- inxi -Fzxi
Kernel: 6.11.0-9-generic arch: x86_64 bits: 64 compiler: gcc v: 14.2.0
Desktop: GNOME v: 47.0 Distro: Ubuntu 24.10 (Oracular Oriole)
Type: Desktop System: Micro-Star product: MS-7C35 v: 1.0
serial: <superuser required>
Mobo: Micro-Star model: MEG X570 ACE (MS-7C35) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.O0
date: 03/29/2024
Battery:
Device-1: hidpp_battery_0 model: Logitech MX Vertical Advanced Ergonomic
Mouse charge: 55% (should be ignored) status: discharging
Info: 16-core model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3+
rev: 0 cache: L1: 1024 KiB L2: 8 MiB L3: 64 MiB
Speed (MHz): avg: 2385 high: 3950 min/max: 550/5907 boost: enabled cores:
1: 2025 2: 3950 3: 3950 4: 2025 5: 2025 6: 2025 7: 2025 8: 2025 9: 2025
10: 3950 11: 2025 12: 2025 13: 2025 14: 3948 15: 2025 16: 3943 17: 2025
18: 2025 19: 2025 20: 2025 21: 2025 22: 2025 23: 2025 24: 2025 25: 2025
26: 2025 27: 2025 28: 2025 29: 3949 30: 2025 31: 2025 32: 2025
bogomips: 252803
Device-1: NVIDIA GA102 [GeForce RTX 3090] vendor: Micro-Star MSI
driver: nvidia v: 560.35.03 arch: Ampere bus-ID: 2d:00.0
Device-2: MacroSilicon USB Video
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB bus-ID: 5-4:2
Display: wayland server: X.Org v: 24.1.2 with: Xwayland v: 24.1.2
compositor: gnome-shell driver: gpu: nvidia,nvidia-nvswitch resolution:
1: 3072x1728~60Hz 2: 1920x1080~60Hz
API: EGL v: 1.5 drivers: nvidia,swrast platforms:
active: gbm,wayland,x11,surfaceless,device inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 560.35.03
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3090/PCIe/SSE2
Device-1: NVIDIA GA102 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 2d:00.1
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 2f:00.4
Device-3: Elgato Systems GmbH Wave:1 driver: snd-usb-audio type: USB
bus-ID: 1-6:8
Device-4: MacroSilicon USB Video
API: ALSA v: k6.11.0-9-generic status: kernel-api
Server-1: PipeWire v: 1.2.4 status: active
Device-1: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb
v: kernel port: e000 bus-ID: 26:00.0
IF: enp38s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IP v6: <filter> virtual: proto kernel_ll scope: link
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel port: d000 bus-ID: 27:00.0
IF: enp39s0 state: down mac: <filter>
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 28:00.0
IF: wlo1 state: down mac: <filter>
Bluetooth:
Device-1: Intel AX200 Bluetooth driver: btusb v: 0.8 type: USB bus-ID: 1-4:5
Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
lmp-v: 11
Local Storage: total: 1.86 TiB used: 15.15 GiB (0.8%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVL22T0HBLB-00B00
size: 1.86 TiB temp: 42.9 C
ID-1: / size: 325.96 GiB used: 9.42 GiB (2.9%) fs: btrfs dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 1.05 GiB used: 6.1 MiB (0.6%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 1.54 TiB used: 5.73 GiB (0.4%) fs: btrfs
dev: /dev/nvme0n1p3
System Temperatures: cpu: 39.4 C mobo: 33.5 C
Fan Speeds (rpm): N/A
Memory: total: 32 GiB available: 30.26 GiB used: 4.62 GiB (15.3%)
Processes: 553 Uptime: 39m Init: systemd target: graphical (5)
Packages: 2109 Compilers: N/A Shell: Bash v: 5.2.32 inxi: 3.3.35
Hallöchen,
Gestern hatte ich echt mein erstes richtiges GNU/Linux ( ja ich habe mich weiter gebildet ^^) WOW Erlebnis.
Ich habe mal zum testen Cachyos auf meinem Hauptsystem installiert und WOW.
Was für eine Geschwindigkeit, alles läuft so flüssig, so schnell, sogar die Browser arbeiten finde ich dort schneller.
Eigentlich genau das was ich mir beim Wechsel von Windows auf Linux Mint / Ubuntu erwartet hatte.
Mir war auch immer so als würde sich Windows sogar schneller anfühlen als Mint und Ubuntu.
Und heute wieder Ubuntu 24.10 rauf getan und alles ist so langsam träge. Genau wie Linux Mint bei mir.
Nur zur Klarstellung, wir reden vom dem Zustand nach der Installation und ein zwei Programme die aber nicht im Hintergrund laufen.
Alles auf dem gleichen PC, sogar die gleiche NVME, weil die ist zum Testen da.
Kann es sein das Debian und dessen Derivate einfach langsamer ist als Arch Linux?
Ich würde ja gerne bei Cachyos bleiben, aber Arch ist mir schon 2 Nummern zu hoch und es gibt keine Shop,
alle Programme die ich nutze haben nur rpm oder deb Dateien zum runter laden.
Und vom Arch reporsitorium (keine Ahnung wie man das schreibt) wird so oft gewarnt, das ich mich da nicht ran traue.
Bilde ich mir das vielleicht auch nur ein, okay daran glaub ich eigentlich nicht, weil ich gestern bei der F1 Übertragung vom PC weg gegangen bin und
wieder zum TV gegangen bin weil das Bild nicht flüssig lief hier im Firefox Browser unter Ubuntu. Was mir bei Linux Mint auch schon auf fiel aber nicht so
arg wie jetzt unter Ubuntu. Jetzt könnte man noch sagen das Ubuntu 24.10 ja neu ist und da noch Fehler drinnen sein können, aber unter 24.04 fühlte
es sich nicht anders an. Weswegen ich eigentlich die ganze Hobbserei überhaupt mache.
Ich finde sogar das Fedora sich schneller anfühlt als Debian Derivate nur nicht so startk, aber bei Fedora scheitere ich an den ganzen Codes für
Multimedia und Bildern, zig Seiten durchgegangen überall toll erklärt, aber nix ging. Immer andere Fehlermeldungen.
Warum die Lizenzprobleme beim Implementieren damit haben und Ubuntu, Nobara und co. nicht versteh ich überhaupt nicht.
Mich würde jetzt echt gerne eure Meinung dazu Interessieren, vor allem weiß ich ja von einigen die schon fast alles Durch haben.
Vielleicht bin ich nur auch ein wenig Verrückt
BG Anda
