- System:
Kernel: 6.19.11-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
clocksource: tsc
Desktop: KDE Plasma v: 6.6.3 tk: Qt v: N/A wm: kwin_wayland vt: 2 dm: N/A
Distro: EndeavourOS base: Arch Linux
Type: Detachable System: Micro (HK) Tech product: V3 v: N/A
serial: <superuser required>
Mobo: Shenzhen Meigao Equipment model: HPPAC serial: <superuser required>
uuid: <superuser required> Firmware: UEFI vendor: American Megatrends LLC.
v: 1.06 date: 04/16/2024
Battery:
ID-1: BATT charge: 15.7 Wh (33.2%) condition: 47.2/50.8 Wh (92.9%)
volts: 11.04 min: 11.55 model: Standard SR Real Battery type: Li-ion
serial: <filter> charging: status: discharging cycles: 322
Device-1: hid-0018:222A:550D.0003-battery model: PNP0C50:00 222A:550D
serial: N/A charge: N/A status: N/A
Info: 8-core model: AMD Ryzen 7 8840U w/ Radeon 780M Graphics bits: 64
type: MT MCP smt: enabled arch: Zen 4 rev: 2 cache: L1: 512 KiB L2: 8 MiB
L3: 16 MiB
Speed (MHz): avg: 1100 min/max: 419/5135 boost: enabled cores: 1: 1100
2: 1100 3: 1100 4: 1100 5: 1100 6: 1100 7: 1100 8: 1100 9: 1100 10: 1100
11: 1100 12: 1100 13: 1100 14: 1100 15: 1100 16: 1100 bogomips: 105404
Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a
ssse3 svm
Device-1: Advanced Micro Devices [AMD/ATI] HawkPoint1 driver: amdgpu
v: kernel arch: RDNA-3 pcie: speed: 16 GT/s lanes: 16 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, DP-8, Writeback-1
bus-ID: c3:00.0 chip-ID: 1002:1900 class-ID: 0300 temp: 25.0 C
Device-2: Sunplus Innovation Hy-Usb2.0-1 MIC driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-1:2 chip-ID: 1bcf:2ce4
class-ID: 0e02 serial: <filter>
Device-3: Kingcome USB2.0 FHD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 3-1:2 chip-ID: 2b7e:c705
class-ID: fe01 serial: <filter>
Display: wayland server: X.org v: 1.21.1.21 with: Xwayland v: 24.1.9
unloaded: modesetting,radeon alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: BOE Display 0x0b7b res: mode: 2560x1600 hz: 60
scale: 125% (1.25) to: 2048x1280 dpi: 215 size: 302x188mm (11.89x7.4")
diag: 356mm (14") modes: max: 2560x1600 min: 640x480
API: EGL v: 1.5 hw: drv: amd radeonsi platforms: device: 0 drv: radeonsi
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi
wayland: drv: radeonsi x11: drv: radeonsi
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 26.0.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 780M Graphics (radeonsi
phoenix ACO DRM 3.64 6.19.11-arch1-1) device-ID: 1002:1900
display-ID: :0.0
API: Vulkan v: 1.4.341 layers: 10 surfaces: N/A device: 0
type: integrated-gpu driver: mesa radv device-ID: 1002:1900
de: kscreen-console,kscreen-doctor wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 16
bus-ID: c3:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Audio Coprocessor
driver: snd_pci_ps v: kernel pcie: speed: 16 GT/s lanes: 16 bus-ID: c3:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio
bus-ID: c3:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Sunplus Innovation Hy-Usb2.0-1 MIC driver: uvcvideo type: USB
API: ALSA v: k6.19.11-arch1-1 status: kernel-api
Server-1: sndiod v: N/A status: off
Server-2: PipeWire v: 1.6.2 status: active with: 1: pipewire-pulse
status: active 2: wireplumber status: active 3: pipewire-alsa type: plugin
4: pw-jack type: plugin
Message: No PCI device data found.
IF-ID-1: virbr0 state: down mac: <filter>
Bluetooth:
Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 bus-ID: 1-5:6 chip-ID: 8087:0032 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.4
lmp-v: 13 class-ID: 6c0000
Local Storage: total: 953.87 GiB used: 570.54 GiB (59.8%)
ID-1: /dev/nvme0n1 vendor: Kingston model: OM8PGP41024Q-A0
size: 953.87 GiB speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter>
fw-rev: ELFK0S.6 temp: 18.9 C scheme: GPT
ID-1: / size: 802.52 GiB used: 570.37 GiB (71.1%) fs: btrfs
dev: /dev/nvme0n1p5
ID-2: /home size: 802.52 GiB used: 570.37 GiB (71.1%) fs: btrfs
dev: /dev/nvme0n1p5
ID-3: /var/log size: 802.52 GiB used: 570.37 GiB (71.1%) fs: btrfs
dev: /dev/nvme0n1p5
System Temperatures: cpu: 27.4 C mobo: N/A gpu: amdgpu temp: 25.0 C
Fan Speeds (rpm): N/A
Memory: total: 28 GiB available: 27.19 GiB used: 3.28 GiB (12.1%)
Processes: 393 Power: uptime: 8m states: freeze,mem,disk suspend: s2idle
wakeups: 0 hibernate: platform Init: systemd v: 260 default: graphical
Packages: 2109 pm: pacman pkgs: 2102 pm: flatpak pkgs: 7 Compilers:
clang: 22.1.2 gcc: 15.2.1 Shell: Bash v: 5.3.9 running-in: konsole
inxi: 3.3.40
Moin zusammen, fühle mich gerade wie ein absoluter Anfänger
Ich habe auf dem Minisforum V3 aufgeräumt, nicht benutze Pakete deinstalliert. Unter anderem einige der "linux-firmware-xyz". Anscheinend auch die für den WiFi Chip benötigte. Nach dem nächsten Boot war nämlich kein Netzwerk-Adapter mehr im System. In dmesg gab es auch eine entsprechende Meldung über fehlende Firmware für intel wifi.
Also habe ich die linux-firmware pacman Pakete von einem anderen EndeavourOS auf USB Stick und dann auf dem betroffenen Gerät mittels pacman-U wieder von den bestehenden Paket-Dateien installiert.
Neustart, immer noch kein Netzwerk-Adapter vorhanden. Aber keine "fehlende firmware" mehr in den Kernel-Meldungen.
Mal von einigen Live-ISO (Endeavour, Fedora) gestartet und auch da: kein Netzwerk-Adapter!
Schließlich noch die uralte Windows-Partition gestartet: auch da kein Netzwerk.
Das Gerät hat wohl einen Intel AX210 der für WiFi und Bluetooth zuständig ist. Bluetooth ist sogar noch vorhanden (siehe inxi). Aber was ist mit dem WiFi Teil passiert?
Habe ich jetzt irgendwie die Hardware geschrottet? ![]()
