Ordner lässt sich nich öffnen, nicht löschen
    Linux Mint
    Host: Kernel: 6.8.0-51-generic arch: x86_64 bits: 64
    compiler: gcc v: 13.3.0
    base: Ubuntu 24.04 noble
    Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING II v: Rev 1.xx
    serial: <superuser required> UEFI: American Megatrends v: 4301
    date: 03/04/2021
    Battery:
    Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K270 charge: 100%
    (should be ignored) status: discharging
    Info: 8-core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2
    rev: 0 cache: L1: 512 KiB L2: 4 MiB L3: 32 MiB
    Speed (MHz): avg: 2306 high: 3931 min/max: 2200/4426 boost: enabled cores:
    1: 2200 2: 2200 3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2196
    10: 2200 11: 2200 12: 2196 13: 3931 14: 2189 15: 2196 16: 2200
    bogomips: 114984
    Device-1: NVIDIA GA104 [GeForce RTX 3060] vendor: Gigabyte driver: nvidia
    v: 535.183.01 arch: Ampere bus-ID: 09:00.0
    loaded: nouveau unloaded: fbdev,modesetting,vesa failed: nvidia
    gpu: nvidia,nvidia-nvswitch resolution: 3840x2160
    API: EGL v: 1.5 drivers: kms_swrast,nvidia,swrast platforms:
    active: gbm,x11,surfaceless,device inactive: wayland,device-1
    API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 535.183.01
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
    Device-1: Creative Labs CA0132 Sound Core3D [Sound Blaster Recon3D /
    Z-Series BlasterX AE-5 Plus] driver: snd_hda_intel v: kernel
    bus-ID: 08:00.0
    Device-2: NVIDIA GA104 High Definition Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel bus-ID: 09:00.1
    Device-3: AMD Starship/Matisse HD Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 0b:00.4
    API: ALSA v: k6.8.0-51-generic status: kernel-api
    Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
    port: e000 bus-ID: 03:00.0
    IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: f0:2f:74:21:44:20
    Local Storage: total: 10.23 TiB used: 4.36 TiB (42.6%)
    ID-1: /dev/sda vendor: Western Digital model: WD30EFRX-68EUZN0
    ID-2: /dev/sdb vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
    ID-3: /dev/sdc vendor: Samsung model: SSD 870 QVO 2TB size: 1.82 TiB
    ID-4: /dev/sdd vendor: Seagate model: ST2000DX001-1NS164 size: 1.82 TiB
    ID-5: /dev/sde vendor: Western Digital model: WD40NMZW-11GX6S1
    size: 3.64 TiB type: USB
    ID-1: / size: 1.79 TiB used: 85.54 GiB (4.7%) fs: ext4 dev: /dev/sdc2
    ID-1: swap-1 type: file size: 2 GiB used: 1024 KiB (0.0%) file: /swapfile
    System Temperatures: cpu: 38.0 C mobo: 35.0 C gpu: nvidia temp: 48 C
    Fan Speeds (rpm): cpu: 1146 case-1: 0 case-2: 700 case-3: 0 gpu: nvidia
    fan: 0%
    Power: 12v: 10.08 5v: N/A 3.3v: N/A vbat: 3.23
    Memory: total: 16 GiB available: 15.51 GiB used: 5.9 GiB (38.0%)
    Processes: 447 Uptime: 3h 11m Init: systemd target: graphical (5)
    Packages: 2434 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
    Hallo
    Ich mache Regelmäßig von meinen Lesezeichen Backups auf meinen Externen Festplatten seit Mittwoch bekomme diese Fehlermeldung.
    Wenn ich den Ordner löschen möchte kommt diese Meldung.
    Fehler beim Holen der Informationen für Datei »/mnt/wwn-0x50014ee0af22fa5c-part1/Tools/Backup & Tools/Bookmarks/bookmarks_20.12.24.html«: Eingabe-/Ausgabefehler
    Das hat ich vor Monaten mit einem anderen Ordner auch gehabt, da habe ich in Linux Mint ein Tool das ich zufällig gefunden habe leider weiß ich nicht wie es heißt.
    Linux Mint 22.3 Zena
  • ansonsten mit sudo rm -rf /pfad/zum/order einfach vorsicht, dass ist dann endgültig und weg.
  • Hmm wenn ein Eingabe-/Ausgabefehler auftritt würde ich auch mal die Festplatte überprüfen also die SMART Werte auslesen (soweit der Controller des Festplattengehäuse dies unterstützt) und dass Filesystem überprüfen lassen.
    Evtl auch die Festplatte mal in einem anderen Gehäuse testen.
  • Laufwerke sagt mir Festplatte ist in Ordnung.
    Habe kein anderes Gehäuse wo ich Anschließen könnte.
  • @karl-heinz-lnx mount | grep /mnt/
    /dev/sdb1 on /mnt/5AF6A54BF6A52869 type fuseblk (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other,blksize=4096,x-gvfs-show,x-gvfs-name=Volume)
    /dev/sda2 on /mnt/E2B0404FB0402C7B type fuseblk (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other,blksize=4096,x-gvfs-show)
    /dev/sdd1 on /mnt/8C1CDE2E1CDE12D6 type fuseblk (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other,blksize=4096,x-gvfs-show,x-gvfs-name=Datenträger)
    Borrtux
    algl Die Option für SMART isst ausgegraut.
  • Nutzt du die Platten auch unter Windows, oder warum sind sie NTFS-formatiert? Wenn möglich, sollte man unter Linux auf NTFS verzichten, das macht immer mal wieder Probleme, schon wegen der Dateiattribute und der Userberechtigungen.
    Evtl. hast du die Platte unter Windows einfach abgezogen statt sicher zu entfernen. Dann sollte das chkdsk hinbekommen.
  • Rasalom Von Windows habe ich mich schon lange verabschiedet nutze Linux nur noch seit durchgehend davor Linux Parallel Die Platten stammen noch aus der Windows zeit .
  • Wie greifst du auf den Ordner zu? Bzw. von wo kommt die Fehlermeldung?
    Weil mir scheint in #9 die Festplatte auf der die Bookmarks gespeichert sind, gar nicht eingehängt zu sein. Zumindest ist in der dortigen Liste die "ID", nicht wie in der Fehlermeldung, zu sehen.
    Wenn du den PC neustartest, den Dateimanager öffnest, und dort die Festplatte "sde" einhängst (wird meist angezeigt - ich kann es gerade nicht genau sagen, weil ich aktuell kein Cinammon habe) indem du darauf klickst, sollte es funktionieren.
    Wenn du eine Verknüpfung auf den Ordner hast, musst du diesen evtl. wieder anpassen. Nach meiner Erfahrung ist es am besten den Festplatten/Partitionen ein Label zuzuweißen und diese in der Verknüpfung zu verwenden. Damit fährt man meist besser (beim Browser/Programm muss der Pfad evtl. ebenfalls geändert werden mit ggf. Programmneustart).
    Ich hoffe die Festplatte mit 4 TB ist nicht allein für Bookmarks gedacht, weil da passen sehr viele Bookmarks darauf ;)
  • Lessli Auf der 4 TB Festplatte ist noch mehr drauf nicht nur der Ordner Bookmarks.
    Die Festplatte wird ganz normal Eingehängt, angezeigt sobald ich den Ordner mit Doppelklick öffne kommt die Meldung, der Ordner lässt sich auch nicht löschen wollte es Testen geht nicht.
  • Wo ist denn das Verzeichnis /mnt/wwn-* im Ergebnis des grep? Sieht aus als wäre es nicht mehr gemountet, ergo kann man auch keine Dateioperationen durchführen.
  • Zeig uns doch mal den Inhalt deines Mount-Verzeichnisses.
    ls -l /mnt
    und wenn du mount -a ausführst. Passiert dann irgendwas?
  • Bulvai hier die Ausgabe.
    insgesamt 136
    drwxrwxrwx 1 root root 20480 Jan 22 07:00 5AF6A54BF6A52869
    drwxrwxrwx 1 root root 16384 Jan 22 07:00 8C1CDE2E1CDE12D6
    drwxrwxrwx 1 root root 81920 Jun  8  2022 E2B0404FB0402C7B
    drwxr-xr-x 2 root root  4096 Aug  5 15:26 wwn-0x5000cca0d8c783e8-part1
    drwxrwxrwx 1 root root 12288 Jan 18 13:36 wwn-0x50014ee0af22fa5c-part1
    drwxr-xr-x 2 root root  4096 Aug  5 18:32 wwn-0x50014ee2bba61df0-part2
    Ich habe mount -a eingegeben und fragte mich was soll da passieren soll?.
    Lessli Ich komme erst gar nicht rein bei öffnen des Ordners kommt die Fehlermeldung.
