- Distrowahl
- Linux Mint
- [code]
Kernel: 6.8.0-45-generic arch: x86_64 bits: 64 compiler: gcc v: 13.2.0 clocksource: tsc
Desktop: Cinnamon v: 6.2.9 tk: GTK v: 3.24.41 wm: Muffin v: 6.2.0 vt: 7 dm: LightDM v: 1.30.0
Distro: Linux Mint 22 Wilma base: Ubuntu 24.04 noble
Type: Laptop System: Micro-Star product: GX780/GT780/GT780DX/GT783 v: N/A
serial: <superuser required> Chassis: Micro-Star International type: 10
Mobo: Micro-Star model: MS-1761 serial: <superuser required> uuid: <superuser required>
BIOS: American Megatrends v: E1761IMS V1.0H date: 11/18/2011
Battery:
ID-1: BAT1 charge: 47.2 Wh (100.0%) condition: 47.2/86.6 Wh (54.5%) volts: 12.5 min: 11.1
model: MS-1761 type: Unknown serial: N/A status: full
Info: quad core model: Intel Core i7-2670QM bits: 64 type: MT MCP smt: enabled arch: Sandy Bridge
rev: 7 cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
Speed (MHz): avg: 2322 high: 2900 min/max: 800/3100 cores: 1: 2900 2: 2794 3: 800 4: 2794
5: 800 6: 2900 7: 2794 8: 2794 bogomips: 35119
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: NVIDIA GF114M [GeForce GTX 570M] vendor: Micro-Star MSI driver: nouveau v: kernel
arch: Fermi pcie: speed: 5 GT/s lanes: 16 ports: active: HDMI-A-1,LVDS-1 empty: VGA-1
bus-ID: 01:00.0 chip-ID: 10de:1210 class-ID: 0300 temp: 43.0 C
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X: loaded: modesetting
unloaded: fbdev,vesa dri: nouveau gpu: nouveau display-ID: :0 screens: 1
Screen-1: 0 s-res: 3968x1152 s-dpi: 96 s-size: 1050x305mm (41.34x12.01")
s-diag: 1093mm (43.05")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: right model: Acer ED323QUR res: 2048x1152 hz: 60
dpi: 75 size: 697x392mm (27.44x15.43") diag: 800mm (31.5") modes: max: 1856x1392 min: 720x400
Monitor-2: LVDS-1 pos: primary,left model: Chi Mei Opto 0x1720 res: 1920x1080 hz: 60 dpi: 128
size: 382x215mm (15.04x8.46") diag: 438mm (17.3") modes: max: 1920x1080 min: 640x350
API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau device: 1 drv: swrast
gbm: drv: nouveau surfaceless: drv: nouveau x11: drv: nouveau inactive: wayland
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 24.0.9-0ubuntu0.1 glx-v: 1.4
direct-render: yes renderer: NVCE device-ID: 10de:1210
Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: Micro-Star MSI 6
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20 class-ID: 0403
Device-2: NVIDIA GF114 HDMI Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie:
speed: 5 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0e0c class-ID: 0403
API: ALSA v: k6.8.0-45-generic status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse status: active
2: wireplumber status: active 3: pipewire-alsa type: plugin
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
RTL8111/8168/8411 driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Centrino Wireless-N 130 driver: iwlwifi v: kernel pcie: speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:0896 class-ID: 0280
IF: wlp3s0 state: down mac: <filter>
Local Storage: total: 1.19 TiB used: 588.23 GiB (48.5%)
ID-1: /dev/sda vendor: Western Digital model: WD10JPLX-00MBPT0 size: 931.51 GiB speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: 1H01 scheme: MBR
ID-2: /dev/sdb vendor: Kingston model: SV300S37A240G size: 223.57 GiB speed: 6.0 Gb/s tech: SSD
serial: <filter> fw-rev: UA scheme: GPT
ID-3: /dev/sdc vendor: Intenso model: Ultra Line size: 58.59 GiB type: USB rev: 2.1
spd: 480 Mb/s lanes: 1 tech: N/A serial: <filter> fw-rev: 0009 scheme: MBR
ID-1: / size: 218.36 GiB used: 56.24 GiB (25.8%) fs: ext4 dev: /dev/sdb3
ID-2: /boot/efi size: 570.8 MiB used: 6.1 MiB (1.1%) fs: vfat dev: /dev/sdb2
ID-1: swap-1 type: file size: 2 GiB used: 23 MiB (1.1%) priority: -2 file: /swapfile
USB:
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s lanes: 1
chip-ID: 1d6b:0002 class-ID: 0900
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0 speed: 480 Mb/s
lanes: 1 chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.5:3 info: Logitech Cordless Mouse type: mouse driver: hid-generic,usbhid
interfaces: 1 rev: 1.1 speed: 1.5 Mb/s lanes: 1 power: 50mA chip-ID: 046d:c510 class-ID: 0301
Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s lanes: 1
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0 speed: 480 Mb/s
Device-1: 2-1.2:3 info: Realtek RTS5139 Card Reader Controller type: <vendor specific>
driver: rtsx_usb,rtsx_usb_ms,rtsx_usb_sdmmc interfaces: 1 rev: 2.0 speed: 480 Mb/s lanes: 1
power: 500mA chip-ID: 0bda:0139 class-ID: ff00 serial: <filter>
Device-2: 2-1.3:4 info: Innostor IS918 Flash Drive type: mass storage driver: usb-storage
interfaces: 1 rev: 2.1 speed: 480 Mb/s lanes: 1 power: 100mA chip-ID: 1f75:0918 class-ID: 0806
serial: <filter>
Device-3: 2-1.7:6 info: MSI steel series rgb keyboard type: HID driver: gt683r_led,usbhid
interfaces: 1 rev: 1.1 speed: 12 Mb/s lanes: 1 power: 2mA chip-ID: 1770:ff00 class-ID: 0300
serial: <filter>
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0 speed: 480 Mb/s lanes: 1
Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s lanes: 1 chip-ID: 1d6b:0003
class-ID: 0900
System Temperatures: cpu: 54.0 C mobo: N/A gpu: nouveau temp: 43.0 C
Fan Speeds (rpm): N/A
Repos:
Packages: 2211 pm: dpkg pkgs: 2193 pm: flatpak pkgs: 18
Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
1: deb http: //packages.linuxmint.com wilma main upstream import backport
2: deb http: //archive.ubuntu.com/ubuntu noble main restricted universe multiverse
3: deb http: //archive.ubuntu.com/ubuntu noble-updates main restricted universe multiverse
4: deb http: //archive.ubuntu.com/ubuntu noble-backports main restricted universe multiverse
5: deb http: //security.ubuntu.com/ubuntu/ noble-security main restricted universe multiverse
Memory: total: 8 GiB available: 7.73 GiB used: 2.72 GiB (35.1%)
Processes: 317 Power: uptime: 5h 6m states: freeze,standby,mem,disk suspend: deep wakeups: 1
hibernate: platform Init: systemd v: 255 target: graphical (5) default: graphical
Compilers: gcc: 13.2.0 Client: Unknown python3.12 client inxi: 3.3.34
[/code]
ich habe vor ein paar Tagen auf eine bestehende und gut funktionierende Linux-Mint 21.3 Partition, Mint 22 überspielt. Anscheindend habe ich einen entscheidenden Fehler gemacht, denn seit dem, startet der Rechner bzw. das Grub nicht mehr.
Es erscheint die Fehlermeldung: error: no such device (mit einer langen krytographischen Zeichenfolge danach) und die Meldung error:unknown filesystem. Ich habe zwei Festplatten im Laptop. Eine mit Win10 und eine für Linux.
Ich habe schon ein paar übliche GRUB-Reparaturversuche und Befehlsketten ausgeführt (wie auch hier im Forum beschrieben). Leider bisher ohne Erfolg.
Ich starte Linux zur Zeit über F11 während des Bootvorganges und wähle die Festplatte mit Linux direkt aus. Dann startet Linux normal. Wähle ich die Festplatte mit Windows aus, erhalte ich diese Fehlermeldung.
Nach dem, was ich bisher recherchiert habe, liegt es evtl. an veränderten Partitionsgrößen.
Hier zwei Screenshots mit Gparted als Anlage
dev/sda (Windows-Platte)
dev/sdb (Linux-Platte)
Auch wenn ich Windows seit Jahrzehnten mit Verachtung strafe, komme ich leider nicht ganz ohne aus. Für ein paar wenige Programme brauche ich das leider noch immer....
Evtl. habt ihr eine Idee oder Hilfestellung.
Ich gebe zu Bedenken, dass ich trotz aller Computeraffinität, kein Programmierer, sondern leidiger Endandwender bin, von daher bitte ich eventuelle Unzulänglichkeiten in der Beschreibung zu entschuldigen, ich liefere gerne Infos nach... ![]()
