Linux Mint Cinnamon - Benachrichtigungen wieder auf Standard
    Linux Mint
    Kernel: 6.8.0-51-generic x86_64 bits: 64 compiler: N/A
    Desktop: Cinnamon 6.0.4 Distro: Linux Mint 21.3 Virginia
    base: Ubuntu 22.04 jammy
    Type: Laptop System: HP product: HP EliteBook 840 G6 v: N/A
    serial: <superuser required>
    Mobo: HP model: 8549 v: KBC Version 52.6F.00 serial: <superuser required>
    UEFI: HP v: R70 Ver. 01.24.00 date: 03/27/2023
    Battery:
    ID-1: BAT0 charge: 33.4 Wh (93.3%) condition: 35.8/50.2 Wh (71.3%)
    volts: 11.8 min: 11.6 model: Hewlett-Packard Primary status: Discharging
    Info: quad core model: Intel Core i5-8365U bits: 64 type: MT MCP
    arch: Comet/Whiskey Lake note: check rev: C cache: L1: 256 KiB L2: 1024 KiB
    L3: 6 MiB
    Speed (MHz): avg: 800 min/max: 400/4100 cores: 1: 800 2: 800 3: 800
    4: 800 5: 800 6: 800 7: 800 8: 800 bogomips: 30399
    Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620]
    vendor: Hewlett-Packard driver: i915 v: kernel bus-ID: 00:02.0
    Device-2: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD
    Integrated Webcam
    type: USB driver: uvcvideo bus-ID: 1-9:5
    Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: modesetting
    unloaded: fbdev,vesa gpu: i915 resolution: 1920x1080~60Hz
    OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2)
    v: 4.6 Mesa 23.2.1-1ubuntu3.1~22.04.3 direct render: Yes
    Device-1: Intel Cannon Point-LP High Definition Audio
    vendor: Hewlett-Packard driver: sof-audio-pci-intel-cnl bus-ID: 00:1f.3
    Sound Server-1: ALSA v: k6.8.0-51-generic running: yes
    Device-1: Intel Ethernet I219-LM vendor: Hewlett-Packard driver: e1000e
    v: kernel port: N/A bus-ID: 00:1f.6
    IF: enp0s31f6 state: down mac: <filter>
    Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 3a:00.0
    IF: wlp58s0 state: up mac: <filter>
    IP v4: <filter> type: noprefixroute scope: global
    IF-ID-1: br-3128c8b28a8d state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
    IP v4: <filter> scope: global
    IP v6: <filter> scope: link
    IF-ID-2: br-338b1bf599d3 state: down mac: <filter>
    IF-ID-3: br-d04283c63f6f state: down mac: <filter>
    IF-ID-4: docker0 state: down mac: <filter>
    IF-ID-5: vethe7e39f8 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
    Bluetooth:
    Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
    bus-ID: 1-10:6
    Report: hciconfig ID: hci0 rfk-id: 9 state: up address: <filter>
    bt-v: 3.0 lmp-v: 5.2
    Local Storage: total: 931.51 GiB used: 128.22 GiB (13.8%)
    ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 980 1TB size: 931.51 GiB
    temp: 28.9 C
    ID-1: / size: 239.04 GiB used: 128.13 GiB (53.6%) fs: ext4
    dev: /dev/nvme0n1p6
    ID-2: /boot/efi size: 100.2 MiB used: 94.2 MiB (94.0%) fs: vfat
    dev: /dev/nvme0n1p2
    System Temperatures: cpu: 41.0 C pch: 39.0 C mobo: 30.0 C
    Fan Speeds (RPM): N/A
    Processes: 542 Uptime: 1d 16h 11m Memory: 15.44 GiB used: 13.46 GiB (87.2%)
    Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 3782 Shell: Bash
    v: 5.1.16 inxi: 3.3.13
    ich habe am System herumgespielt und mir dabei die Benachrichtigungen zerschossen. Ich nutze im Moment Linux Mint 21.3 Cinnamon und meine Benachrichtigungen sehen etwa so aus:
    Leider weiß ich nicht mehr, was ich gemacht oder ausprobiert bzw. installiert habe. Ist schon einige Wochen her. Wie kann man das wieder richtig hinbekommen? Benötigt ihr eventuell mehr Infos?
    Danke schon Mal im Voraus!
    Grüße,
    Palim
  • Du könntest einen Wiederherstellungspunkt von Timeshift verwenden. Da ich mich sonst mit Mint nicht so gut auskenne kann ich das sonst auch nix zu sagen. Vielleicht haben die Anderen da mehr Ahnung von.
  • Hallo palim mach doch mal einen Screenshot von dem Bereich (vermute in der Taskleiste) in dem sich das Benachrichtigungsymbol befindet. Ich kann noch nicht erkennen, welches Du meinst.
    Desktop: Cinnamon v: 6.4.6 Distro: Linux Mint 22.1 Xia; GuideOS Debian 12 Cinnamon v:5.6.8
    Machine: Type: Laptop System: ASUSTeK product: N76VB v: 1.0
    CPU: Intel© Core™ i7-3630QM CPU @ 2.40GHz × 4
    UEFI: American Megatrends v: N76VB.205 date: 05/24/2013
    Graphics: Device-1: NVIDIA GK107M [GeForce GT 740M]
  • Schau doch mal in den Einstellungen unter „Meldungen“, ich hab hier die Standard-Einstellungen mal als Screenshot beigefügt.
    DELL OptiPlex 7030 Tower | Intel Core i5-13500 | Intel UHD Graphics 770 | 32 GB RAM | Tuxedo OS | KDE Plasma 6.5.2 | Kernel 6.14.0-116036-tuxedo
  • Timeshift habe ich leider deaktiviert, da ich im Moment nur eine kleine NVMe in meinem Notebook habe.
    Ritchy Das Applet "Benachrichtigungsanzeige" für die Taskleiste ist aktiviert, aber es werden dort keine Benachrichtigungen mehr angezeigt. Das war mir vor deiner Nachfrage gar nicht aufgefallen. Alle Benachrichtigungen die reinkommen werden nur wenige Sekunden angezeigt, daher ist es extrem schwierig einen Screenshot zu erstellen. Ich habe mit notify-send "Test" -t 20000 diese Test-Benachrichtigung erstellt, damit man wenigstens etwas als Beispiel sehen kann.
  • Das Applet "Benachrichtigungsanzeige" für die Taskleiste ist aktiviert, aber es werden dort keine Benachrichtigungen mehr angezeigt.
    Dann klich mit der rechten Maustaste auf die Leiste und öffne die Applets. Dort findest Du Meldungen. Die hat Einstellungsmöglichkeiten. Zur Not auch deinstallieren und wieder neu installieren.
  • Hier nochmal ein Screenshot von einer Testbenachrichtigung, die man aus der Cinnamon-App Meldungen aus ausführen kann:
    Ich habe an meinem Cinnamon-Theme nichts umgestellt, daher sieht das hier völlig befremdlich aus.
    Man kann das Applet nicht deinstallieren, man kann es nur deaktivieren und ich glaube es hat auch nichts mit der Darstellungweise des Popups zu tun. Ich glaube irgendein anderes Tool hat sich die Berechtigungen geschnappt.
    Irgendwie erinnert mich das Aussehen an dmenu von suckless.org. Das war eins der Dinge, die ich ausprobiert habe. Aber wie kann ich herausfinden, was zur Anzeige benutzt wird und es umstellen?
  • Das ist wohl einfach eine Testnachricht die wohl mit diesem Tool oder den selben Algorithmus erstellt wurde. Das ist ein simpler Textgenerator.
  • Hattest du dunst selber installiert? Oder wie kommt das auf dein System?
  • Gut zu wissen,weil irgendwie habe ich versucht den Fehler zurück zu führen. Erst habe ein Theme getippt, aber hat sich wohl dann geklärt.
    Ich nutze für meine Scripte momentan https://ntfy.sh/ als Nachrichtenmessenger. Auch für Android.
    curl -d "Backup successful 😀".....
