- Distrowahl
- Linux Mint
- inxi -Fzxi
Kernel: 6.12.3-surface-2 arch: x86_64 bits: 64 compiler: gcc v: 9.4.0
Desktop: Cinnamon v: 6.4.6 Distro: Linux Mint 22.1 Xia
base: Ubuntu 24.04 noble
Type: Laptop System: Microsoft product: Surface Pro
v: 124000000000000000000000D:0B:09F:5C:09P:38S:01E:0
serial: <superuser required>
Mobo: Microsoft model: Surface Pro serial: <superuser required>
UEFI: Microsoft v: 239.871.768 date: 11/07/2015
Battery:
ID-1: BAT1 charge: 28.3 Wh (82.0%) condition: 34.5/45.0 Wh (76.7%)
volts: 7.4 min: 7.6 model: SMP M1009169 status: discharging
Info: dual core model: Intel Core i5-7300U bits: 64 type: MCP
arch: Amber/Kaby Lake note: check rev: 9 cache: L1: 128 KiB L2: 512 KiB
L3: 3 MiB
Speed (MHz): avg: 550 high: 700 min/max: 400/3500 cores: 1: 700 2: 400
bogomips: 10799
Device-1: Intel HD Graphics 620 vendor: Microsoft driver: i915 v: kernel
arch: Gen-9.5 bus-ID: 00:02.0
resolution: 2736x1824~60Hz
active: x11,surfaceless,device inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.9-0ubuntu0.3
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 620 (KBL GT2)
Device-1: Intel Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Imaging
Unit driver: ipu3-imgu bus-ID: 00:05.0
Device-2: Intel CSI-2 Host driver: ipu3-cio2 bus-ID: 00:14.3
Device-3: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3
API: ALSA v: k6.12.3-surface-2 status: kernel-api
Device-1: Marvell 88W8897 [AVASTAR] 802.11ac Wireless driver: mwifiex_pcie
v: 1.0 bus-ID: 01:00.0
IF: wlp1s0 state: up mac: <filter>
Bluetooth:
Device-1: Marvell Bluetooth and Wireless LAN Composite driver: btusb v: 0.8
type: USB bus-ID: 1-5:3
Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 4.2
lmp-v: 8
Local Storage: total: 238.33 GiB used: 31.26 GiB (13.1%)
ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEBKF128G7 size: 119.24 GiB
temp: 20.9 C
ID-2: /dev/sda vendor: Generic model: SD MMC size: 119.08 GiB type: USB
ID-1: / size: 116.32 GiB used: 17.3 GiB (14.9%) fs: ext4 dev: /dev/nvme0n1p2
dev: /dev/nvme0n1p1
System Temperatures: cpu: 23.0 C pch: 21.5 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 8 GiB available: 7.68 GiB used: 1.47 GiB (19.2%)
Processes: 217 Uptime: 0m Init: systemd target: graphical (5)
Packages: 1988 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Moin!
Kann ich die laufende Konfiguration eines Rechners, die ich erstellt habe, auf einen bootfähigen USB Stick schreiben, um bei Bedarf mit meinen Einstellungen neu zu installieren?
Ich habe z.B. ein Microsoft Surface, auf dem ich nachträglich den Kernel mit Touchscreen Funktionalität usw. installiert habe.
Schön wäre auch, wenn bespielsweise meine Thunderbird- und Firefox Einstellungen funktionieren würde.
Kurz, alles, was ich nach der Installation ein- und verstellt habe, Programme, die ich installiert habe, sollten nach der Installation gleich wieder funktionien.
Geht so was? Man kann doch auch in Unternehmen vielen Rechnern die gleiche Konfiguration verpassen...
