- Distrowahl
- Linux Mint
- System:
Kernel: 6.8.0-90-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
Desktop: Cinnamon v: 6.6.7 Distro: Linux Mint 22.3 Zena
base: Ubuntu 24.04 noble
Type: Desktop Mobo: ASUSTeK model: H110M-A/M.2 v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4202
date: 02/28/2019
Info: quad core model: Intel Core i7-6700 bits: 64 type: MT MCP
arch: Skylake-S rev: 3 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
Speed (MHz): avg: 800 min/max: 800/4000 cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 bogomips: 54398
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Sapphire Nitro+ driver: amdgpu v: kernel arch: GCN-4 bus-ID: 01:00.0
temp: 48.0 C
resolution: 1: 1920x1080~60Hz 2: 1920x1080~60Hz
v: 25.2.8-0ubuntu0.24.04.1 glx-v: 1.4 direct-render: yes renderer: AMD
Radeon RX 580 Series (radeonsi polaris10 ACO DRM 3.57 6.8.0-90-generic)
Device-1: Intel 100 Series/C230 Series Family HD Audio
vendor: ASUSTeK H110I-PLUS driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Sapphire driver: snd_hda_intel v: kernel bus-ID: 01:00.1
API: ALSA v: k6.8.0-90-generic status: kernel-api
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL88x2bu [AC1200 Techkey] driver: rtl88x2bu type: USB
bus-ID: 2-3:2
IF: wlx145d34bd1832 state: up mac: <filter>
IF-ID-1: br-e45b7f01d2cf state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v4: <filter> scope: global
IP v6: <filter> scope: link
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: vethb67e5fa state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-4: virbr0 state: down mac: <filter>
Bluetooth:
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB
bus-ID: 1-8:9
lmp-v: 10
Local Storage: total: 1.84 TiB used: 416.73 GiB (22.1%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 1TB
size: 931.51 GiB temp: 29.9 C
ID-2: /dev/sda vendor: Orico model: N/A size: 953.87 GiB
ID-1: / size: 273.95 GiB used: 160.06 GiB (58.4%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 951.1 MiB used: 6.1 MiB (0.6%) fs: vfat
dev: /dev/sda1
ID-3: /home size: 661.9 GiB used: 256.67 GiB (38.8%) fs: ext4
dev: /dev/sda3
System Temperatures: cpu: 24.0 C mobo: N/A gpu: amdgpu temp: 48.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 750
Memory: total: 16 GiB available: 15.56 GiB used: 10.13 GiB (65.1%)
Processes: 315 Uptime: 34m Init: systemd target: graphical (5)
Packages: 2505 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Hallo zusammen,
ich habe Linux Mint 22.3 auf einem älteren Rechner auf einer SSD installiert und der aktuelle Kernel ist 6.8.0.90-generic. Durch die Aktualisierungsverwaltung wurden inzwischen die Kernel mit der Endung .106 und auch .107 installiert. Jedoch wurden diese nicht aktiviert. Bisher wurden die Kernel immer automatisch auf die neueste Version (von .53 auf .56 dann auf .90) aktualisiert. Jetzt jedoch nicht mehr.
Selbst ein "sudo update-initramfs -u -k all && sudo update-grub" hat mir bisher nicht geholfen. Im Grub-Menu erscheinen die neueren Kernel nicht.
Ein dpkg --list | grep linux-image ergibt:
ii linux-image-6.8.0-106-generic 6.8.0-106.106 amd64 Signed kernel image generic
ii linux-image-6.8.0-107-generic 6.8.0-107.107 amd64 Signed kernel image generic
ii linux-image-6.8.0-51-generic 6.8.0-51.52 amd64 Signed kernel image generic
ii linux-image-6.8.0-52-generic 6.8.0-52.53 amd64 Signed kernel image generic
ii linux-image-6.8.0-53-generic 6.8.0-53.55 amd64 Signed kernel image generic
rc linux-image-6.8.0-54-generic 6.8.0-54.56 amd64 Signed kernel image generic
rc linux-image-6.8.0-55-generic 6.8.0-55.57 amd64 Signed kernel image generic
ii linux-image-6.8.0-56-generic 6.8.0-56.58+1 amd64 Signed kernel image generic
rc linux-image-6.8.0-57-generic 6.8.0-57.59 amd64 Signed kernel image generic
rc linux-image-6.8.0-58-generic 6.8.0-58.60+1 amd64 Signed kernel image generic
rc linux-image-6.8.0-59-generic 6.8.0-59.61 amd64 Signed kernel image generic
ii linux-image-6.8.0-60-generic 6.8.0-60.63 amd64 Signed kernel image generic
rc linux-image-6.8.0-63-generic 6.8.0-63.66 amd64 Signed kernel image generic
rc linux-image-6.8.0-85-generic 6.8.0-85.85 amd64 Signed kernel image generic
rc linux-image-6.8.0-87-generic 6.8.0-87.88 amd64 Signed kernel image generic
ii linux-image-6.8.0-90-generic 6.8.0-90.91 amd64 Signed kernel image generic
ii linux-image-generic 6.8.0-107.107 amd64 Generic Linux kernel image
Display More
Ein cat /etc7default grub ergibt:
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
# info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=hidden
GRUB_TIMEOUT=0
GRUB_DISTRIBUTOR=`( . /etc/os-release; echo ${NAME:-Ubuntu} ) 2>/dev/null echo Ubuntu`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
# If your computer has multiple operating systems installed, then you
# probably want to run os-prober. However, if your computer is a host
# for guest OSes installed via LVM or raw disk devices, running
# os-prober can cause damage to those guest OSes as it mounts
# filesystems to look for things.
#GRUB_DISABLE_OS_PROBER=false
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=640x480
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY="true"
# Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
Display More
Ich denke, es ist wahrscheinlich nur eine Kleinigkeit, aber die muss ich erst mal finden.
Für Hinweise bin ich dankbar.
Gruß Pumba
P.S. Den blöden Smiley bei GRUB_DISTRIBUTOR habe ich nicht eingefügt, dort sollten eigentlich zwei Pipe-Symbole hintereinander stehen.
