Mintupgrade - Paketübertragung - Fehler aufgetreten
    Linux Mint
    Kernel: 5.15.0-119-generic x86_64 bits: 64 compiler: gcc v: 11.4.0
    Desktop: Cinnamon 6.0.4 Distro: Linux Mint 21.3 Virginia
    base: Ubuntu 22.04 jammy
    Type: Desktop System: Gigabyte product: N/A v: N/A
    serial: <superuser required>
    Mobo: Gigabyte model: H77M-D3H v: x.x serial: <superuser required>
    BIOS: American Megatrends v: F9 date: 08/22/2012
    Info: quad core model: Intel Core i5-3470S bits: 64 type: MCP
    arch: Ivy Bridge rev: 9 cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
    Speed (MHz): avg: 3033 high: 3193 min/max: 1600/3600 cores: 1: 3193
    2: 3191 3: 2556 4: 3193 bogomips: 23147
    Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
    Device-1: NVIDIA GA104 [GeForce RTX 3060] vendor: Micro-Star MSI
    driver: nvidia v: 550.107.02 bus-ID: 01:00.0
    gpu: nvidia resolution: 1: 1680x1050~60Hz 2: 1920x1080~60Hz
    OpenGL: renderer: N/A v: N/A direct render: N/A
    Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Gigabyte
    Device-2: NVIDIA GA104 High Definition Audio vendor: Micro-Star MSI
    Sound Server-1: ALSA v: k5.15.0-119-generic running: yes
    Device-1: Qualcomm Atheros AR8161 Gigabit Ethernet vendor: Gigabyte
    driver: alx v: kernel port: d000 bus-ID: 02:00.0
    IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
    Local Storage: total: 2.52 TiB used: 2.07 TiB (82.1%)
    ID-1: /dev/sda vendor: Western Digital model: WD5000AAKX-08ERMA0
    ID-2: /dev/sdb vendor: Verbatim model: Vi550 S3 size: 953.87 GiB
    ID-3: /dev/sdc vendor: Western Digital model: WD5000BEVT-22ZAT0
    ID-4: /dev/sdd type: USB vendor: Samsung model: HD753LJ size: 698.64 GiB
    ID-1: / size: 69.12 GiB used: 47.69 GiB (69.0%) fs: ext4 dev: /dev/sdb4
    ID-1: swap-1 type: partition size: 7.45 GiB used: 0 KiB (0.0%)
    dev: /dev/sdb3
    System Temperatures: cpu: 59.0 C mobo: 27.8 C
    Fan Speeds (RPM): N/A
    Processes: 254 Uptime: 24m Memory: 15.58 GiB used: 2.56 GiB (16.4%)
    Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 3077 Shell: Bash
    v: 5.1.16 inxi: 3.3.13
    juergen@WoZi:~$
    Moin,
    bevor ich gleich meinen Computer schrotte (und aus dem Fenster schmeisse), möchte ich Euch um Hilfe bitten.
    Wollte bzw. will einen Upgrade auf 22 machen. Habe mir das tool heruntergeladen und alles so gemacht wie Jean es in seinem Video beschrieben hat.
    Dann kommt nach der Simulation die obige Fehlermeldung:
    dieses ist der output, der noch im Kommandozeilen-Fenster zu sehen ist.
    Nach dem ersten Auftauchen bin ich dann beigegangen und habe dieses alles deinstalliert mit Synaptic-Paketverwaltung.
    Als erstes libreoffice, wie in einem anderen Thread vorgeschlagen und den Rest mit der Verwaltung.
    Das einzige Ergebnis danach war, das mein System total kollabiert ist und ich über Timeshift zurück gegangen bin.
    Dann der 2. Versuch und wieder dieses. Ich habe jetzt keine Idee mehr.
    Einer von Euch vielleicht?
    Gruß
    Jürgen
  • Wenn ein Upgrade nicht funktioniert, bleibt immer noch eine Neuinstallation.
    Hier ist es empfehlenswert, eine eigene /home - Partition zu nutzen.
    Dadurch bleiben Einstellungen erhalten und auch die Daten.
    Auch würde ich vordem Upgrade auf Kernel 6.8 wechseln und schauen, ob mein System mit dem 6.8er läuft.
    Um Zeit bei Upgrade zu sparen empfiehlt es sich auch, alle anderen Kernel zu löschen.
    Anleitung zum Thema Kernel: https://sourceforge.net/projects/iso-d…ng.pdf/download
  • Hast Du ggf. vorhandene fremde Paketquellen deaktiviert?
    Hast Du das Apt-Cache geleert, damit keine alten Paket-Versionen mehr drin vorhanden sind? - außerdem sollten auch alte Pakete ohne Abhängigkeiten entfernt werden:
    sudo apt-get clean && sudo apt-get autoremove
    Oder es liegt nur am Spiegelserver - ggf. den mal wechseln.
  • Hallo, ich habe das gleiche Problem (Error - Return code: 100), als Spiegelserver ist fastly eingestellt, So wie es auch in Jeans Video erklärt wird.
    Aus dem Report:
    Ich habe die Abhängigkeiten mal nachgeschaut:
    gvfs-backends : Depends: libsmbclient (>= 2:4.12.0+dfsg)
    :~# aptitude show libsmbclient
    Paket: libsmbclient
    Version: 2:4.15.13+dfsg-0ubuntu1.6
    Zustand: Installiert
    libldb2 : Depends: libtevent0 (>= 0.10.2~)
    :~# aptitude show libtevent0
    Paket: libtevent0
    Version: 0.11.0-1build1
    usw.
    Bin ratlos :/
    Ich weiß nicht was Jean dort empfiehlt! Ich empfehle als Spiegelserver jeweils "Gebietsnah" auszuwählen UND eine
    Uni weil die "stabiler" ausliefern.
    Gebietsnah wäre z.B. im Umkreis von Frankfurt eine Uni von Frankfurt (sofern vorhanden)
  • tommix - Danke!
    Der Update auf Kernel 6.8. und dann noch einmal Aktualisierung gefahren, ein paar mal gestartet usw.
    Jetzt ist der Upgrade durch - ohne Probleme!
    Und auch die anderen Probleme, wegen denen ich den Upgrade fahren wollte sind erledigt.
    Mein System läuft wieder wie eine eins.
    Tommix - Eine Frage muß ich aber noch stellen: Du schreibst für Neuinstallation "...eigene /home - Partition zu nutzen..."
    Meine Daten habe ich ja schon ausgelagert und per Link eingebunden. Kann ich denn jetzt im Nachhinein auch noch das ganze home vom system auslagern?
  • phili
    Zu deiner Frage: Ja, auch eine nachträgliche ist die Auslagerung der /home - Partition möglich.
    Als Hilfe für das Upgrade von LM 21.3 auf LM 22 kann diese Anleitung genutzt werden:
    https://sourceforge.net/projects/iso-dateien/files/Wiki/Upgrade/Upgrade%20auf%20Linux%20Mint%2021.pdf/download
    Die Anleitung Für das Upgrade von LM 21.3 auf LM 22 erstelle ich gerade.
    Auch ein Upgrade von LM 21.3 LXDE auf LM 22 LXDE ist nach einem ersten Test möglich.
    Auch dafür erstelle ich eine Anleitung.
    Edited once, last by tommix (August 28, 2024 at 9:11 PM).
  • Ist zwar schon etwas älter, sollte aber noch funktionieren:
    System-Ordner (z.B. Home-Ordner) im Nachhinein auf andere Partitionen auslagern - Linux Tutorial
    Heute zeige Ich, wie man Systemordner im Nachhinein auf andere Partitionen auslagern kann. Dabei müssen das keine existierende Ordner sein, es können auch ko...
    www.youtube.com
  • phili August 29, 2024 at 5:27 PM
