "zram" usw. Habt ihr sonst noch eine Idee? ... Ne, aber im Ernst, bitte schreib so, dass es auch Andere verstehen :thumbup:
    Erst wenn der letzte FTP Server kostenpflichtig, der letzte GNU-Sourcecode verkauft, der letzte Algorithmus patentiert, der letzte Netzknoten kommerzialisert ist, werdet Ihr merken, dass Manager nicht programmieren können.
  • Mein verwegener Tipp: Mach die kack Tabs zu organisiere dich anders - effizienter wirds nicht. Ich habe mir ein Limit von 50 Tabs gesetzt, dann ist Schluss und ich speicher, schließe und sortiere aus.
  • Memory: total: 32 GiB available: 31.09 GiB used: 28.62 GiB (92.0%)
    Hier liegt das Problem! Das System kackt zusammen, weil der Ramspeicher voll ausgelastet ist.
    Warum? Das wird schwer herauszufinden sein, allein wegen der Kommunikation Problematik.
  • Was kann noch einstellen Haufen Browser Tabs usw. Ofen zram oder noch wasanderesund Swappartion mit 32 GB RAM habe auch
  • Wie gesagt, ich glaube da hilft es nur wenn du deine Arbeitsweise den Gegebenheiten anpasst.
  • Du hast einen i5 und 32GB RAM, die Kist auszulasten nur mit Browsertabs ist schon ne "Leistung"
    Ich habe 16GB, 2 VMs am laufen, Terminals, Musik, ~40 Tabs und Kleingram und alles läuft supi.
    Wir brauchen mehr Infos wwas dein System betrifft!
  • Code
    nudels@nudels:~$ ps aux --sort=-%mem | head -n 5
    USER         PID %CPU %MEM    VSZ   RSS TTY      STAT START   TIME COMMAND
    nudels     45173 11.5  2.8 5484904 933876 ?      Sl   21:33  13:36 /usr/lib/firefox/firefox-bin -contentproc -isForBrowser -prefsHandle 0 -prefsLen 40186 -prefMapHandle 1 -prefMapSize 263215 -jsInitHandle 2 -jsInitLen 254356 -parentBuildID 20250120135430 -sandboxReporter 3 -chrootClient 4 -ipcHandle 5 -initialChannelId {cbc621b3-abe7-42cb-9309-f271ada80d5c} -parentPid 21037 -crashReporter 6 -greomni /usr/lib/firefox/omni.ja -appomni /usr/lib/firefox/browser/omni.ja -appDir /usr/lib/firefox/browser 82 tab
    nudels     88163 14.4  2.6 3487700 849488 ?      Sl   21:44  15:31 /usr/lib/firefox/firefox-bin -contentproc -isForBrowser -prefsHandle 0 -prefsLen 40243 -prefMapHandle 1 -prefMapSize 263215 -jsInitHandle 2 -jsInitLen 254356 -parentBuildID 20250120135430 -sandboxReporter 3 -chrootClient 4 -ipcHandle 5 -initialChannelId {850bbf17-1530-4cd3-bfc1-857e801b50ea} -parentPid 21037 -crashReporter 6 -greomni /usr/lib/firefox/omni.ja -appomni /usr/lib/firefox/browser/omni.ja -appDir /usr/lib/firefox/browser 119 tab
    nudels     21037 70.3  2.4 16830832 810260 ?     Sl   21:28  86:51 /usr/lib/firefox/firefox
    nudels    105539  2.5  1.6 3106144 540760 ?      Sl   21:48   2:36 /usr/lib/firefox/firefox-bin -contentproc -isForBrowser -prefsHandle 0 -prefsLen 40243 -prefMapHandle 1 -prefMapSize 263215 -jsInitHandle 2 -jsInitLen 254356 -parentBuildID 20250120135430 -sandboxReporter 3 -chrootClient 4 -ipcHandle 5 -initialChannelId {f7ea81d9-9674-494e-a03f-99a0fe2615c4} -parentPid 21037 -crashReporter 6 -greomni /usr/lib/firefox/omni.ja -appomni /usr/lib/firefox/browser/omni.ja -appDir /usr/lib/firefox/browser 122 tab
  • Code
    nudels     45173 11.2  8.3 5513576 2730620 ?     Rl   21:33  13:45 /usr/lib/firefox/firefox-bin -contentproc -isForBrowser -prefsHandle 0 -prefsLen 40186 -prefMapHandle 1 -prefMapSize 263215 -jsInitHandle 2 -jsInitLen 254356 -parentBuildID 20250120135430 -sandboxReporter 3 -chrootClient 4 -ipcHandle 5 -initialChannelId {cbc621b3-abe7-42cb-9309-f271ada80d5c} -parentPid 21037 -crashReporter 6 -greomni /usr/lib/firefox/omni.ja -appomni /usr/lib/firefox/browser/omni.ja -appDir /usr/lib/firefox/browser 82 tab
    nudels     42271  9.4  3.3 3790144 1092740 ?     Sl   21:32  11:37 /usr/lib/firefox/firefox-bin -contentproc -isForBrowser -prefsHandle 0 -prefsLen 40186 -prefMapHandle 1 -prefMapSize 263215 -jsInitHandle 2 -jsInitLen 254356 -parentBuildID 20250120135430 -sandboxReporter 3 -chrootClient 4 -ipcHandle 5 -initialChannelId {d986376b-b432-4c5a-b9a0-6a0f7f1f9435} -parentPid 21037 -crashReporter 6 -greomni /usr/lib/firefox/omni.ja -appomni /usr/lib/firefox/browser/omni.ja -appDir /usr/lib/firefox/browser 79 tab
    nudels     29403 11.5  3.3 3787860 1084624 ?     Sl   21:29  14:34 /usr/lib/firefox/firefox-bin -contentproc -isForBrowser -prefsHandle 0 -prefsLen 40186 -prefMapHandle 1 -prefMapSize 263215 -jsInitHandle 2 -jsInitLen 254356 -parentBuildID 20250120135430 -sandboxReporter 3 -chrootClient 4 -ipcHandle 5 -initialChannelId {a8128d80-dec2-474e-a4cd-1d8f642a66d7} -parentPid 21037 -crashReporter 6 -greomni /usr/lib/firefox/omni.ja -appomni /usr/lib/firefox/browser/omni.ja -appDir /usr/lib/firefox/browser 32 tab
    nudels     45080  7.7  3.1 3652304 1035564 ?     Sl   21:33   9:26 /usr/lib/firefox/firefox-bin -contentproc -isForBrowser -prefsHandle 0 -prefsLen 40186 -prefMapHandle 1 -prefMapSize 263215 -jsInitHandle 2 -jsInitLen 254356 -parentBuildID 20250120135430 -sandboxReporter 3 -chrootClient 4 -ipcHandle 5 -initialChannelId {f85995ed-ca22-47e0-b862-e7adbb6d514d} -parentPid 21037 -crashReporter 6 -greomni /usr/lib/firefox/omni.ja -appomni /usr/lib/firefox/browser/omni.ja -appDir /usr/lib/firefox/browser 81 tab
    nudels@nudels:~$
  • Aktuell ist dein Arbeitsspeicher nicht voll und die Swap wird nicht genutzt. Hast du Firefox Tabs geschlossen? Vielleicht fällt noch jemand anderem etwas dazu ein?
    6551,7 free,  24254,9 used,   5258,4 buff/cache
    free ist komplett frei und buff/cache ist frei aber für gestartete Prozesse reserviert.
  • Doch wird unterstütztz
     nudels@nudels:~$ free -m
                  gesamt       benutzt     frei      gemns.  Puffer/Cache verfügbar
    Speicher:      31839       23183        8017        3498        4573        8655
    Auslager:      32767           0       32767
    nudels@nudels:~$
