- Distrowahl
- Linux Mint
- bernardos@bernardos-MS-7D30:~$ inxi -Fzxi
Kernel: 6.8.0-51-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
Desktop: Cinnamon v: 6.4.6 Distro: Linux Mint 22.1 Xia
base: Ubuntu 24.04 noble
Type: Desktop System: Micro-Star product: MS-7D30 v: 1.0
serial: <superuser required>
Mobo: Micro-Star model: MPG Z690 CARBON WIFI (MS-7D30) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.H0
date: 04/01/2024
Battery:
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
charge: 55% (should be ignored) status: discharging
Info: 12-core (8-mt/4-st) model: 12th Gen Intel Core i7-12700K bits: 64
type: MST AMCP arch: Alder Lake rev: 2 cache: L1: 1024 KiB L2: 12 MiB
L3: 25 MiB
Speed (MHz): avg: 936 high: 2217 min/max: 800/4900:5000:3800 cores: 1: 800
2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 2217 11: 800
12: 800 13: 800 14: 800 15: 800 16: 800 17: 800 18: 891 19: 800 20: 2016
bogomips: 144383
Device-1: NVIDIA GA104 [GeForce RTX 3060] vendor: Micro-Star MSI
driver: nvidia v: 550.120 arch: Ampere bus-ID: 01:00.0
Device-2: Realtek FULL HD 1080P Webcam driver: snd-usb-audio,uvcvideo
type: USB bus-ID: 1-11.4.2:10
loaded: N/A failed: nvidia gpu: nvidia,nvidia-nvswitch resolution:
1: 3840x2160~30Hz 2: 3840x2160~60Hz
API: EGL v: 1.5 drivers: kms_swrast,nvidia,swrast platforms:
active: gbm,x11,surfaceless,device inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.120
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
Device-1: Intel Alder Lake-S HD Audio vendor: Micro-Star MSI
Device-2: NVIDIA GA104 High Definition Audio vendor: Micro-Star MSI
Device-3: Realtek FULL HD 1080P Webcam driver: snd-usb-audio,uvcvideo
Device-4: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB bus-ID: 1-3:3
API: ALSA v: k6.8.0-51-generic status: kernel-api
Device-1: Intel Alder Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3
IF: wlo1 state: down mac: <filter>
Device-2: Intel Ethernet I225-V vendor: Micro-Star MSI driver: igc
v: kernel port: N/A bus-ID: 04:00.0
Bluetooth:
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB
bus-ID: 1-14:7
lmp-v: 12
Local Storage: total: 2.05 TiB used: 903.39 GiB (43.0%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 980 PRO 1TB size: 931.51 GiB
temp: 43.9 C
ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 980 PRO 1TB size: 931.51 GiB
temp: 35.9 C
ID-3: /dev/nvme2n1 vendor: Samsung model: MZVLW256HEHP-00000
size: 238.47 GiB temp: 34.9 C
ID-1: / size: 233.67 GiB used: 103.85 GiB (44.4%) fs: ext4
dev: /dev/nvme2n1p1
dev: /dev/nvme0n1p1
System Temperatures: cpu: 31.0 C mobo: N/A gpu: nvidia temp: 53 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Memory: total: 32 GiB note: est. available: 31.15 GiB used: 3.21 GiB (10.3%)
Processes: 412 Uptime: 21m Init: systemd
Packages: 2977 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Ich habe das hier im Terminal wegen Aktualisierungsverwaltung als Meldung erhalten. Mich würde interessieren, was es damit auf sich hat, insbesondere "29 nicht aktualisiert", aber auch was es sich mit gestaffelter Auslieferung auf sich hat.
Bin nur neugierig und hab das im Terminal eingegeben, da vorher unten in der Leiste bei mir zunächst ein Zahnrad erschien. Dieses Zahnrad hatte lediglich einen Hinweis, das gerade was aktualisiert wird? Und das Zahnrad mit dem Punkt ließ sich nicht aufrufen. Danach hab ich erstmal Neustart gemacht und erst dann den o.a. Befehl im Terminal gemacht. Danke für kommende Infos!
bernardos@bernardos-MS-7D30:~$ sudo apt-get dist-upgrade
Paketaktualisierung (Upgrade) wird berechnet… Fertig
Folgende Aktualisierungen wurden aufgrund von gestaffelter Auslieferung vorerst zurückgehalten:
bsdextrautils bsdutils eject fdisk firmware-sof-signed grub-common grub-efi-amd64-bin grub-pc grub-pc-bin
grub2-common libblkid1 libblkid1:i386 libfdisk1 libfprint-2-2 libfprint-2-tod1 libmount1 libmount1:i386
libnautilus-extension4 libsmartcols1 libuuid1 libuuid1:i386 mount nautilus-data rfkill util-linux uuid-runtime
xfsprogs xwayland
Die folgenden Pakete sind zurückgehalten worden:
grub-efi-amd64-signed
0 aktualisiert, 0 neu installiert, 0 zu entfernen und 29 nicht aktualisiert.
N: Some packages may have been kept back due to phasing.
