Mint Installation auf separatem HDD
    Linux Mint
    Kernel: 6.8.0-38-generic arch: x86_64 bits: 64 compiler: gcc v: 13.2.0
    Desktop: Cinnamon v: 6.2.7 Distro: Linux Mint 22 Wilma
    base: Ubuntu 24.04 noble
    Type: Desktop Mobo: ASRock model: B85M Pro4 serial: <superuser required>
    BIOS: American Megatrends v: P1.90 date: 12/06/2013
    Battery:
    Device-1: hidpp_battery_0 model: Logitech K850 Performance Wireless Keyboard
    charge: 100% (should be ignored) status: discharging
    Info: quad core model: Intel Core i7-4770K bits: 64 type: MT MCP
    arch: Haswell rev: 3 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
    Speed (MHz): avg: 1012 high: 1700 min/max: 800/3900 cores: 1: 835 2: 1389
    3: 800 4: 800 5: 954 6: 800 7: 825 8: 1700 bogomips: 55988
    Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: eVga.com.
    driver: nouveau v: kernel arch: Pascal bus-ID: 01:00.0 temp: 51.0 C
    Device-2: ARC Camera driver: snd-usb-audio,uvcvideo type: USB
    bus-ID: 3-11.2:8
    loaded: modesetting unloaded: fbdev,vesa dri: nouveau gpu: nouveau
    resolution: 1: 3440x1440~60Hz 2: 1920x1200~60Hz
    API: EGL v: 1.5 drivers: nouveau,swrast platforms:
    API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 24.0.9-0ubuntu0.1
    glx-v: 1.4 direct-render: yes renderer: NV136
    Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASRock 8
    Device-2: NVIDIA GP106 High Definition Audio vendor: eVga.com.
    Device-3: ARC Camera driver: snd-usb-audio,uvcvideo type: USB
    bus-ID: 3-11.2:8
    API: ALSA v: k6.8.0-38-generic status: kernel-api
    Device-1: Intel Ethernet I217-V vendor: ASRock driver: e1000e v: kernel
    port: f040 bus-ID: 00:19.0
    IF: enp0s25 state: up speed: 1000 Mbps duplex: full mac: <filter>
    Local Storage: total: 2.28 TiB used: 12.06 GiB (0.5%)
    ID-1: /dev/sda vendor: Western Digital model: WD10EZEX-60ZF5A0
    ID-2: /dev/sdb vendor: Western Digital model: WD10EZRX-00A8LB0
    ID-3: /dev/sdc vendor: Samsung model: HM500JI size: 465.76 GiB
    ID-4: /dev/sde vendor: Intenso model: Alu Line size: 7.28 GiB type: USB
    ID-1: / size: 11.7 GiB used: 156.5 MiB (1.3%) fs: overlay source: ERR-102
    System Temperatures: cpu: 31.0 C mobo: N/A gpu: nouveau temp: 51.0 C
    Fan Speeds (rpm): N/A gpu: nouveau fan: 0
    Memory: total: 24 GiB available: 23.39 GiB used: 2.1 GiB (9.0%)
    Processes: 293 Uptime: 22m Init: systemd target: graphical (5)
    Packages: 1992 Compilers: gcc: 13.2.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
    Hallo.
    Ich mache erste Gehversuche und möchte Mint mal ausführlich testen, weil ich überhaupt gar keine Lust habe, meinen bisher hervorragend funktionirenden PC demnächst zu verschrotten nur wegen Windows11. Ich möchte es daher installieren und mal aktiv verwenden um zu sehen ob das passt. Eine Installation auf einem alten, fast 20 Jahre alten PC mit einer Festplatte hat zwar gut funktioniert, ergibt aber keinen Sinn, da die CPU viel zu schwach ist, alles sehr langsam und vieles Läuft nicht, so kann ich nichts testen. Eine Alternatie habe ich gerade nicht, daher habe ich mich nun dazu entschieden, meinen aktuellen PC zu verwenden. Die reguläre 500GB SSD mit meinem Windows 10 habe ich vorher angeklemmt, dafür eine ältere 2,5" Samsung 500GB HDD angeklemmt [dev/sdc].
    Die Idee war, darauf das Mint zu installieren, und danach die SSD wieder anzuschließen, so dass ich zwei Platten mit zwei bootfähigen OS habe und im Boot-Menü des BIOS einfach das zu startende System auswählen kann. Parallel befinden sich noch zwei 1TB WD Platten als reine Datenspeicher im Gerät, die ich einfach ignoriere (auf einer davon ist noch irgendeinnicht mehr funktionierendes uralt Windows drauf).
    Gesagt getan, vom USB Stick das live/Demo System gestartet, die Installation lief easy durch, ich habe es im "Automatik" Betrieb gemacht und das System die gesamte Platte verwenden lassen, ohne irgendwas manuell einzustellen oder zu partitionieren. Es kam die Fragem ob die anderen Patten ein oder ausgehängt werden sollen, habe ich verweigert, weil die m.E. hierfür uninteressant sind. Nach dem ersten Neustart finde ich aber verwirrenderweise sowohl im BIOS als auch im Bootmenü gleich zwei Einträge:
    - Ubuntu
    - Bezeichnung der 500 GB HDD
    Und beide funktionieren nicht. Ich erhalte gleich zu Beginn Fehlermeldungen, soll was bootbares einlegen und neu starten.
    Woran kann das liegen? Habe ich hier was falsch gemacht?
    Kann das evtl. an der HDD liegen? In Mint unter Disks wird in rot angezeigt: DISK IS LIKELY TO FAIL SOON (29°C/88°F)
    PS: die Terminal Ausgaben stammen aus dem jetzt wieder gestarteten live System - ich sehehier für die 500GB Samsung Disk, dass dort zwei Partitionen angelegt wurden:
    -sdc1 537 MB FAT Typ EFI System
    -sdc2 500 GB Typ Linux Filesystem
    -1,1 MB Free Space
    Bringt es etwas, das Ganze zu wiederholen?
    Viele Grüße
  • Gesagt getan, vom USB Stick das live/Demo System gestartet, die Installation lief easy durch, ich habe es im "Automatik" Betrieb gemacht und das System die gesamte Platte verwenden lassen, ohne irgendwas manuell einzustellen oder zu partitionieren. Es kam die Fragem ob die anderen Patten ein oder ausgehängt werden sollen, habe ich verweigert, weil die m.E. hierfür uninteressant sind. Nach dem ersten Neustart finde ich aber verwirrenderweise sowohl im BIOS als auch im Bootmenü gleich zwei Einträge:
    - Ubuntu
    Bootet denn die Platte wenn du sie alleine dran hängen hast so wie du instlliert hast? Evtl. bekommt die Platte nach dem anstecken der anderen einen neuen Bezeichner (als /dev/sda installiert, nun wieder /dev/sdc oder so was). Was ist in der /etc/fstab eingetragen, das Device (z.B. /dev/sda) oder die UUID?
  • Hallo Gerbil
    Ich habe seit der Installation ja nichts verändert. Während der Installation waren meine beiden WD Platten dran und die Ziel Platte für mint. Danach gebootet.
    Die Boot Option Ubuntu bringt diesen Fehler: „unexpected return from initial read: device error buffersize 0, failed to load image: device error, start_image() returned device error.“
    Die option Samsung HM500JI liefert den Fehler: „Reboot and Select proper Boot device or insert Boot Media in selected Boot device and press a key“.
    Das heißt es bootet gar nichts, es sei denn ich starte wieder direkt vom Mint USB Stick, was mir ja nichts bringt.
    Meine windows 10 Platte habe ich noch nicht wieder angeschlossen.
    Edited once, last by jamaica2912 (November 3, 2024 at 3:39 PM).
  • Meine windows 10 Platte habe ich noch nicht wieder angeschlossen.
    Ah, das war mir nicht klar. Das heißt, direkt nach der Installation bootet er nicht von der Linuxplatte?! Hattest du den Grub auf die Platte schreiben lassen? Vielleicht hat jemand anders noch eine Idee.
  • Ah, das war mir nicht klar. Das heißt, direkt nach der Installation bootet er nicht von der Linuxplatte?! Hattest du den Grub auf die Platte schreiben lassen? Vielleicht hat jemand anders noch eine Idee.
    ja genau, direkt der erste neustart scheiterte mit o.g. Fehlern.
    sieh es mir nach, ich bin neu, ich weiss nicht was der grub ist(*) und ich wurde auch nicht gefragt ob ich das tun möchte oder nicht, habe einfach die standard installation laufen lassen.
    * hier steht was es ist :D aber wie gesagt, hab mich nicht darum gekümmert und die tatsache dass da neue EInträge im BootMenü auftauchen spricht ja eigentlich dafür
  • Habe jetzt nicht noch mal alles durchgelesen - aber wahrscheinlich ist die UEFI-Partition auf der Windows-Platte?
  • ich habe es im "Automatik" Betrieb gemacht und das System die gesamte Platte verwenden lassen, ohne irgendwas manuell einzustellen oder zu partitionieren.
    Ich kann mir unter Automatik gerade nichts vorstellen. Meinst du den Punkt Erase Disk and install Linux Mint, also den hier in diesem Bild: https://linuxmint-installation-guide.readthedocs.io/en/latest/_ima…ler-install.png? Und dein Bootmenü, welches du siehst, sieht in etwa so aus: https://www.fosslinux.com/wp-content/upl…ub-in-Linux.png? Also es taucht der Name GRUB auf? Frage nur, um sicher zu gehen.
    In der offiziellen Dokumentation steht gibt es ein Punkt Troubleshooting: https://linuxmint-installation-guide.readthedocs.io/en/latest/efi.html#efi-boot-order. Vielleicht kommst du damit weiter?
    Möglich, kann man so pauschal nicht sagen. Da du ja neu beginnst, verlierst du auch nicht wirklich Einstellungen und Daten.
    Es sei Euch Glück und Freude beschieden, auf dass der Tag Euch hold sei.
    Beim Neustart komme ich in eine/die "moderne" grafische Oberfläche mit allen Grundeinstellungen wie Storage Konfig, RAM, Bootreihenfolgen etc. wie gewohnt. Auch wenn die Windows Platte ausgebaut ist.
  • Ja das ist der Dialog den ich meinte, ich hatte Option 1 gewählt und alles auf die eingehängte Platte "geballert".
    Nein, was ich hier meinte ist was anderes. Ich sehe kein Grub, ich drücke beim Hochfahren F11 und erhalte dann eine Liste der bootbaren Geräte. Dort erhalte ich o.g. Optionen, die nicht funktionieren.
    Danke, schaue ich mir an.
  • In der offiziellen Dokumentation steht gibt es ein Punkt Troubleshooting: https://linuxmint-installation-guide.readthedocs.io/en/latest/efi.html#efi-boot-order. Vielleicht kommst du damit weiter?
    Also meine Boot-Einstellungen sehen deutlich anders aus als in der genannten Anleitung im Beispiel nicht so, sagen wir, übersichtlich. Keine Ahnung was das für Zahelkolonnen sind. Hier findet sich auf dieser misteryöse "ubuntu" Eintrag wieder, der nicht funktioniert.
    mint@mint:~$ sudo efibootmgr
    BootCurrent: 000B
    Timeout: 10 seconds
    BootOrder: 0008,000B,000A,0001,0000
    Boot0000  Ubuntu	HD(1,GPT,699e1a91-fcbb-43f2-a0fe-d33bf44fa704,0x800,0x100000)/File(\EFI\ubuntu\shimx64.efi)
    Boot0001* Hard Drive 	BBS(HD,,0x0)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
    Boot0008* USB 	BBS(USB,,0x0)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
    Boot000A* CD/DVD Drive 	BBS(CDROM,,0x0)0000474f00004e4fb3000000010000006f0048004c002d00440054002d00530054002000440056004400520041004d00200047004800320034004e0053003900350000000501090003000000007fff040002010c00d041030a0000000001010600021f03120a000400ffff00007fff040001043e00ef47642dc93ba041ac194d51d01b4ce644004b00440034004c00310034004b0035003700200032002000200020002000200020002000200000007fff04000000424f
    Boot000B* UEFI: Intenso Alu Line 8.07	PciRoot(0x0)/Pci(0x1a,0x0)/USB(1,0)/USB(6,0)/HD(1,MBR,0x7629b1,0x800,0xe8c7d8)0000424f
    Ich gehe da jetzt mal nicht ran, weil es im Prinzip dem entspricht, was ich zuletzt im UEFI eingestellt hatte und werde die Installation stattdessen einmal wiederholen. Mal schaun.
  • So, Installation wiederholt, Option "ganze Festplatte" verwendet und installiert. Danach, siehe da, bin ich wohl einen Schritt weiter, Mint startet von der Platte. Leider aber nicht zu Ende. Es präsentiert relativ früh folgende Fehlermeldung:
    "Cannot find TOCBLOCK, database maybe corrupt", dann gaanz kurz irgendein roter Error, danach erscheint ein schwarzer Bildschirm und einfach gar nichts passiert dann mehr.
    Schade ||
  • Ich habs hinbekommen.
    Der Schlüssel war einfach die Installationsoption "Neben Windows installieren" zu benutzen, vor der ich vorher zu viel Schiss hatte und deswegen was anderes getan hatte (ganze Festplatte).
    Das hat nun geklappt und Mint läuft.
    Der komische "Cannot find TOCBLOCK, database maybe corrupt" Fehler kommt zwar trotzdem noch kurz, aber dann startet das System.
    Ich freue mich.
  • Noch benutzerfreundlicher empfinde ich die Nutzung von Windows To Go, welches ich wie folgt eingerichtet habe:
    • Verwendung einer externen SSD mit 256 GB Speicherkapazität
    • Installation von Windows auf der internen Festplatte des Computers
    • Herunterladen einer Windows 10/11 ISO-Datei direkt von der offiziellen Microsoft-Website.
    • Einsatz des Tools „Rufus“ zur Einrichtung
    In Rufus wurden die folgenden Optionen ausgewählt: ISO-Datei, MBR-Partitionsschema, Unterstützung für BIOS und UEFI, sowie der Modus „Windows To Go“. Nach der Bestätigung war der Prozess in weniger als drei Minuten abgeschlossen, wodurch auf der externen SSD ein voll funktionsfähiges Windows-Betriebssystem installiert ist.
    Durch diese Vorgehensweise erhält man zwei separate und unabhängig voneinander operierende Systeme, ohne komplizierte Konfiguration.
    Brauche ich nun Windows, dann schließe ich die externe Festplatte an und bei booten drücke ich, in meinem Fall ein Thinkpad t480, die F12 Taste um in das Boot Menü zu kommen und wähle dort die externe Festplatte mit Windows aus. Fertig.
    Warum das ganz? Ganz einfach. Damit ich alte Spiele spielen kann und vorallem Forscan zum Auslesen und programmieren von Ford Modellen.
