GRUB an UHD-Monitor anpassen?
    Linux Mint
    sascha@sascha-mint:~$ inxi -Fzxi
    Kernel: 6.8.0-44-generic arch: x86_64 bits: 64 compiler: gcc v: 13.2.0
    base: Ubuntu 24.04 noble
    Type: Desktop Mobo: Gigabyte model: B760 GAMING X AX DDR4 v: x.x
    serial: <superuser required> UEFI: American Megatrends LLC. v: F11d
    date: 08/07/2024
    Info: 14-core (6-mt/8-st) model: 13th Gen Intel Core i5-13600KF bits: 64
    type: MST AMCP arch: Raptor Lake rev: 1 cache: L1: 1.2 MiB L2: 20 MiB
    L3: 24 MiB
    Speed (MHz): avg: 4510 high: 5110 min/max: 800/5100:3900 cores: 1: 5100
    2: 5107 3: 5100 4: 5093 5: 5100 6: 5110 7: 5100 8: 5100 9: 5100 10: 5083
    11: 5100 12: 5099 13: 3578 14: 3744 15: 3762 16: 3314 17: 3528 18: 3665
    19: 3720 20: 3713 bogomips: 139776
    Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M] vendor: Gigabyte
    driver: amdgpu v: kernel arch: RDNA-3 bus-ID: 03:00.0
    Device-2: Razer USA Kiyo Pro driver: snd-usb-audio,uvcvideo type: USB
    bus-ID: 2-3.1:5
    loaded: amdgpu unloaded: fbdev,modesetting,radeon,vesa dri: radeonsi
    gpu: amdgpu resolution: 1: 6144x3456~144Hz 2: 5120x2880
    API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: PPA glx-v: 1.4
    direct-render: yes renderer: AMD Radeon RX 7900 XTX (radeonsi navi31 LLVM
    15.0.7 DRM 3.57 6.8.0-44-generic)
    Device-1: AMD Navi 31 HDMI/DP Audio driver: snd_hda_intel v: kernel
    bus-ID: 03:00.1
    Device-2: Razer USA BlackShark V2 Pro
    driver: hid-generic,snd-usb-audio,usbhid type: USB bus-ID: 1-6.2:18
    Device-3: Razer USA Kiyo Pro driver: snd-usb-audio,uvcvideo type: USB
    bus-ID: 2-3.1:5
    API: ALSA v: k6.8.0-44-generic status: kernel-api
    Device-1: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel
    bus-ID: 06:00.0
    IF: wlp6s0 state: down mac: <filter>
    Device-2: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
    port: 3000 bus-ID: 07:00.0
    IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
    Bluetooth:
    Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB
    bus-ID: 1-6.3:20
    lmp-v: 10
    Local Storage: total: 8.25 TiB used: 1.25 TiB (15.2%)
    ID-1: /dev/nvme0n1 model: MS200- 2TB size: 1.86 TiB temp: 38.9 C
    ID-2: /dev/nvme1n1 model: MS100 - 1TB size: 953.87 GiB temp: 45.9 C
    ID-3: /dev/nvme2n1 vendor: Samsung model: SSD 980 PRO 2TB size: 1.82 TiB
    temp: 33.9 C
    ID-4: /dev/nvme3n1 vendor: Samsung model: SSD 980 PRO 1TB size: 931.51 GiB
    temp: 39.9 C
    ID-5: /dev/sda vendor: Crucial model: CT1000MX500SSD1 size: 931.51 GiB
    ID-6: /dev/sdb vendor: Toshiba model: HDWD220 size: 1.82 TiB
    ID-1: / size: 181.83 GiB used: 119.22 GiB (65.6%) fs: ext4
    dev: /dev/nvme2n1p4
    ID-2: /boot/efi size: 96 MiB used: 32.5 MiB (33.9%) fs: vfat
    dev: /dev/nvme1n1p1
    System Temperatures: cpu: 44.0 C mobo: 30.0 C gpu: amdgpu temp: 52.0 C
    Fan Speeds (rpm): N/A gpu: amdgpu fan: 1
    Memory: total: 32 GiB available: 31.2 GiB used: 5.22 GiB (16.7%)
    Processes: 488 Uptime: 11m Init: systemd target: graphical (5)
    Packages: 3027 Compilers: gcc: 13.2.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
    Hi,
    ich verfolge einige Videos von Linuxguides und das klappt eigentlich auch immer super. Da ich noch recht neu in der Welt von Linux bin lese ich eben viel und probiere auch noch recht viel aus. :)
    Mein Problem wäre nun das... Habe in dem Guide-Video gesehen, wie man mit dem Linuxguidestool Grub anpassen kann.
    https://www.youtube.com/watch?v=uW11Uu8vhqc&t=178s Der Punkt wäre ab 2:53 sichtbar.
    Wenn ich "Grub" oder andere Wörter in der Toolsuche eingebe, erscheint bei mir der Punkt einfach nicht, den man auf dem Video sieht.
    Hat jemand eine Idee, was ich da tun kann?
    MfG
    taker-`
  • Go to Best Answer
  • harihegen September 17, 2024 at 7:59 AM
    Approved the thread.
    danke, das habe ich auch gefunden. Dachte ich probiere das mal mit dem Tool von Linuxguides. Fraglich ist, wieso es im Video gezeigt wird, aber ich bei mir den Eintrag gar nicht finden kann?! :(
    Wegen der Schriftgröße...so wie ich das gelesen habe, muss ich in Grub die Auflösung runterstellen, damit die Schrift größer wird, oder?
    Lg
  • Welche Installation meinst du denn genau? Habe das *.deb Paket installiert und nutze LM22.
    Sorry, bin doch noch so neu bei Linux. :D
  • Deine Installation. Sie wird wohl anders sein als im Video, allein aus dem Grund das Du andere HW hast.
    Was Du während der Installation und danach noch gemacht hast entzieht sich auch der Kenntnis.
    Also sind viele Unwägbarkeiten im Spiel.
  • Sorry - ich schaue mir grundsätzlich keine Video's an. Zeitverschwendung!
    Der Hinweis von Toadie ist doch einfach.
    Im Terminal "sudo nano /etc/default/grub" eingeben.
    Das, das da auf geht ist ein Script. Das man dann an die eigenen Bedürfnisse anpasst.
    Und wenn man fertig ist: "sudo update-grub" damit die Änderungen in Grub eingetragen werden. Fertig.
  • BITTE Finger weg von GRUB Customizer - es gibt viele Berichte das man damit mehr Schaden anrichtet als etwas Gutes!
    In Foren wo DAS hinlänglich bekannt ist wird eindringlich von der Benutzung des GRUB Customizer gewarnt!
    Wer diese Warnung missachtet steht i.d.R. alleine mit seinem Problem da!
  • Alles klar. Verstanden. :)
    Habe es auch so gemacht. Passt nun!
    Danke
    //edit: Wie kann ich hier das Thema als gelöst markieren? Ich kann meinen ersten Post nicht editieren.
  • taker-` September 19, 2024 at 12:48 AM
    Hmm okay, hatte es mal in einer VM getestet und keine Probleme gehabt. Na dann, Finger weg
  • Finger weg
    Ich bin von diesem Tool jedenfalls geheilt. ;)
    DenalB
    September 25, 2023 at 11:10 AM
  • Moin,
    habe das Problem gelöst bekommen. Die Flathub-Version ist wohl nicht auf dem aktuellsten Stand. Habe diese deinstalliert und die *.deb von der Homepage geladen. Da finde ich nun auch diese Einstellung. :)
    Lg
