Fedora 41 KDE system monitor brint ganzes system zum absturz
    Fedora
    Kernel: 6.11.5-300.fc41.x86_64 arch: x86_64 bits: 64 compiler: gcc
    v: 2.43.1-2.fc41
    Desktop: KDE Plasma v: 6.2.2 Distro: Fedora Linux 41 (KDE Plasma)
    Type: Desktop Mobo: ASUSTeK model: PRIME B450M-A v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 3002
    date: 03/10/2021
    Battery:
    Device-1: hidpp_battery_0 model: Logitech MX Vertical Advanced Ergonomic
    Mouse charge: 55% (should be ignored) status: discharging
    Info: 6-core model: AMD Ryzen 5 3600X bits: 64 type: MT MCP arch: Zen 2
    rev: 0 cache: L1: 384 KiB L2: 3 MiB L3: 32 MiB
    Speed (MHz): avg: 2200 min/max: 2200/4275 boost: enabled cores: 1: 2200
    2: 2200 3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200
    11: 2200 12: 2200 bogomips: 102599
    Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti] vendor: ASUSTeK driver: nvidia
    v: 560.35.03 arch: Ampere bus-ID: 09:00.0
    Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_wayland driver: X: loaded: nvidia unloaded: modesetting
    gpu: nvidia resolution: 2560x1440
    API: EGL v: 1.5 drivers: nvidia,swrast platforms:
    active: gbm,wayland,x11,surfaceless,device inactive: device-1
    API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 560.35.03
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
    API: Vulkan v: 1.3.296 drivers: N/A surfaces: xcb,xlib,wayland devices: 2
    Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 09:00.1
    Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio
    vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 0b:00.4
    Device-3: Generalplus USB Audio Device
    driver: hid-generic,snd-usb-audio,usbhid type: USB bus-ID: 3-2:2
    API: ALSA v: k6.11.5-300.fc41.x86_64 status: kernel-api
    Server-1: PipeWire v: 1.2.6 status: active
    vendor: ASUSTeK RTL8111H driver: r8169 v: kernel port: f000 bus-ID: 08:00.0
    IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
    Device-2: Microsoft Xbox Wireless Adapter for Windows driver: mt76x2u
    type: USB bus-ID: 3-4:4
    IF: wlp11s0f3u4 state: down mac: <filter>
    Bluetooth:
    Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB bus-ID: 1-3:2
    Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.1
    lmp-v: 10
    Local Storage: total: 2.37 TiB used: 246.03 GiB (10.1%)
    ID-1: /dev/nvme0n1 vendor: Crucial model: CT2000P3SSD8 size: 1.82 TiB
    temp: 44.9 C
    ID-2: /dev/sda vendor: Kingston model: SA400S37480G size: 447.13 GiB
    ID-3: /dev/sdb vendor: SanDisk model: Ultra size: 115.69 GiB type: USB
    ID-1: / size: 1.27 TiB used: 214.21 GiB (16.5%) fs: btrfs
    dev: /dev/nvme0n1p6
    ID-2: /boot size: 973.4 MiB used: 345 MiB (35.4%) fs: ext4
    dev: /dev/nvme0n1p5
    ID-3: /boot/efi size: 96 MiB used: 44.6 MiB (46.4%) fs: vfat
    dev: /dev/nvme0n1p1
    ID-4: /home size: 1.27 TiB used: 214.21 GiB (16.5%) fs: btrfs
    dev: /dev/nvme0n1p6
    ID-1: swap-1 type: zram size: 8 GiB used: 0 KiB (0.0%) dev: /dev/zram0
    System Temperatures: cpu: 50.2 C mobo: N/A
    Fan Speeds (rpm): N/A
    Memory: total: 32 GiB available: 31.25 GiB used: 2.72 GiB (8.7%)
    Processes: 419 Uptime: 2m Init: systemd target: graphical (5)
    Packages: 13 note: see --rpm Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.32
    inxi: 3.3.36
    Sobald ich im system monito bin ,und diesen anpassen will, wie einen sensor für eine hardware hinzufügen, stürzt doeser ab, udn ich bekomme iene fehlermeldung. dann ist es aber auch oft so, dass dann das ganze system einfriert, und ich dann einen hard reset machen muss also den power knopf für 5 sekunden gedrückt halten. (ist glaube ich für die komponenten nicht das angenehmste so ausgeschaltet zu werden)
  • Schau mal in deinen Einstellungen nach, ob du unter Anzeige & Bildschirm den adaptiven Abgleich auf niemals gesetzt hast. Wen nicht mach das mal, war bei mir unter KDE und AMD ein Riesen-Problem. Nach der Einstellung hat alles wieder funktioniert!
    Ist auch hauptsächlich ein Wayland Problem, da Fedora glaube ich kein X11 mehr nutzt.
    Gruß Dieter
  • diese fehlermeldung bekomme ich immer und das adaptive abgleich auf niemals hat auch ncihts gebracht
    diese fehlermeldung ploppt sogar 3 mal hintereinander auf.
    sheinbar hat ein sudi dnf upgrade wohl das problem gelöst sodass das system monitr wieder ganz normal funktioniert
