Linux Mint 21.2: Inhalt von Hilfe-Themen wird nicht angezeigt, z.B. Nemo
    harry@harry-HP-Z230-Tower-Workstation:~$ inxi -Fzxi
    Kernel: 5.15.0-116-generic x86_64 bits: 64 compiler: gcc v: 11.4.0
    Desktop: Cinnamon 6.0.4 Distro: Linux Mint 21.3 Virginia
    base: Ubuntu 22.04 jammy
    Type: Desktop System: Hewlett-Packard product: HP Z230 Tower Workstation
    v: N/A serial: <superuser required>
    Mobo: Hewlett-Packard model: 1905 serial: <superuser required>
    UEFI: Hewlett-Packard v: L51 v01.61 date: 07/04/2018
    Battery:
    Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M510
    charge: 55% (should be ignored) status: Discharging
    Info: quad core model: Intel Core i7-4770 bits: 64 type: MT MCP
    arch: Haswell rev: 3 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
    Speed (MHz): avg: 3012 high: 3393 min/max: 800/3900 cores: 1: 3392
    2: 2376 3: 2399 4: 2442 5: 3310 6: 3393 7: 3392 8: 3393 bogomips: 54271
    Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
    Device-1: NVIDIA GK107GL [Quadro K600] vendor: Hewlett-Packard
    driver: nvidia v: 470.256.02 bus-ID: 01:00.0
    unloaded: fbdev,modesetting,nouveau,vesa gpu: nvidia resolution:
    1: 1920x1080~60Hz 2: 1920x1080~60Hz
    OpenGL: renderer: Quadro K600/PCIe/SSE2 v: 4.6.0 NVIDIA 470.256.02
    direct render: Yes
    Device-1: Intel 8 Series/C220 Series High Definition Audio
    vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    Device-2: NVIDIA GK107 HDMI Audio vendor: Hewlett-Packard
    Sound Server-1: ALSA v: k5.15.0-116-generic running: yes
    Device-1: Intel Ethernet I217-LM vendor: Hewlett-Packard driver: e1000e
    v: kernel port: f040 bus-ID: 00:19.0
    Bluetooth:
    Device-1: TP-Link UB500 Adapter type: USB driver: btusb v: 0.8
    bus-ID: 3-11:7
    Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter>
    bt-v: 3.0 lmp-v: 5.1
    RAID:
    Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0
    bus-ID: 00:1f.2
    Local Storage: total: 2.27 TiB used: 443.8 GiB (19.1%)
    ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB
    ID-2: /dev/sdb vendor: Western Digital model: WD10EZEX-60M2NA0
    ID-3: /dev/sdc type: USB vendor: Toshiba model: MQ01ABD100
    ID-1: / size: 456.89 GiB used: 30.04 GiB (6.6%) fs: ext4 dev: /dev/sda2
    dev: /dev/sda1
    System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 68 C
    Fan Speeds (RPM): N/A gpu: nvidia fan: 34%
    Processes: 291 Uptime: 37m Memory: 7.51 GiB used: 2.03 GiB (27.0%)
    Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 2478 Shell: Bash
    v: 5.1.16 inxi: 3.3.13
    Hi,
    ich habe das Probleme, dass in der Rubrik "Hilfe" zwar Themen angezeigt werden, aber keine Inhalte.
    Beispiel: Persönlicher Ordner - Nemo 6.0.2 - Hilfe - Suche z.B. Anzeige und dann .. nichts.
    Das Problem habe ich auch bei anderen Programmen z.B. PIX
    Was muss ich tun um das Problem zu Lösen?
  • DenalB July 23, 2024 at 2:12 PM
    Changed the title of the thread from “Hilfe Themen Inhalte werden nicht angezeigt - Linux Mint 21.2 - z.B. Nemo” to “Linux Mint 21.2: Inhalt von Hilfe-Themen wird nicht angezeigt, z.B. Nemo”.
  • Wenn es von Interesse ist >>> das Problem lag in der Auswahl des Grafiktreibers. Ich hatte den vom System empfohlenen genommen, hätte aber den eine Etage tiefer (also älter) nehmen sollen (es waren 3 Treiber aufgelistet). Treiber gewechselt und schon war wieder alles gut.
    Hilfe kam hier von einem anderen Linux Mint Forum.
  • DenalB July 26, 2024 at 10:26 AM
