- System:
Kernel: 6.8.0-51-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
base: Ubuntu 24.04 noble
Type: Desktop Mobo: ASRock model: B650M PG Riptide
serial: <superuser required> UEFI: American Megatrends LLC. v: 2.08
date: 03/01/2024
Info: 12-core model: AMD Ryzen 9 7900 bits: 64 type: MT MCP arch: Zen 4
rev: 2 cache: L1: 768 KiB L2: 12 MiB L3: 64 MiB
Speed (MHz): avg: 533 high: 3604 min/max: 400/5482 cores: 1: 400 2: 400
3: 400 4: 400 5: 400 6: 400 7: 400 8: 400 9: 3604 10: 400 11: 400 12: 400
13: 400 14: 400 15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 21: 400
22: 400 23: 400 24: 400 bogomips: 177268
Device-1: NVIDIA TU104 [GeForce RTX 2060] vendor: eVga.com. driver: nvidia
v: 550.120 arch: Turing bus-ID: 01:00.0
Device-2: AMD Raphael driver: amdgpu v: kernel arch: RDNA-2
bus-ID: 0f:00.0 temp: 43.0 C
loaded: amdgpu,nouveau unloaded: fbdev,modesetting,vesa failed: nvidia
dri: radeonsi gpu: nvidia,nvidia-nvswitch resolution: 5120x2880~60Hz
API: EGL v: 1.5 drivers: kms_swrast,nvidia,radeonsi,swrast platforms:
active: gbm,x11,surfaceless,device inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.120
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2
Device-1: NVIDIA TU104 HD Audio vendor: eVga.com. driver: snd_hda_intel
v: kernel bus-ID: 01:00.1
Device-2: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 0f:00.1
Device-3: AMD Family 17h/19h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus-ID: 0f:00.6
API: ALSA v: k6.8.0-51-generic status: kernel-api
Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
port: e000 bus-ID: 07:00.0
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-33bf4204706e state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v4: <filter> scope: global
IP v6: <filter> scope: link
IF-ID-2: br-4495cc0fe563 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-3: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-4: veth08276c7 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-5: veth365c11b state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-6: vethd02b910 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-7: vethd182526 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-8: vethf4bcb07 state: up speed: 10000 Mbps duplex: full
mac: <filter>
Local Storage: total: 4.25 TiB used: 31.07 GiB (0.7%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WD Blue SN570 1TB
size: 931.51 GiB temp: 35.9 C
ID-2: /dev/nvme1n1 vendor: Lexar model: SSD NM790 2TB size: 1.86 TiB
temp: 55.9 C
ID-3: /dev/sda vendor: Seagate model: ST1000DM003-9YN162 size: 931.51 GiB
ID-4: /dev/sdb vendor: Western Digital model: WD5000AACS-00ZUB0
ID-5: /dev/sdc vendor: A-Data model: SP900 size: 119.24 GiB
ID-1: / size: 1.83 TiB used: 31.03 GiB (1.7%) fs: ext4 dev: /dev/nvme1n1p2
ID-2: /boot/efi size: 96 MiB used: 37.6 MiB (39.2%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: 50.2 C mobo: N/A
Fan Speeds (rpm): N/A
GPU: device: nvidia screen: :0.0 temp: 37 C fan: 0% device: amdgpu
temp: 44.0 C
Memory: total: 32 GiB note: est. available: 30.47 GiB used: 4.41 GiB (14.5%)
Processes: 520 Uptime: 34m Init: systemd target: graphical (5)
Packages: 2632 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Hallo zusammen,
kann es sein, dass man bei Linux Mint 22 viele Programme nicht in der Anwendungsverwaltung findet, die es in Mint 21.3 noch gab?
Oder hab ich da irgendwas vergessen einzustellen/konfigurieren?
Danke schon mal!
Grüße
Johannes
