Wine-Reste komplett entfernen und neu installieren
    Linux Mint
    Kernel: 6.8.0-49-generic arch: x86_64 bits: 64 compiler: gcc v: 13.2.0
    base: Ubuntu 24.04 noble
    Type: Desktop Mobo: ASUSTeK model: P8Z68 DELUXE v: Rev 1.xx
    serial: <superuser required> BIOS: American Megatrends v: 0603
    date: 06/14/2011
    Info: quad core model: Intel Core i7-2600K bits: 64 type: MT MCP
    arch: Sandy Bridge rev: 7 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
    Speed (MHz): avg: 1887 high: 3800 min/max: 1600/3800 cores: 1: 1605
    2: 1688 3: 1600 4: 1600 5: 3800 6: 1600 7: 1605 8: 1600 bogomips: 54579
    Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
    Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
    vendor: ASUSTeK driver: i915 v: kernel arch: Gen-6 bus-ID: 00:02.0
    Device-2: NVIDIA GP106 [GeForce GTX 1060 6GB] driver: nvidia v: 470.256.02
    arch: Pascal bus-ID: 01:00.0
    loaded: modesetting,nvidia unloaded: fbdev,nouveau,vesa dri: crocus
    gpu: i915,nvidia resolution: 1: 1920x1080~60Hz 2: 1920x1080~60Hz
    API: EGL v: 1.5 drivers: crocus,nvidia,swrast platforms:
    active: x11,surfaceless,device inactive: gbm,wayland,device-2
    API: OpenGL v: 4.6.0 compat-v: 3.3 vendor: nvidia mesa v: 470.256.02
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1060
    6GB/PCIe/SSE2
    Device-1: Intel 6 Series/C200 Series Family High Definition Audio
    vendor: ASUSTeK P8P67 Deluxe driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    Device-2: NVIDIA GP106 High Definition Audio driver: snd_hda_intel
    v: kernel bus-ID: 01:00.1
    Device-3: Intel USB PnP Sound Device
    driver: hid-generic,snd-usb-audio,usbhid type: USB bus-ID: 2-1.1:3
    API: ALSA v: k6.8.0-49-generic status: kernel-api
    Device-1: Intel 82579V Gigabit Network vendor: ASUSTeK P8P67 Deluxe
    driver: e1000e v: kernel port: f080 bus-ID: 00:19.0
    IF: eno1 state: up speed: 100 Mbps duplex: full mac: <filter>
    vendor: ASUSTeK P8P67 and other motherboards driver: r8169 v: kernel
    port: a000 bus-ID: 0e:00.0
    IF: enp14s0 state: down mac: <filter>
    Device-3: MediaTek WiFi driver: mt76x0u type: USB bus-ID: 1-1.3:3
    IF: wlx803f5d2134c1 state: down mac: <filter>
    Bluetooth:
    Device-1: Qualcomm Atheros AR3011 Bluetooth driver: btusb v: 0.8 type: USB
    bus-ID: 1-1.7:8
    Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 3.0
    lmp-v: 5
    Local Storage: total: 5.73 TiB used: 1.46 TiB (25.4%)
    ID-1: /dev/sda vendor: Samsung model: SSD 840 EVO 120GB size: 111.79 GiB
    ID-2: /dev/sdb vendor: Toshiba model: HDWE140 size: 3.64 TiB
    ID-3: /dev/sdg vendor: SanDisk model: USB 3.2Gen1 size: 57.3 GiB type: USB
    ID-4: /dev/sdh vendor: Seagate model: ST32000641AS size: 1.82 TiB
    ID-5: /dev/sdi vendor: SanDisk model: SDSSDA120G size: 111.79 GiB
    ID-1: / size: 107.39 GiB used: 44.03 GiB (41.0%) fs: ext4 dev: /dev/sdi3
    ID-2: /boot/efi size: 188 MiB used: 6.1 MiB (3.2%) fs: vfat dev: /dev/sdi2
    ID-1: swap-1 type: partition size: 1.93 GiB used: 0 KiB (0.0%)
    dev: /dev/sdi4
    System Temperatures: cpu: 37.0 C mobo: 36.0 C gpu: nvidia temp: 41 C
    Fan Speeds (rpm): fan-1: 1061 fan-2: 2086 fan-3: 0 fan-4: 0 fan-5: 0
    gpu: nvidia fan: 25%
    Power: 12v: N/A 5v: N/A 3.3v: 3.30 vbat: 3.38
    Memory: total: 16 GiB available: 15.53 GiB used: 4.49 GiB (28.9%)
    Processes: 417 Uptime: 1h 13m Init: systemd target: graphical (5)
    Packages: 2881 Compilers: gcc: 13.2.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
    offenbar habe ich etwas zu viel mit Wine und PlayonLunix herumexperimentiert.
    Die Deinstallation von wine ist offenbar nicht richtig gelungen, zumal ich auch noch andere Versionen installiert habe und hatte
    So sollte sich eine Neuinstallation von wine aus der Anwendungsverwaltung von Mint Cinnemon starten lassen, Das tut sie aber nicht.
    Mir ist auch etwas unklar, welche der angebotenen wine-s wirklich für eine effektive Nutzung von Windows-Programmen benötigt werden.
    Und wie ich eine saubere Umgebung wieder hinbekomme...
    Gruß DreyDee
  • Hallo Der Dude,
    Ja, doch. Ich habe Timeshift-Snapshot, aber leider war wine da schon installiert. Und offenbar hat es die neuen Änderungen nicht rausgeschmissen...
    Hallo Kater,
    Danke.
    Gruß DreyDEe
