- Distrowahl
- Linux Mint
- sascha@sascha-mint:~$ inxi -Fzxi
Kernel: 6.8.0-44-generic arch: x86_64 bits: 64 compiler: gcc v: 13.2.0
base: Ubuntu 24.04 noble
Type: Desktop Mobo: Gigabyte model: B760 GAMING X AX DDR4 v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F11d
date: 08/07/2024
Info: 14-core (6-mt/8-st) model: 13th Gen Intel Core i5-13600KF bits: 64
type: MST AMCP arch: Raptor Lake rev: 1 cache: L1: 1.2 MiB L2: 20 MiB
L3: 24 MiB
Speed (MHz): avg: 4510 high: 5110 min/max: 800/5100:3900 cores: 1: 5100
2: 5107 3: 5100 4: 5093 5: 5100 6: 5110 7: 5100 8: 5100 9: 5100 10: 5083
11: 5100 12: 5099 13: 3578 14: 3744 15: 3762 16: 3314 17: 3528 18: 3665
19: 3720 20: 3713 bogomips: 139776
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M] vendor: Gigabyte
driver: amdgpu v: kernel arch: RDNA-3 bus-ID: 03:00.0
Device-2: Razer USA Kiyo Pro driver: snd-usb-audio,uvcvideo type: USB
bus-ID: 2-3.1:5
loaded: amdgpu unloaded: fbdev,modesetting,radeon,vesa dri: radeonsi
gpu: amdgpu resolution: 1: 6144x3456~144Hz 2: 5120x2880
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: PPA glx-v: 1.4
direct-render: yes renderer: AMD Radeon RX 7900 XTX (radeonsi navi31 LLVM
15.0.7 DRM 3.57 6.8.0-44-generic)
Device-1: AMD Navi 31 HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 03:00.1
Device-2: Razer USA BlackShark V2 Pro
driver: hid-generic,snd-usb-audio,usbhid type: USB bus-ID: 1-6.2:18
Device-3: Razer USA Kiyo Pro driver: snd-usb-audio,uvcvideo type: USB
bus-ID: 2-3.1:5
API: ALSA v: k6.8.0-44-generic status: kernel-api
Device-1: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel
bus-ID: 06:00.0
IF: wlp6s0 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
port: 3000 bus-ID: 07:00.0
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth:
Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB
bus-ID: 1-6.3:20
lmp-v: 10
Local Storage: total: 8.25 TiB used: 1.25 TiB (15.2%)
ID-1: /dev/nvme0n1 model: MS200- 2TB size: 1.86 TiB temp: 38.9 C
ID-2: /dev/nvme1n1 model: MS100 - 1TB size: 953.87 GiB temp: 45.9 C
ID-3: /dev/nvme2n1 vendor: Samsung model: SSD 980 PRO 2TB size: 1.82 TiB
temp: 33.9 C
ID-4: /dev/nvme3n1 vendor: Samsung model: SSD 980 PRO 1TB size: 931.51 GiB
temp: 39.9 C
ID-5: /dev/sda vendor: Crucial model: CT1000MX500SSD1 size: 931.51 GiB
ID-6: /dev/sdb vendor: Toshiba model: HDWD220 size: 1.82 TiB
ID-1: / size: 181.83 GiB used: 119.22 GiB (65.6%) fs: ext4
dev: /dev/nvme2n1p4
ID-2: /boot/efi size: 96 MiB used: 32.5 MiB (33.9%) fs: vfat
dev: /dev/nvme1n1p1
System Temperatures: cpu: 44.0 C mobo: 30.0 C gpu: amdgpu temp: 52.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 1
Memory: total: 32 GiB available: 31.2 GiB used: 5.22 GiB (16.7%)
Processes: 488 Uptime: 11m Init: systemd target: graphical (5)
Packages: 3027 Compilers: gcc: 13.2.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Hi,
ich verfolge einige Videos von Linuxguides und das klappt eigentlich auch immer super. Da ich noch recht neu in der Welt von Linux bin lese ich eben viel und probiere auch noch recht viel aus. ![]()
Mein Problem wäre nun das... Habe in dem Guide-Video gesehen, wie man mit dem Linuxguidestool Grub anpassen kann.
https://www.youtube.com/watch?v=uW11Uu8vhqc&t=178s Der Punkt wäre ab 2:53 sichtbar.
Wenn ich "Grub" oder andere Wörter in der Toolsuche eingebe, erscheint bei mir der Punkt einfach nicht, den man auf dem Video sieht.
Hat jemand eine Idee, was ich da tun kann?
MfG
taker-`
