Linux Mint 22: Weniger Apps in Anwendungsverwaltung als in 21.3?
    Kernel: 6.8.0-51-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
    base: Ubuntu 24.04 noble
    Type: Desktop Mobo: ASRock model: B650M PG Riptide
    serial: <superuser required> UEFI: American Megatrends LLC. v: 2.08
    date: 03/01/2024
    Info: 12-core model: AMD Ryzen 9 7900 bits: 64 type: MT MCP arch: Zen 4
    rev: 2 cache: L1: 768 KiB L2: 12 MiB L3: 64 MiB
    Speed (MHz): avg: 533 high: 3604 min/max: 400/5482 cores: 1: 400 2: 400
    3: 400 4: 400 5: 400 6: 400 7: 400 8: 400 9: 3604 10: 400 11: 400 12: 400
    13: 400 14: 400 15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 21: 400
    22: 400 23: 400 24: 400 bogomips: 177268
    Device-1: NVIDIA TU104 [GeForce RTX 2060] vendor: eVga.com. driver: nvidia
    v: 550.120 arch: Turing bus-ID: 01:00.0
    Device-2: AMD Raphael driver: amdgpu v: kernel arch: RDNA-2
    bus-ID: 0f:00.0 temp: 43.0 C
    loaded: amdgpu,nouveau unloaded: fbdev,modesetting,vesa failed: nvidia
    dri: radeonsi gpu: nvidia,nvidia-nvswitch resolution: 5120x2880~60Hz
    API: EGL v: 1.5 drivers: kms_swrast,nvidia,radeonsi,swrast platforms:
    active: gbm,x11,surfaceless,device inactive: wayland,device-1
    API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.120
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2
    Device-1: NVIDIA TU104 HD Audio vendor: eVga.com. driver: snd_hda_intel
    v: kernel bus-ID: 01:00.1
    Device-2: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
    v: kernel bus-ID: 0f:00.1
    Device-3: AMD Family 17h/19h HD Audio vendor: ASRock driver: snd_hda_intel
    v: kernel bus-ID: 0f:00.6
    API: ALSA v: k6.8.0-51-generic status: kernel-api
    Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
    port: e000 bus-ID: 07:00.0
    IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
    IF-ID-1: br-33bf4204706e state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
    IP v4: <filter> scope: global
    IP v6: <filter> scope: link
    IF-ID-2: br-4495cc0fe563 state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
    IF-ID-3: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
    IF-ID-4: veth08276c7 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
    IF-ID-5: veth365c11b state: up speed: 10000 Mbps duplex: full
    mac: <filter>
    IF-ID-6: vethd02b910 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
    IF-ID-7: vethd182526 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
    IF-ID-8: vethf4bcb07 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
    Local Storage: total: 4.25 TiB used: 31.07 GiB (0.7%)
    ID-1: /dev/nvme0n1 vendor: Western Digital model: WD Blue SN570 1TB
    size: 931.51 GiB temp: 35.9 C
    ID-2: /dev/nvme1n1 vendor: Lexar model: SSD NM790 2TB size: 1.86 TiB
    temp: 55.9 C
    ID-3: /dev/sda vendor: Seagate model: ST1000DM003-9YN162 size: 931.51 GiB
    ID-4: /dev/sdb vendor: Western Digital model: WD5000AACS-00ZUB0
    ID-5: /dev/sdc vendor: A-Data model: SP900 size: 119.24 GiB
    ID-1: / size: 1.83 TiB used: 31.03 GiB (1.7%) fs: ext4 dev: /dev/nvme1n1p2
    ID-2: /boot/efi size: 96 MiB used: 37.6 MiB (39.2%) fs: vfat
    dev: /dev/nvme0n1p1
    System Temperatures: cpu: 50.2 C mobo: N/A
    Fan Speeds (rpm): N/A
    GPU: device: nvidia screen: :0.0 temp: 37 C fan: 0% device: amdgpu
    temp: 44.0 C
    Memory: total: 32 GiB note: est. available: 30.47 GiB used: 4.41 GiB (14.5%)
    Processes: 520 Uptime: 34m Init: systemd target: graphical (5)
    Packages: 2632 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
    Hallo zusammen,
    kann es sein, dass man bei Linux Mint 22 viele Programme nicht in der Anwendungsverwaltung findet, die es in Mint 21.3 noch gab?:/
    Oder hab ich da irgendwas vergessen einzustellen/konfigurieren?
    Danke schon mal!
    Grüße
    Johannes
    ASRock B650 PG Riptide
    AMD Ryzen 9 7900
    Geforce RTX2060
    32 GB DDR5
    Linux Mint 22
    Linux Mint 21.3
    Windows 11
  • Go to Best Answer
  • Danke für die Rückmeldung!
    Ich vermisse zum Beispiel Ultimaker Cura, das ich unter Mint 21.3 definitiv über die Anwendungsverwaltung installiert habe. Und Joplin (da bin ich mir aber nicht mehr ganz sicher, ob ich das nicht anders installiert habe).
    Werden alle installierten Programme in der Anwendungsverwaltung angezeigt, wenn ich mir die installierten anzeigen lasse? Also auch die, die man nicht darüber installiert hat?
    AMD Ryzen 9 7900
    Geforce RTX2060
    32 GB DDR5
    Linux Mint 22
    Linux Mint 21.3
    Windows 11
  • Joplin ist in 21.3 nicht drin. Für Cura finde ich:
    $ apt search cura
    p   cura                                  - GUI G-code generator for 3D printers
    p   cura-engine                           - command line slicer engine for 3d printing
    ist es das was du suchst?
  • Ja, das müsste es sein --> unter Mint 22 nicht vorhanden.
    Ah, dann hab ich Joplin damals scheinbar anders installiert.
    Weiß jemand, wieso manche hier nicht verfügbar sind und ob das dann normalerweise nach und nach dazu kommt?
    Danke!
    AMD Ryzen 9 7900
    Geforce RTX2060
    32 GB DDR5
    Linux Mint 22
    Linux Mint 21.3
    Windows 11
  • DenalB January 14, 2025 at 12:44 PM
    Changed the title of the thread from “Anwendungsverwaltung Mint 22” to “Linux Mint 22: Weniger Apps in Anwendungsverwaltung als in 21.3?”.
    Du musst in der Anwendungsverwaltung in den Einstellungen die ungeprüften Flatpak's freischalten und schon sind die Programme die du vermisst wieder da.
    DELL OptiPlex 7010 Tower | Intel Core i5-13500 | Intel UHD Graphics 770 | 32 GB RAM | Fedora Linux 41| KDE Plasma | Kernel 6.12.11
  • Du musst in der Anwendungsverwaltung in den Einstellungen die ungeprüften Flatpak's freischalten und schon sind die Programme die du vermisst wieder da.
    Oh Mann:D, darauf hätte ich auch kommen können. Hab sogar schon nach einer solchen Einstellung gesucht, aber nicht gefunden, wie doof kann man sein:rolleyes:
    DANKE!
    AMD Ryzen 9 7900
    Geforce RTX2060
    32 GB DDR5
    Linux Mint 22
    Linux Mint 21.3
    Windows 11
  • das leigt ned an mint sodner an ubuntu canicla das die nache pakete kicken usw
    Dell Latiude 7390 mit i5 32gb Ram und darauf LM 22 XFCE und andere Tuxe Bitte um Nachsicht wegen meiner Rechtschreibprobs. Habe Legasthenie, wenn man was nicht lesen kann, einfach nachfragen.
  • Joplin gib es auch als App-Image
    Ich denke mal die Zeit von Repos und Anwendungsverwaltung geht bald vorbei. Hauptaugenmerk sind die App-Images.
    Ich nutze nur noch App-Images. Ich kann die dann gut auf einen Server verteilen und von jedem Linux-Gerät starten.
  • Danke euch!
    Die entsprechenden AppImages kannte ich auch schon. Über die Anwendungsverwaltung ist das nur viel einfacher für mich. AppImages kann man auch nicht automatisch aktualisieren lassen, oder? :/
    AMD Ryzen 9 7900
    Geforce RTX2060
    32 GB DDR5
    Linux Mint 22
    Linux Mint 21.3
    Windows 11
  • Danke euch!
    Ja(kann man nicht aktualisieren), aber ab und zu mal auf der Webseite schauen und einfach die App-Images austauschen.Die App-Images geben aber auch eine Meldung ab, dass eine neuere Version verfügbar ist.
  • Ich denke mal die Zeit von Repos und Anwendungsverwaltung geht bald vorbei. Hauptaugenmerk sind die App-Images.
    Ich hoffe - aus keinen Fall ;) Was irgendwie geht kommt aus den Repos!
  • Die aktualisieren sich automatisch!
    Aber nicht alle.
    Siehe das Video von Jean.
