- System:
Kernel: 5.10.0-39-686-pae i686 bits: 32 compiler: gcc v: 10.2.1
Desktop: LXDE 0.10.1 Distro: Debian GNU/Linux 11 (bullseye)
Type: Laptop System: ASUSTeK product: 1000HG v: x.x serial: <filter>
Mobo: ASUSTeK model: 1000HG v: x.xx serial: <filter>
BIOS: American Megatrends v: 0602 date: 03/02/2009
Battery:
ID-1: BAT0 charge: 55.3 Wh condition: 55.3/55.3 Wh (100%)
model: ASUS 1000HG status: Full
Info: Single Core model: Intel Atom N270 bits: 32 type: MT arch: Bonnell
rev: 2 L2 cache: 512 KiB
flags: nx pae sse sse2 sse3 ssse3 bogomips: 6399
Speed: 951 MHz min/max: 800/1600 MHz Core speeds (MHz): 1: 951 2: 1093
Device-1: Intel Mobile 945GSE Express Integrated Graphics vendor: ASUSTeK
driver: i915 v: kernel bus ID: 00:02.0
Device-2: Chicony 2.0M UVC Webcam / CNF7129 type: USB driver: uvcvideo
bus ID: 1-8:5
Display: x11 server: X.Org 1.20.11 driver: loaded: intel
unloaded: fbdev,modesetting,vesa resolution: 1024x600~65Hz
OpenGL: renderer: Mesa DRI Intel 945GME x86/MMX/SSE2 v: 1.4 Mesa 20.3.5
direct render: Yes
Device-1: Intel NM10/ICH7 Family High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Sound Server: ALSA v: k5.10.0-39-686-pae
Device-1: Qualcomm Atheros AR242x / AR542x Wireless Network Adapter
vendor: AzureWave AW-GE780 802.11bg driver: ath5k v: kernel port: ffa0
bus ID: 01:00.0
IF: wlan0 state: up mac: <filter>
IP v6: <filter> scope: link
Device-2: Qualcomm Atheros AR8121/AR8113/AR8114 Gigabit or Fast Ethernet
vendor: ASUSTeK driver: ATL1E v: N/A port: ec00 bus ID: 03:00.0
IF: eth0 state: down mac: <filter>
Bluetooth:
Device-1: ASUSTek Broadcom Bluetooth 2.1 type: USB driver: btusb v: 0.8
bus ID: 5-1:2
Report: ID: hci0 state: up running bt-v: 1.2 lmp-v: 2.1 address: <filter>
Local Storage: total: 149.05 GiB used: 8.72 GiB (5.9%)
ID-1: /dev/sda vendor: Seagate model: ST9160310AS size: 149.05 GiB
temp: 49 C
ID-1: / size: 144.71 GiB used: 8.53 GiB (5.9%) fs: ext4 dev: /dev/sda1
ID-1: swap-1 type: partition size: 976 MiB used: 200.9 MiB (20.6%)
dev: /dev/sda5
ID-2: swap-2 type: file size: 100 MiB used: 0 KiB (0.0%) file: /var/swap
System Temperatures: cpu: 53.0 C mobo: N/A
Fan Speeds (RPM): cpu: 1260
Processes: 158 Uptime: 42m Memory: 991.1 MiB used: 592.4 MiB (59.8%)
Init: systemd runlevel: 5 Compilers: gcc: 10.2.1 Packages: 2123
Shell: Bash v: 5.1.4 inxi: 3.3.01
ich schreibe gerade von meinem sehr alten und damals sehr geliebten eee PC.
Und ich liebe ihn beim Schreiben gleich wieder. ![]()
Die Tastatur ist für so ein kleines Gerät einfach fantastisch.
Leider hat er nur ein 32 Bit-System. (Installiert war noch Windows XP, weswegen er sehr lange unbenutzt im Schrank lag …)
Jetzt habe ich einfach mal Raspberry Pi Desktop (Debian 11) darauf installiert.
Hat weit über eine Stunde gedauert.
Okay, zum Schreiben kann man ihn noch gebrauchen …
Ich wollte auch immer mal ein Pi-hole als Werbeblocker haben.
Vielleicht kann ich auch das mit dem eee PC umsetzen. Was meint ihr?
Oder ein Media-Center?
Vorschläge, wie ich das mit dem Gerät umsetzen kann? Oder wäre das unsinnig?
Und falls ich ihn doch noch als Notebook nutzen mag:
Welche Distros können noch 32 Bit?
Auf den Elektro-Kompost soll mein eee noch lange nicht …
