Hplip Papierformat 11x14 inch als Dauerschleife
    Linux Mint
    Kernel: 6.8.0-111-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
    Desktop: Cinnamon v: 6.6.7 Distro: Linux Mint 22.3 Zena
    base: Ubuntu 24.04 noble
    Type: Convertible System: HP product: HP EliteBook x360 1030 G2 v: N/A
    serial: <superuser required>
    Mobo: HP model: 827D v: KBC Version 44.79 serial: <superuser required>
    UEFI: HP v: P80 Ver. 01.39 date: 04/20/2021
    Battery:
    ID-1: BAT0 charge: 42.3 Wh (96.4%) condition: 43.9/57.2 Wh (76.7%)
    volts: 12.3 min: 11.6 model: Hewlett-Packard Primary status: not charging
    Info: dual core model: Intel Core i7-7600U bits: 64 type: MT MCP
    arch: Amber/Kaby Lake note: check rev: 9 cache: L1: 128 KiB L2: 512 KiB
    L3: 4 MiB
    Speed (MHz): avg: 3897 high: 3901 min/max: 400/3900 cores: 1: 3898 2: 3898
    3: 3901 4: 3894 bogomips: 23199
    Device-1: Intel HD Graphics 620 vendor: Hewlett-Packard driver: i915
    v: kernel arch: Gen-9.5 bus-ID: 00:02.0
    Device-2: Chicony HP HD Camera driver: uvcvideo type: USB bus-ID: 1-7:8
    Device-3: Chicony HP IR Camera driver: uvcvideo type: USB bus-ID: 1-8:9
    loaded: modesetting unloaded: fbdev,vesa dri: iris gpu: i915 resolution:
    1: 2560x1440~60Hz 2: 1920x1080~120Hz
    v: 25.2.8-0ubuntu0.24.04.1 glx-v: 1.4 direct-render: yes renderer: Mesa
    Intel HD Graphics 620 (KBL GT2)
    Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
    Device-2: DSEA A/S EPOS BTD 800 III
    driver: hid-generic,snd-usb-audio,usbhid type: USB bus-ID: 1-2.1:5
    Device-3: Realtek USB Audio driver: hid-generic,snd-usb-audio,usbhid
    type: USB bus-ID: 3-1.1.3:6
    API: ALSA v: k6.8.0-111-generic status: kernel-api
    Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel
    bus-ID: 3a:00.0
    IF: wlp58s0 state: up mac: <filter>
    Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    bus-ID: 4-1.2:4
    IF: enxe04f438e99ca state: up speed: 1000 Mbps duplex: full mac: <filter>
    Bluetooth:
    Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    bus-ID: 1-9:10
    address: <filter>
    Local Storage: total: 238.47 GiB used: 186.49 GiB (78.2%)
    ID-1: /dev/sda vendor: Micron model: MTFDDAV256TBN-1AR15ABHA
    ID-1: / size: 233.18 GiB used: 186.47 GiB (80.0%) fs: ext4 dev: /dev/sda2
    System Temperatures: cpu: 72.0 C pch: 62.0 C mobo: N/A
    Fan Speeds (rpm): N/A
    Memory: total: 16 GiB note: est. available: 15.04 GiB used: 7.09 GiB (47.2%)
    Processes: 282 Uptime: 3h 47m Init: systemd target: graphical (5)
    Packages: 3213 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
    Im März 2025 auf Linux Mint umgestiegen und vom ersten Tag an hatte der HP OfficeJetPro 7740 kein Problem mit diesem Systemwechsel.
    Letzten Freitag die Änderung nach einem Patronenwechsel:
    • Netzwerkdrucker wurde nicht mehr gefunden - erledigt, funktioniert wieder.
    • Libre Office druckt zentriert und ohne Kopf- und Fusszeilen (in der Druckvorschau erscheint es aber korrekt als A4 Ausdruck, linksbündig mit Kopf- und Fusszeile) - Format ist auf A4 gesetzt - bis jetzt keine Lösung
    • HPlip stellt das Papierformat immer wieder auf 11x14 Inch - man kann es manuell auf A4 stellen, sobald man aber wieder auf die generellen Einstellungen zurück kommt, ist da wieder 11x14 gesetzt. Es bringt auch nichts, wenn man den "default" Knopf drückt, es springt dann zwar brav auf A4; sobald man aber die Seite wechselt und auf "General" zurückkommt, ist da wieder 11x14 gesetzt. Dementsprechend sieht auch die Testseite aus.
    • Druckt man die Testseite direkt am Drucker ist alles in bester Ordnung.
    • Druckt man von einem Android-Gerät im Netzwerk ist alles in bester Ordnung.
    • Druckt man, mit dem Arbeits-Laptop in Windows, ist, so weh es tut, dies zu schreiben, alles in bester Ordnung.
    • Auf CUPS ist A4 als Standard festgelegt, scheint aber Hplip nur bedingt zu interessieren.
    Wo stehe ich genau auf dem Schlauch?
  • Hallo Ricobla
    Ruf doch mal in der Konsole die
    locale
    auf und sieh dir mal an ob diese Variable drin steht.
    LC_PAPER=de_DE.UTF-8
    Sollte da stattdessen us_US drin stehen müssen wir das ändern.
    Nur ein Ansatz aber damit können wir falls es stimmt schon mal ausklammern.
    Gruss
  • Na fein
    Die Grundkonstante ist in Ordnung.
    Dann ist wahrscheinlich der Drucker bei Patronenwechsel auf default/Auslieferungszustand zurückgesetzt worden.
    Ergo:
    Ruf in einem Browser http://localhost:631 auf geh zu deinem Drucker und leg die Standardoption auf Din4 fest.
    Danach startest du cups bitte neu.
    sudo systemctl restart cups
    Wo ge nau das in dieser grafischen Umgebung ist musst du dir ansehen, findest du aber mit Sicherheit.
    Ich bin leider nicht Mint affin sprich ich habe das nicht bei mir am laufen.
    Wenn nicht melde dich bitte nochmal, das bekommen wir schon geregelt.
  • Geschafft.
    Folgender Weg führte zum Erfolg:
    • Drucker mit CUPS löschen
    • Auf HPlip kontrollieren, ob er wirklich gelöscht ist - bei mir war die Scan-Funktion noch da.
    • Zur Sicherheit auch noch ein Blick auf localhost werfen.
    • Drucker abstellen und neu starten.
    • Drucker localhost aufrufen und "Hinzufügen" wählen.
    • Drucker einrichten und Testseite drucken - Format stimmte aber die Auswahl war auf "Graustufen" (war mir aber zu dem Moment so was von egal!)
    • CUPS aufrufen und Einstellungen kontrollieren, wahlweise noch ein kurzer Aufruf an die persönliche Gottheit und eine Testseite drucken. Format A4
    • HPlip öffnen und das Format kontrollieren: A4
    • Zur Sicherheit noch die Einstellungen bei Libre Office kontrolliert: A4
    • Thunderbird hatte 3x5 inch als Standardformat, lässt sich aber einfach ändern und bleibt auch
    • Der einzige, kleine Fehler besteht bei pdf Dateien. pdf Datei ab Broser Brave kommt eine A4 Seite auf der Grösse einer Visitenkarte raus und müsste vor jedem Druck manuel angepasst werden. Gleiche Datei gespeichert und dann ab Dokumentenansicht gedruckt, alles in Ordnung. Mit Firefox besteht diese Herausforderung nicht und Brave brauche ich an sich nur für die Webshop von zwei Lieferanten.
    Ich möchte mich für die Hilfe bedanken und wünsche allen HP-Usern einen störungsfreien Betrieb.
