- System:
Kernel: 5.4.0-187-generic x86_64 bits: 64 compiler: gcc v: 9.4.0
Desktop: MATE 1.26.0 Distro: Linux Mint 20.3 Una base: Ubuntu 20.04 focal
Type: Desktop System: ASUS product: All Series v: N/A serial: <filter>
Mobo: ASUSTeK model: B85M-G v: Rev X.0x serial: <filter>
BIOS: American Megatrends v: 2108 date: 08/11/2014
Topology: Quad Core model: Intel Core i7-4790 bits: 64 type: MT MCP
arch: Haswell rev: 3 L2 cache: 8192 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 57465
Speed: 1598 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 1400 2: 1401
3: 1399 4: 1532 5: 1452 6: 1400 7: 1408 8: 1417
Device-1: NVIDIA GM107 [GeForce GTX 750 Ti] vendor: ASUSTeK driver: nvidia
v: 535.183.01 bus ID: 01:00.0
Display: x11 server: X.Org 1.20.13 driver: nvidia
unloaded: fbdev,modesetting,nouveau,vesa resolution: 1920x1080~60Hz
OpenGL: renderer: NVIDIA GeForce GTX 750 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 535.183.01 direct render: Yes
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1b.0
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 01:00.1
Device-3: C-Media CM106 Like Sound Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 5-1.1:3
Device-4: Guillemot Dualpix HD type: USB driver: snd-usb-audio,uvcvideo
bus ID: 3-10:6
Sound Server: ALSA v: k5.4.0-187-generic
vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus ID: 04:00.0
WAN IP: No WAN IP data found. Connected to the web? SSL issues?
Local Storage: total: 2.51 TiB used: 1.40 TiB (55.9%)
ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB
ID-2: /dev/sdb vendor: Seagate model: ST2000DM001-1ER164 size: 1.82 TiB
ID-3: /dev/sdc vendor: Intenso model: SSD SATAIII size: 238.47 GiB
ID-1: / size: 233.18 GiB used: 83.41 GiB (35.8%) fs: ext4 dev: /dev/sdc5
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 39 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 28%
Processes: 247 Uptime: 1h 00m Memory: 31.29 GiB used: 3.54 GiB (11.3%)
Init: systemd runlevel: 5 Compilers: gcc: 9.4.0 Shell: bash v: 5.0.17
inxi: 3.0.38
Hallo in die Runde,
z.Zt. mache ich bei meinem System (Linux Mint 20.3 Una 64-bit, Kernel Linux 5.4.0-187-generic x86_64, MATE 1.26.0) einen "Frühjahrsputz" (bzw. versuche es zumindest, denn ich bin erst vor nicht allzu langer Zeit auf Linux umgestiegen).
Dazu habe ich im Terminal folgendes durchgeführt:
dpf0005@newtow:~$ uname -a
Linux newtow 5.4.0-187-generic #207-Ubuntu SMP Mon Jun 10 08:16:10 UTC 2024 x86_64 x86_64
x86_64 GNU/Linux
dpf0005@newtow:~$ sudo apt-get autoremove --purge
[sudo] Passwort für dpf0005:
Paketlisten werden gelesen... Fertig
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen.... Fertig
0 aktualisiert, 0 neu installiert, 0 zu entfernen und 2 nicht aktualisiert.
sudo rm -rf /var/lib/apt/lists/*
sudo apt-get update
In Anwendungsverwaltung - Ansicht - Kernel habe ich danach folgendes entdeckt:
"Sie benutzen derzeit den Kernel: 5.4.0-187-generic (Wird unterstützt bis April 2025)
5.15 5.15.0-113 Wird unterstützt bis Mai 2025
5.15-0-... Wurde ersetzt ...
5.13 Ende der Unterstützungsdauer
5.11 Ende der Unterstützungsdauer
5.8 Ende der Unterstützungsdauer
5.4 5.4.0-187 Aktiv Wird unterstützt bis April 2025
5.4.0-187 installiert
5.4.0-58 installiert
5.4-0-... Wurde ersetzt ...
Ich nehme an, dass ich zumindest 5.13, 5.11 und 5.8 bedenkenlos entfernen kann, habe aber keine Ahnung ...![]()
... und bevor ich mir die ganze "Kiste" abschiesse, frage vorher ich lieber 'mal ...
Vielen Dank im voraus.
Gruß Glolin
