- System:
Kernel: 5.4.0-187-generic x86_64 bits: 64 compiler: gcc v: 9.4.0
Desktop: MATE 1.26.0 Distro: Linux Mint 20.3 Una base: Ubuntu 20.04 focal
Type: Desktop System: ASUS product: All Series v: N/A serial: <filter>
Mobo: ASUSTeK model: B85M-G v: Rev X.0x serial: <filter>
BIOS: American Megatrends v: 2108 date: 08/11/2014
Topology: Quad Core model: Intel Core i7-4790 bits: 64 type: MT MCP
arch: Haswell rev: 3 L2 cache: 8192 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 57465
Speed: 1598 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 1400 2: 1401
3: 1399 4: 1532 5: 1452 6: 1400 7: 1408 8: 1417
Device-1: NVIDIA GM107 [GeForce GTX 750 Ti] vendor: ASUSTeK driver: nvidia
v: 535.183.01 bus ID: 01:00.0
Display: x11 server: X.Org 1.20.13 driver: nvidia
unloaded: fbdev,modesetting,nouveau,vesa resolution: 1920x1080~60Hz
OpenGL: renderer: NVIDIA GeForce GTX 750 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 535.183.01 direct render: Yes
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1b.0
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 01:00.1
Device-3: C-Media CM106 Like Sound Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 5-1.1:3
Device-4: Guillemot Dualpix HD type: USB driver: snd-usb-audio,uvcvideo
bus ID: 3-10:6
Sound Server: ALSA v: k5.4.0-187-generic
vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus ID: 04:00.0
WAN IP: No WAN IP data found. Connected to the web? SSL issues?
Local Storage: total: 2.51 TiB used: 1.40 TiB (55.9%)
ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB
ID-2: /dev/sdb vendor: Seagate model: ST2000DM001-1ER164 size: 1.82 TiB
ID-3: /dev/sdc vendor: Intenso model: SSD SATAIII size: 238.47 GiB
ID-1: / size: 233.18 GiB used: 83.41 GiB (35.8%) fs: ext4 dev: /dev/sdc5
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 39 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 28%
Processes: 247 Uptime: 1h 00m Memory: 31.29 GiB used: 3.54 GiB (11.3%)
Init: systemd runlevel: 5 Compilers: gcc: 9.4.0 Shell: bash v: 5.0.17
inxi: 3.0.38
Hallo in die Runde,
z.Zt. mache ich bei meinem System (Linux Mint 20.3 Una 64-bit, Kernel Linux 5.4.0-187-generic x86_64, MATE 1.26.0) einen "Frühjahrsputz" (bzw. versuche es zumindest, denn ich bin erst vor nicht allzu langer Zeit auf Linux umgestiegen).
Dazu habe ich im Terminal folgendes durchgeführt:
dpf0005@newtow:~$ uname -a
Linux newtow 5.4.0-187-generic #207-Ubuntu SMP Mon Jun 10 08:16:10 UTC 2024 x86_64 x86_64
x86_64 GNU/Linux
dpf0005@newtow:~$ sudo apt-get autoremove --purge
[sudo] Passwort für dpf0005:
Paketlisten werden gelesen... Fertig
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen.... Fertig
0 aktualisiert, 0 neu installiert, 0 zu entfernen und 2 nicht aktualisiert.
sudo rm -rf /var/lib/apt/lists/*
sudo apt-get update
In Anwendungsverwaltung - Ansicht - Kernel habe ich danach folgendes entdeckt:
"Sie benutzen derzeit den Kernel: 5.4.0-187-generic (Wird unterstützt bis April 2025)
5.15 5.15.0-113 Wird unterstützt bis Mai 2025
5.15-0-... Wurde ersetzt ...
5.13 Ende der Unterstützungsdauer
5.11 Ende der Unterstützungsdauer
5.8 Ende der Unterstützungsdauer
5.4 5.4.0-187 Aktiv Wird unterstützt bis April 2025
5.4.0-187 installiert
5.4.0-58 installiert
5.4-0-... Wurde ersetzt ...
Ich nehme an, dass ich zumindest 5.13, 5.11 und 5.8 bedenkenlos entfernen kann, habe aber keine Ahnung ...
... und bevor ich mir die ganze "Kiste" abschiesse, frage vorher ich lieber 'mal ...
Vielen Dank im voraus.
Gruß Glolin
