- thomasm@TomsDebian1:~$ inxi -Fzxi
Kernel: 6.1.0-23-amd64 arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
Desktop: Cinnamon v: 5.6.8 Distro: Debian GNU/Linux 12 (bookworm)
Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-E GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 1407
date: 02/24/2020
Battery:
ID-1: hidpp_battery_1 charge: 75% condition: N/A volts: 4.0 min: N/A
model: Logitech G903 Wired/Wireless Gaming Mouse status: discharging
Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
charge: 55% (should be ignored) status: discharging
Info: 12-core model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2
rev: 0 cache: L1: 768 KiB L2: 6 MiB L3: 64 MiB
Speed (MHz): avg: 3624 high: 4004 min/max: 2200/4918 boost: enabled cores:
1: 4004 2: 4000 3: 3999 4: 4000 5: 2200 6: 3999 7: 3999 8: 4000 9: 4000
10: 4000 11: 4001 12: 4000 13: 2200 14: 3998 15: 3990 16: 3999 17: 4002
18: 4000 19: 2200 20: 2200 21: 2200 22: 3999 23: 4000 24: 3993
bogomips: 191978
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT]
vendor: XFX Speedster MERC 319 driver: amdgpu v: kernel arch: RDNA-2
bus-ID: 0c:00.0
Display: x11 server: X.Org v: 1.21.1.7 with: Xwayland v: 22.1.9 driver: X:
loaded: amdgpu unloaded: fbdev,modesetting,radeon,vesa dri: radeonsi
gpu: amdgpu resolution: 5120x2880~60Hz
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: AMD Radeon RX 6900 XT (navi21
LLVM 15.0.6 DRM 3.49 6.1.0-23-amd64) direct-render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 0c:00.1
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0e:00.4
API: ALSA v: k6.1.0-23-amd64 status: kernel-api
Server-1: PipeWire v: 0.3.65 status: active
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
port: e000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IP v4: <filter> type: noprefixroute scope: global
IP v6: <filter> scope: link
Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
port: d000 bus-ID: 06:00.0
IF: enp6s0 state: down mac: <filter>
Bluetooth:
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-6:4
bt-service: enabled,running rfk-block: hardware: no software: no
address: <filter>
Local Storage: total: 7.53 TiB used: 605.24 GiB (7.9%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 2TB
size: 1.82 TiB temp: 59.9 C
ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 980 PRO 500GB
size: 465.76 GiB temp: 43.9 C
ID-3: /dev/sda vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB
ID-4: /dev/sdb vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
ID-5: /dev/sdc vendor: Seagate model: ST2000DM001-1ER164 size: 1.82 TiB
ID-6: /dev/sdd vendor: Seagate model: ST2000DM001-1ER164 size: 1.82 TiB
ID-7: /dev/sdf type: USB vendor: Realtek model: RTL9210B-CG
ID-1: / size: 1.72 TiB used: 571.32 GiB (32.4%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 5.8 MiB (1.9%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: partition size: 68.97 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p3
System Temperatures: cpu: 42.0 C mobo: 34.0 C gpu: amdgpu temp: 54.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 482 Uptime: 59m Memory: 62.7 GiB used: 24.04 GiB (38.3%)
Init: systemd target: graphical (5) Compilers: gcc: 12.2.0 Packages: 2770
Shell: Bash v: 5.2.15 inxi: 3.3.26
ich habe ein Problem mit einer OracleVM. Diese Maschine läuft unter Debian 12. In der Maschine ist Windows 10 installiert, brauche ich für Hardware, die ich sonst nicht über Linux auslesen kann.
Jetzt ist das Problem, das sie Software in dem Windows10 die angeschlossene Hardware nicht findet. Es ist so, das die Hardware (Insulinpumpe) piept, wenn sie mit dem USB Kabel am PC angeschlossen wird, und sie piept noch mal, wenn ich die Software in der VM starte und dazu unter "USB" das entsprechende Gerät auswähle. Der Treiber in dem Windows10 sucht dann die Hardware, findet sie aber nicht. Die "Sanduhr" dreht sich ununterbrochen.
Dazu muss ich sagen, das es schon mal funktioniert hat. Und da ging das ganz schnell, Hardware (Insulinpumpe) anschließen, kurz darauf hat der Treiber (Glooko) die Hardware erkannt.
Die Gasterweiterungen sind installiert.
Woran kann das liegen, was kann ich tun?
Danke
