- Distrowahl
- Linux Mint
- System:
Kernel: 6.17.0-23-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
Desktop: Cinnamon v: 6.6.7 Distro: Linux Mint 22.3 Zena
base: Ubuntu 24.04 noble
Type: Desktop System: CSL GmbH product: H5859 v: N/A
serial: <superuser required>
Mobo: ASUSTeK model: PRIME A520M-A II v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3634
date: 09/10/2025
Info: 6-core model: AMD Ryzen 5 PRO 5655G with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 rev: 0 cache: L1: 384 KiB L2: 3 MiB L3: 16 MiB
Speed (MHz): avg: 2629 high: 3000 min/max: 404/4466 boost: enabled cores:
1: 2368 2: 3000 3: 2368 4: 2368 5: 3000 6: 2368 7: 3000 8: 2983 9: 2999
10: 2368 11: 2368 12: 2368 bogomips: 93606
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
Device-1: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5 bus-ID: 08:00.0
temp: 24.0 C
resolution: 1920x1080~60Hz
v: 25.2.8-0ubuntu0.24.04.1 glx-v: 1.4 direct-render: yes renderer: AMD
Radeon Graphics (radeonsi renoir ACO DRM 3.64 6.17.0-23-generic)
Device-1: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 08:00.1
Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 08:00.6
API: ALSA v: k6.17.0-23-generic status: kernel-api
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 04:00.0
IF: wlp4s0 state: down mac: <filter>
vendor: ASUSTeK RTL8111H driver: r8169 v: kernel port: f000 bus-ID: 06:00.0
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth:
Device-1: Intel AX200 Bluetooth driver: btusb v: 0.8 type: USB bus-ID: 1-8:5
Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
lmp-v: 11
Local Storage: total: 931.51 GiB used: 15.85 GiB (1.7%)
ID-1: /dev/nvme0n1 vendor: Kingston model: SNV3S1000G size: 931.51 GiB
temp: 23.9 C
ID-1: / size: 430.13 GiB used: 15.79 GiB (3.7%) fs: ext4 dev: /dev/nvme0n1p5
ID-2: /boot/efi size: 256 MiB used: 56.5 MiB (22.1%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: 28.2 C mobo: N/A gpu: amdgpu temp: 24.0 C
Fan Speeds (rpm): N/A
Memory: total: 32 GiB note: est. available: 30.65 GiB used: 2.17 GiB (7.1%)
Processes: 371 Uptime: 20m Init: systemd target: graphical (5)
Packages: 2023 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Moin ![]()
Wie bekomme ich meine NAS (Synology) bei Systemstart "aufgeweckt" (wakeonlan) und danach gemountet?
Mount bei Start klappt wenn die NAS bereits geweckt wurde. Aufwecken geht mit gWakeOnLan auch. Dann muß ich aber nochmal mounten.
Als einzeln und händisch klappt es. Das kann ich den Mitnutzern aber nicht zumuten. Ist auch unpraktisch
Geht das nicht komplett bei Rechnerstart? ![]()
