Nach Monitorwechsel blackscreen mit blinkendem curser bis auf dem bildschirm kommt HDMI kein signal
    Sonstiges
    $ inxi -Fzxi
    Kernel: 6.18.13-330.current arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    Desktop: Xfce v: 4.20.1 Distro: Solus 4.8 opportunity
    Type: Desktop System: LENOVO product: 90G900B7GE v: ideacentre 310S-08ASR
    serial: <superuser required>
    Mobo: LENOVO model: 36F7 v: SDK0J40700 WIN 3258172169990
    serial: <superuser required> Firmware: UEFI-[Legacy] vendor: LENOVO
    v: O2HKT65A date: 04/15/2020
    Info: dual core model: AMD A6-9225 RADEON R4 5 COMPUTE CORES 2C+3G bits: 64
    type: MCP arch: Excavator rev: 0 cache: L1: 256 KiB L2: 2 MiB
    Speed (MHz): avg: 2991 min/max: 1300/2600 boost: enabled cores: 1: 2991
    2: 2991 bogomips: 10381
    Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a
    ssse3 svm
    Device-1: Advanced Micro Devices [AMD/ATI] Stoney [Radeon R2/R3/R4/R5
    Graphics] vendor: Lenovo driver: N/A arch: GCN-3 bus-ID: 00:01.0
    Display: x11 server: X.Org v: 21.1.21 with: Xwayland v: 24.1.9 driver: N/A
    resolution: 1920x1080
    API: EGL v: 1.5 drivers: swrast platforms: active: x11,surfaceless,device
    inactive: gbm,wayland
    API: OpenGL v: 4.5 vendor: mesa v: 26.0.3 glx-v: 1.4 direct-render: yes
    renderer: llvmpipe (LLVM 20.1.8 256 bits)
    Info: Tools: api: eglinfo,glxinfo de: xfce4-display-settings
    gpu: amdgpu_top x11: xdpyinfo, xprop, xrandr
    Device-1: Advanced Micro Devices [AMD/ATI] Stoney HDMI/DP Audio
    vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:01.1
    Device-2: Advanced Micro Devices [AMD] Family 15h Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel bus-ID: 00:09.2
    API: ALSA v: k6.18.13-330.current status: kernel-api
    Server-1: sndiod v: N/A status: off
    Server-2: PipeWire v: 1.6.2 status: active
    Server-3: PulseAudio v: 17.0 status: off (using pipewire-pulse)
    Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
    vendor: Lenovo driver: rtw88_8821ce v: kernel port: e000 bus-ID: 01:00.0
    IF: wlp1s0 state: down mac: <filter>
    vendor: Lenovo driver: r8169 v: kernel port: d000 bus-ID: 02:00.0
    IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
    Bluetooth:
    Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB
    bus-ID: 1-3:2
    Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
    rfk-block: hardware: no software: yes address: see --recommends
    Local Storage: total: 2.05 TiB used: 32.63 GiB (1.6%)
    ID-1: /dev/sda vendor: Samsung model: MZ7LN256HAJQ-000L7 size: 238.47 GiB
    ID-2: /dev/sdb vendor: Toshiba model: MQ04UBD200 size: 1.82 TiB type: USB
    ID-1: / size: 57.37 GiB used: 32.63 GiB (56.9%) fs: ext4 dev: /dev/sda5
    ID-1: swap-1 type: zram size: 7.18 GiB used: 0 KiB (0.0%) dev: /dev/zram0
    System Temperatures: cpu: 45.9 C mobo: N/A
    Fan Speeds (rpm): N/A
    Memory: total: 8 GiB note: est. available: 7.18 GiB used: 946.4 MiB (12.9%)
    Processes: 189 Uptime: 10m Init: systemd
    Packages: 1258 Compilers: gcc: 15.2.1 Shell: Bash v: 5.3.9 inxi: 3.3.40
    moin zusammen
    ich hab hier einen rechner, der einwandfrei lief, tausche den monitor und wenn ich jetzt boote, kommt ein blackscreen mit curser danach "HDMI - kein signal" auf dem monitor. das system startet aber durch. ich kann im blindflug sogar ein terminal öffnen und befehle ausführen
    wenn ich als bootparameter im grub nomodeset mitgebe, dann geht es, aber er erkennt den monitor so gar nicht. nur durch zufall bietet er 1920x1080 als auflösung an in xfce unter anzeige wodurch im grunde alles geht, außer dass man das hintergrundbild nicht wechseln kann und so kleinigkeiten nicht mehr so gut laufen (ich hab das gefühl, die hardwarebeschleunigung im browser funktioniert nicht)
    der rechner ist ein lenovo thinkcentre, so ein standard bürorechner ( 90G900B7GE (ideacentre 310S-08))
    das system ist solus, das sollte aber keinen großen unterscheid machen
    schubst mich mal bitte in die richtige richtung, wie ich da jetzt weiter vorgehe
    ich bin bereits auf den lts kernel gewechselt, ohne änderung, hab versucht, irgendwelche grafiktreiber sachen nachzuinstallieren, aber das war mehr raten als tatsächlich wissen, hab mich einmal quer durch's bios gefräst, aber da ist auch nix zu finden, oder ich seh es einfach nicht
    der monitor selbst, wenn ich den an meinen laptop anstöpsel, wird er direkt erkannt und funktioniert, anschluss erfolgt über HDMI, vorher am rechner war es allerdings so ein adapter von HDMI auf DVI, da der alte monitor keinen HDMI hatte. kann es daran liegen? und wenn, was macht man da?
    viele Grüße aus dem Norden
  • Ich sage mal so, wenn du jetzt entweder einen Grafiktreiber für deine Graka installierst, und das nomodeset herausnimmst, dann sollte es wohl gehen.
    Anstelle von nomodeset kannst du auch amdgpu.dc=1 radeon.si_support=0 radeon.cik_support=0 amdgpu.si_support=1 amdgpu.cik_support=1 probieren
    MfG Nico
  • Ich tippe auf den Monitor.
    Ist der neu oder gebraucht?
    Eventuell ist da irgend etwas eingestellt, sollte zwar nch dem Stromlos machen nicht sein, aber ich habe schon so viel erlebt.
    Hat er bei den Tasten Menü usw. auch eine Auto Taste?
    Versuche die mal zu drücken währen du einschaltest ....
    der ist neu gekauft, aber so ein billig teil
    und er hat nur so ein jog-wheel ding hinten dran
    wenn ich mit nomodeset starte kann ich auch das OSD alles bedienen oder wahlweise den eingang wechseln usw. das geht alles, ohne nomodeset macht er gar nix
    äh, wie würde ich das wohl machen???
    das werd ich gleich noch probieren
    danke erstmal
  • Nachtrag:
    hat auch nix gebracht -> HDMI - kein signal
  • Moin,
    bei manchen Geräten gibt es Timing Probleme, so dass das mit HDMI nicht immer funktioniert. Z.B. laufen einiges Raspberry's auch nicht an bestimmten Monitoren bei uns im Verein. Ich hab das das für mich mit Hardware, einem DSC 301 HD von Extron erschlagen. Damit bekomme ich jedes "Schweinesignal" auf HDMI sauber angezeigt, und natürlich auch HDMI auf HDMI . So mache ich mir einfach keinen Kopf mehr vom neue Monitore : - )
    LG Olav
    Schwerpunkt KI-Projekte: Lokale LLMs, Ollama, RAG, Agenten: Opencode, FredTux
    Weitere Projekte auf Github: https://github.com/o-valo?tab=repositories
    Hardware: Lenovo T450 (Alltagslaptop) | AMD Ryzen 5 2600, 32GB, RTX 5060 16GB vRAM | AMD Ryzen 5 5500U, 16GB RAM | | Raspberry Pi 5 (8GB) | 3x Proxmox Nodes
    geeignet sind.
  • vorher am rechner war es allerdings so ein adapter von HDMI auf DVI, da der alte monitor keinen HDMI hatte. kann es daran liegen? und wenn, was macht man da?
    Also ich schätze mal, dass da der Hund begraben ist. Irgendwo ist die Signalquelle falsch eingestellt. Entweder am Monitor oder innerhalb der Rechnerkonfiguration. (Leider kenne ich mich mit Solus aber nicht aus.)
    Die Grafikkarte findet den Monitor jetzt nicht und stattdessen läuft die Bildausgabe nur über eine Notfallgrafik, die natürlich ohne volle Grafikleistung daherkommt. (Ist so als wäre gar keine echte Grafikkarte eingebaut.)
    Der Monitor samt Kabelverbindung müsste ok sein. Denn am anderen Rechner funktioniert er ja anscheinend.
  • Zeigst du uns das mal nur mal um zu sehen ob überhaupt ein edid Status zustande kommt.
    xrandr --verbose
    thx
    xrandr --verbose
    Screen 0: minimum 640 x 480, current 1920 x 1080, maximum 1920 x 1080
    default connected 1920x1080+0+0 (0x232) normal (normal) 0mm x 0mm
    Identifier: 0x231
    Timestamp: 8849
    Subpixel: horizontal rgb
    Gamma: 1.0:1.0:1.0
    Brightness: 0.0
    Clones:
    CRTC: 0
    CRTCs: 0
    Transform: 1.000000 0.000000 0.000000
    0.000000 1.000000 0.000000
    0.000000 0.000000 1.000000
    filter:
    non-desktop: 0
    supported: 0, 1
    1920x1080 (0x232) 0.000MHz *current
    h: width 1920 start 0 end 0 total 1920 skew 0 clock 0.00KHz
    v: height 1080 start 0 end 0 total 1080 clock 0.00Hz
    640x480 (0x233) 0.000MHz
    h: width 640 start 0 end 0 total 640 skew 0 clock 0.00KHz
    v: height 480 start 0 end 0 total 480 clock 0.00Hz
  • /su live system hab ich probiert, das gleiche problem
    @r00t auch anderes kabel hab ich probiert, genau so, an meinem laptop geht es instant, am pc überhaupt nix
    mit dem alten monitor keine probleme
    ich versteh es nicht ich weiß auch nicht, warum ich es nicht verstehe
    ich hatte gehofft, ich hab irgendwo einen denkfehler oder eine gewaltige macke drin in meinem troubleshoot prozess oder sowas
    aber trotzdem danke an alle, die sich hier eine rübe machen :)
