- Distrowahl
- EndeavourOS
- System:
Kernel: 6.11.4-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
Desktop: KDE Plasma v: 6.2.1 Distro: EndeavourOS base: Arch Linux
Type: Laptop System: LENOVO product: 20T3S24C35 v: ThinkPad X13 Gen 1
serial: <superuser required>
Mobo: LENOVO model: 20T3S24C35 v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: N2YET26W (1.15 )
date: 12/10/2020
Battery:
ID-1: BAT0 charge: 40.3 Wh (92.2%) condition: 43.7/48.0 Wh (91.0%)
volts: 12.4 min: 11.5 model: Sunwoda 5B10W13926 status: discharging
Info: quad core model: Intel Core i5-10310U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check rev: C cache: L1: 256 KiB L2: 1024 KiB
L3: 6 MiB
Speed (MHz): avg: 800 min/max: 400/4400 cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 bogomips: 35210
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Lenovo driver: i915
v: kernel arch: Gen-9.5 bus-ID: 00:02.0
Device-2: Lite-On Integrated Camera driver: uvcvideo type: USB
bus-ID: 1-8:2
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.3
compositor: kwin_wayland driver: X: loaded: modesetting dri: iris gpu: i915
resolution: 1920x1080
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
API: Vulkan Message: No Vulkan data available.
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Lenovo
driver: sof-audio-pci-intel-cnl bus-ID: 00:1f.3
API: ALSA v: k6.11.4-arch1-1 status: kernel-api
Server-1: PipeWire v: 1.2.5 status: active
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3
IF: wlan0 state: up mac: <filter>
Device-2: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6
IF: enp0s31f6 state: down mac: <filter>
Bluetooth:
Device-1: Intel AX201 Bluetooth driver: btusb v: 0.8 type: USB
bus-ID: 1-10:4
Report: btmgmt ID: hci0 rfk-id: 3 state: up address: <filter> bt-v: 5.2
lmp-v: 11
Local Storage: total: 238.47 GiB used: 16.66 GiB (7.0%)
ID-1: /dev/nvme0n1 vendor: Micron model: MTFDHBA256TDV size: 238.47 GiB
temp: 31.9 C
ID-1: / size: 220.67 GiB used: 16.57 GiB (7.5%) fs: btrfs dev: /dev/dm-0
mapped: luks-36dd8658-1490-4531-9947-beda43b4d0a0
ID-2: /home size: 220.67 GiB used: 16.57 GiB (7.5%) fs: btrfs
dev: /dev/dm-0 mapped: luks-36dd8658-1490-4531-9947-beda43b4d0a0
ID-3: /var/log size: 220.67 GiB used: 16.57 GiB (7.5%) fs: btrfs
ID-1: swap-1 type: partition size: 16.76 GiB used: 0 KiB (0.0%)
dev: /dev/dm-1 mapped: luks-76ddaf6f-e88a-4d7d-80aa-648d0d5558ef
System Temperatures: cpu: 39.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 16 GiB note: est. available: 15.25 GiB used: 3.41 GiB (22.3%)
Processes: 293 Uptime: 5m Init: systemd
Packages: 1089 Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.37 inxi: 3.3.36
Hallo zusammen,
ich habe einmal eine Frage, wo ich nach suchen (in den letzten zwei Stunden) nicht das gefunden habe, was ich so wollte.
In einem anderen Topic erwähnte ich, dass ich mal über den Tellerrand schauen möchte und von Debian und Ubuntu in die Richtung "Arch" gehen und mir das auch mal anschauen möchte. Es ist nicht ganz Arch, sondern ein EOS. Wenn ich das System vom USB Stick starte um es zu installieren, kann ich bedenkenlos WLAN und auch mein Bluetooth Gerät (MX Anywhere 2) verbinden.
Dann habe ich das System mit KDE-Plasma installiert, der Installer ist echt toll und all das was ich z.B. bei der Partitionierung wollte, klappte auf Anhieb. Vielen Dank an das Endeavour Team!
Interessant ist allerdings, bei dem jetzt frisch installierten System, benimmt sich Bluetooth doch sehr komisch. Ja, über die Konsole habe ich den Dienst via "enable" aktiviert. Wenn ich "bluetoothctl" ausführe, findet er mein Maus nicht und wenn ich über die GUI da hin gehe, sehe ich erst meine Bluetooth Geräte und nach 20 Sekunden gar nichts mehr. Ich muss Bluetooth aus und wieder einschalten (ein, zwei oder drei mal) und dann sehe ich die Maus und die Verbindung klappt dann wieder.
Habt ihr das auch, oder muss ich noch etwas ändern in meinen Einstellungen?
Bestes Beispiel, ich nehme meine Maus, schalte sie aus, dann schalte ich sie an, schon muss ich Bluetooth aus und wieder einschalten, damit die Maus gefunden und verbunden wird.
Gruß, Domi
