- Distrowahl
- Linux Mint
- System:
Kernel: 6.8.0-41-generic arch: x86_64 bits: 64 compiler: gcc v: 13.2.0
base: Ubuntu 24.04 noble
Type: Laptop System: ASUSTeK product: ROG Strix G713RC_G713RC v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: G713RC v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: G713RC.327 date: 02/16/2023
Battery:
ID-1: BAT0 charge: 50.1 Wh (100.0%) condition: 50.1/56.0 Wh (89.4%)
volts: 16.5 min: 15.9 model: AS3GXSC3KC G513-36 status: discharging
Info: 8-core model: AMD Ryzen 7 6800HS with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3+ rev: 1 cache: L1: 512 KiB L2: 4 MiB L3: 16 MiB
Speed (MHz): avg: 635 high: 2177 min/max: 400/4785 cores: 1: 400 2: 400
3: 400 4: 400 5: 1395 6: 2177 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400
13: 1397 14: 400 15: 400 16: 400 bogomips: 102208
Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: ASUSTeK
driver: nvidia v: 535.183.01 arch: Ampere bus-ID: 01:00.0
Device-2: AMD Rembrandt [Radeon 680M] vendor: ASUSTeK driver: amdgpu
v: kernel arch: RDNA-2 bus-ID: 05:00.0 temp: 31.0 C
loaded: amdgpu,nvidia unloaded: fbdev,modesetting,nouveau,vesa dri: radeonsi
gpu: amdgpu resolution: 1920x1080~144Hz
API: EGL Message: No EGL data available.
API: OpenGL v: 4.6.0 vendor: nvidia v: 535.183.01 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 3050 Laptop GPU/PCIe/SSE2
Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 01:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
driver: snd_pci_acp6x v: kernel bus-ID: 05:00.5
Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 05:00.6
API: ALSA v: k6.8.0-41-generic status: kernel-api
Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
vendor: Foxconn driver: mt7921e v: kernel bus-ID: 02:00.0
IF: wlo1 state: up mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
port: e000 bus-ID: 03:00.0
IF: enp3s0 state: down mac: <filter>
Bluetooth:
Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB
bus-ID: 1-4:3
address: <filter>
Local Storage: total: 931.51 GiB used: 48.47 GiB (5.2%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WDS100T3X0C-00SJG0
size: 931.51 GiB temp: 44.9 C
ID-1: / size: 68.66 GiB used: 15.9 GiB (23.2%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 98.8 MiB used: 6.1 MiB (6.2%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 844.54 GiB used: 32.56 GiB (3.9%) fs: ext4
dev: /dev/nvme0n1p4
ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p3
System Temperatures: cpu: 39.4 C mobo: 26.0 C
Fan Speeds (rpm): N/A
GPU: device: nvidia screen: :0.0 temp: 30 C device: amdgpu temp: 32.0 C
Memory: total: 64 GiB note: est. available: 62.06 GiB used: 1.84 GiB (3.0%)
Processes: 391 Uptime: 2m Init: systemd target: graphical (5)
Packages: 2425 Compilers: gcc: 13.2.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Hallo Ihr
ich habe seit Jahren nur Linux, habe aber auch weiterhin grosse Wissenslücken... und meist nutze ich meinen Laptop nur um im Internet unterwegs zu sein...
nun habe ich mir einen Gaming-Laptop gekauft, über ixsoft.de fix und fertig mit Linux...
auf meinem vorherigen Laptop habe ich erfolgreich OBS installiert und ein paar mal auf Twitch gestreamt... und würde sehr gerne Marbles On Stream streamen.. daher dann auch Steam installiert... von Wine gehört- dieses installiert... soweit gekommen, Windows-Steam über Wine zu installieren und mich per QRCode anzumelden, da die Felder im Anmeldefenster nicht gingen... dann Marbles heruntergeladen, aber nicht wirklich versucht zu starten weil jener Laptop nur eine integrierte Grafik hat, also weit von den MIndestanforderungen entfernt ist...
mittlerweile auch von Proton erfahren und also auf dem Gaming-Laptop Linux-Steam installiert und die entsprechenden Häkchen gesetzt... dann mit verschiedenen Proton-Varianten versucht, Marbles zu starten.. aber bestenfalls blitzt es kurz auf, stoppt dann aber...
nun ist es so, dass ich ehrlich gesagt etwas müde war, als ich Steam installiert habe- kein Problem wenn ich nur machen muss was das System mir sagt- aufmerksam lesen kann ich trotzdem... aber bei der Installation öffnete sich bei 'Updating Steam' ein Fenster und ausser der Installation wurden mir noch ein paar Sachen vorgeschlagen- ich weiss nur noch, dass es etwa fünf waren und jeweils Nvidia im Namen drin war... ich wusste in dem Moment aber nicht, wie ich die Vorschläge mitinstallieren kann... und hinterher hatte ich keine Ahnung wie ich sie wiederfinden kann... und womöglich sind die das, was noch fehlt- oder ein Teil dessen, was noch fehlt...?
vielleicht geht auch Marbles On Stream schlichtweg nicht, aber da es ein Marbles Spieler war, der mir gesagt hatte, dieses würde auch auf LInux laufen, glaube ich eigentlich schon, dass es gehen müsste...
ich würde mich sehr freuen, wenn ihr mir helfen könnt!
liebe Grüssle...
