- Distrowahl
- Linux Mint
- System:
Kernel: 6.8.0-49-generic arch: x86_64 bits: 64 compiler: gcc v: 13.2.0
base: Ubuntu 24.04 noble
Type: Desktop Mobo: ASUSTeK model: P8Z68 DELUXE v: Rev 1.xx
serial: <superuser required> BIOS: American Megatrends v: 0603
date: 06/14/2011
Info: quad core model: Intel Core i7-2600K bits: 64 type: MT MCP
arch: Sandy Bridge rev: 7 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
Speed (MHz): avg: 1916 high: 3800 min/max: 1600/3800 cores: 1: 1915
2: 1605 3: 1605 4: 1600 5: 3800 6: 1600 7: 1605 8: 1600 bogomips: 54579
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: ASUSTeK driver: i915 v: kernel arch: Gen-6 bus-ID: 00:02.0
Device-2: NVIDIA GP106 [GeForce GTX 1060 6GB] driver: nvidia v: 470.256.02
arch: Pascal bus-ID: 01:00.0
loaded: modesetting,nvidia unloaded: fbdev,nouveau,vesa dri: crocus
gpu: i915,nvidia resolution: 1: 1920x1080~60Hz 2: 1920x1080~60Hz
API: EGL v: 1.5 drivers: crocus,nvidia,swrast platforms:
active: x11,surfaceless,device inactive: gbm,wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 3.3 vendor: nvidia mesa v: 470.256.02
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1060
6GB/PCIe/SSE2
Device-1: Intel 6 Series/C200 Series Family High Definition Audio
vendor: ASUSTeK P8P67 Deluxe driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA GP106 High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 01:00.1
Device-3: Intel USB PnP Sound Device
driver: hid-generic,snd-usb-audio,usbhid type: USB bus-ID: 2-1.1:3
API: ALSA v: k6.8.0-49-generic status: kernel-api
Device-1: Intel 82579V Gigabit Network vendor: ASUSTeK P8P67 Deluxe
driver: e1000e v: kernel port: f080 bus-ID: 00:19.0
IF: eno1 state: up speed: 100 Mbps duplex: full mac: <filter>
vendor: ASUSTeK P8P67 and other motherboards driver: r8169 v: kernel
port: a000 bus-ID: 0e:00.0
IF: enp14s0 state: down mac: <filter>
Device-3: MediaTek WiFi driver: mt76x0u type: USB bus-ID: 1-1.3:3
IF: wlx803f5d2134c1 state: down mac: <filter>
Bluetooth:
Device-1: Qualcomm Atheros AR3011 Bluetooth driver: btusb v: 0.8 type: USB
bus-ID: 1-1.7:8
address: <filter>
Local Storage: total: 5.73 TiB used: 106.11 GiB (1.8%)
ID-1: /dev/sda vendor: Samsung model: SSD 840 EVO 120GB size: 111.79 GiB
ID-2: /dev/sdb vendor: Toshiba model: HDWE140 size: 3.64 TiB
ID-3: /dev/sdg vendor: SanDisk model: USB 3.2Gen1 size: 57.3 GiB type: USB
ID-4: /dev/sdh vendor: Seagate model: ST32000641AS size: 1.82 TiB
ID-5: /dev/sdi vendor: SanDisk model: SDSSDA120G size: 111.79 GiB
ID-1: / size: 107.39 GiB used: 46.83 GiB (43.6%) fs: ext4 dev: /dev/sdi3
ID-2: /boot/efi size: 188 MiB used: 6.1 MiB (3.2%) fs: vfat dev: /dev/sdi2
ID-1: swap-1 type: partition size: 1.93 GiB used: 0 KiB (0.0%)
dev: /dev/sdi4
System Temperatures: cpu: 36.0 C mobo: 32.0 C gpu: nvidia temp: 37 C
Fan Speeds (rpm): fan-1: 996 fan-2: 2089 fan-3: 0 fan-4: 0 fan-5: 0
gpu: nvidia fan: 25%
Power: 12v: N/A 5v: N/A 3.3v: 3.30 vbat: 3.36
Memory: total: 16 GiB available: 15.53 GiB used: 3.48 GiB (22.4%)
Processes: 428 Uptime: 4m Init: systemd target: graphical (5)
Packages: 2906 Compilers: gcc: 13.2.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
habe mir von PlayonLinux die aktuellste Sw herunter geladen.
Lt- Hinweis von PC-Welt https://www.pcwelt.de/article/115242…sierung-co.html "Nach dem Aufruf vom Playonlinux klicken Sie im Menü auf „Datei –› Installieren“. Sie sehen Kategorien wie „Grafik“ und „Office“, über die Sie zu den Programmlisten gelangen."
Und genau diese Kategorien sehe ich nicht. Aus der Anwendungsverwaltung von Mint Cinnamon hatte ich vorher beide Versionen von PlayonLinux wechselseitig angeschaut. Hier das gleiche Problem.
Was mache ich falsch?
Gruß DreyDee
