- Distrowahl
- Sonstiges
- System:
Kernel: 6.8.0-101-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
base: Ubuntu 24.04 noble
Mobo: ASUSTeK model: TUF GAMING B550-PLUS WIFI II v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3621
date: 01/13/2025
Info: 6-core model: AMD Ryzen 5 5600 bits: 64 type: MT MCP arch: Zen 3+
rev: 2 cache: L1: 384 KiB L2: 3 MiB L3: 32 MiB
Speed (MHz): avg: 2204 high: 2261 min/max: 2200/4469 boost: enabled cores:
1: 2200 2: 2200 3: 2200 4: 2200 5: 2196 6: 2200 7: 2200 8: 2261 9: 2200
10: 2200 11: 2200 12: 2200 bogomips: 83848
Device-1: NVIDIA AD106 [GeForce RTX 4060 Ti] vendor: CardExpert
driver: nvidia v: 580.126.09 arch: Lovelace bus-ID: 07:00.0
gpu: nv_platform,nvidia,nvidia-nvswitch resolution: 1920x1080~60Hz
API: EGL v: 1.5 drivers: nvidia,swrast platforms:
active: gbm,x11,surfaceless,device inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.126.09
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4060 Ti/PCIe/SSE2
Device-1: NVIDIA vendor: CardExpert driver: snd_hda_intel v: kernel
bus-ID: 07:00.1
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 09:00.4
API: ALSA v: k6.8.0-101-generic status: kernel-api
Device-1: Realtek RTL8852BE PCIe 802.11ax Wireless Network vendor: AzureWave
driver: rtw89_8852be v: kernel port: e000 bus-ID: 05:00.0
IF: wlp5s0 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
port: d000 bus-ID: 06:00.0
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth:
Device-1: IMC Networks Bluetooth Radio driver: btusb v: 0.8 type: USB
bus-ID: 1-5:2
lmp-v: 12
Local Storage: total: 1.38 TiB used: 413.58 GiB (29.4%)
ID-1: /dev/nvme0n1 vendor: Kingston model: SNV2S1000G size: 931.51 GiB
temp: 35.9 C
ID-2: /dev/sda vendor: Kingston model: RBUSNS8180S3512GJ size: 476.94 GiB
ID-1: / size: 321.55 GiB used: 251.68 GiB (78.3%) fs: ext4
dev: /dev/nvme0n1p2
System Temperatures: cpu: 47.6 C mobo: N/A gpu: nvidia temp: 52 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Memory: total: 32 GiB available: 31.24 GiB used: 6.68 GiB (21.4%)
Processes: 445 Uptime: 6h 39m Init: systemd target: graphical (5)
Packages: 3807 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Hallo zusammen, ich brauche Hilfe bei einer "Operation am offenen Herzen".
Das Ziel: Ich möchte meine NVMe komplett löschen und dort Pop!_OS frisch installieren.
Die Bedingung: Zuvor müsste mein altes Pop!_OS auf der SATA-Platte (sda4) absolut sicher und autark booten, damit ich während der Einrichtung auf der NVMe eine stabile Arbeitsumgebung behalte.
Das Problem: Durch das Klonen haben sda1 (EFI) und nvme0n1p1 identische UUIDs. Auch die Root-Partitionen (sda4/nvme0n1p4) sind Klone. Mein UEFI-Bootmanager (efibootmgr) ist zudem "geflutet" mit alten Einträgen (Fedora, Ubuntu). Aktuell boote ich nur per GRUB-Krücke.
Hier sind die Fakten für die Analyse:
ininer@ininer-System-Product-Name:~$ lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
sda
├─sda1
│ vfat FAT32 70C4-CE71
├─sda4
│ ext4 1.0 POP_OS f391e3a4-02b1-48d6-b436-c4585f665dfa
├─sda5
│ ntfs Wilux 541E268C3A102232
└─sda6
vfat FAT32 A58E-FA8A
nvme0n1
├─nvme0n1p1
├─nvme0n1p2
│ ext4 1.0 MINT 08ff89ba-12ff-4010-b495-8532693a33a1 65,8G 74% /
├─nvme0n1p3
│ ext4 1.0 share fe0dde0c-3757-49c6-a455-e1bb7d6f7a4a 168,7G 29% /media/ininer/share1
└─nvme0n1p4
ininer@ininer-System-Product-Name:~$ cat /etc/fstab
UUID=08ff89ba-12ff-4010-b495-8532693a33a1 / ext4 defaults 0 1
ininer@ininer-System-Product-Name:~$ sudo efibootmgr -v
[sudo] Passwort für ininer:
BootCurrent: 0000
Timeout: 1 seconds
BootOrder: 0000,0007,0008,000B,0003,000D,000C,0001,0002,0004
Boot0000* Ubuntu HD(6,GPT,7ab2d6e8-bfe4-4b17-9a64-66756c334f78,0x3b7f8800,0x1e87ff)/File(\EFI\POPOS-SICHERUNG\SHIMX64.EFI)
dp: 04 01 2a 00 06 00 00 00 00 88 7f 3b 00 00 00 00 ff 87 1e 00 00 00 00 00 e8 d6 b2 7a e4 bf 17 4b 9a 64 66 75 6c 33 4f 78 02 02 / 04 04 46 00 5c 00 45 00 46 00 49 00 5c 00 50 00 4f 00 50 00 4f 00 53 00 2d 00 53 00 49 00 43 00 48 00 45 00 52 00 55 00 4e 00 47 00 5c 00 53 00 48 00 49 00 4d 00 58 00 36 00 34 00 2e 00 45 00 46 00 49 00 00 00 / 7f ff 04 00
Boot0001* UEFI:CD/DVD Drive BBS(129,,0x0)
dp: 05 01 09 00 81 00 00 00 00 / 7f ff 04 00
Boot0002* UEFI:Removable Device BBS(130,,0x0)
dp: 05 01 09 00 82 00 00 00 00 / 7f ff 04 00
Boot0003* Ubuntu HD(1,GPT,42471ba7-478e-4d85-b1fd-65aa66101dc5,0x800,0x100000)/File(\EFI\GRUB\SHIMX64.EFI)
dp: 04 01 2a 00 01 00 00 00 00 08 00 00 00 00 00 00 00 00 10 00 00 00 00 00 a7 1b 47 42 8e 47 85 4d b1 fd 65 aa 66 10 1d c5 02 02 / 04 04 30 00 5c 00 45 00 46 00 49 00 5c 00 47 00 52 00 55 00 42 00 5c 00 53 00 48 00 49 00 4d 00 58 00 36 00 34 00 2e 00 45 00 46 00 49 00 00 00 / 7f ff 04 00
Boot0004* UEFI:Network Device BBS(131,,0x0)
dp: 05 01 09 00 83 00 00 00 00 / 7f ff 04 00
Boot0007* Pop!_OS 22.04 LTS HD(6,GPT,7ab2d6e8-bfe4-4b17-9a64-66756c334f78,0x3b7f8800,0x1e87ff)/File(\EFI\SYSTEMD\SYSTEMD-BOOTX64.EFI)
dp: 04 01 2a 00 06 00 00 00 00 88 7f 3b 00 00 00 00 ff 87 1e 00 00 00 00 00 e8 d6 b2 7a e4 bf 17 4b 9a 64 66 75 6c 33 4f 78 02 02 / 04 04 46 00 5c 00 45 00 46 00 49 00 5c 00 53 00 59 00 53 00 54 00 45 00 4d 00 44 00 5c 00 53 00 59 00 53 00 54 00 45 00 4d 00 44 00 2d 00 42 00 4f 00 4f 00 54 00 58 00 36 00 34 00 2e 00 45 00 46 00 49 00 00 00 / 7f ff 04 00
Boot0008* UEFI OS HD(6,GPT,7ab2d6e8-bfe4-4b17-9a64-66756c334f78,0x3b7f8800,0x1e87ff)/File(\EFI\BOOT\BOOTX64.EFI)0000424f
dp: 04 01 2a 00 06 00 00 00 00 88 7f 3b 00 00 00 00 ff 87 1e 00 00 00 00 00 e8 d6 b2 7a e4 bf 17 4b 9a 64 66 75 6c 33 4f 78 02 02 / 04 04 30 00 5c 00 45 00 46 00 49 00 5c 00 42 00 4f 00 4f 00 54 00 5c 00 42 00 4f 00 4f 00 54 00 58 00 36 00 34 00 2e 00 45 00 46 00 49 00 00 00 / 7f ff 04 00
data: 00 00 42 4f
Boot000B* ubuntu HD(1,GPT,42471ba7-478e-4d85-b1fd-65aa66101dc5,0x800,0x100000)/File(\EFI\UBUNTU\SHIMX64.EFI)0000424f
dp: 04 01 2a 00 01 00 00 00 00 08 00 00 00 00 00 00 00 00 10 00 00 00 00 00 a7 1b 47 42 8e 47 85 4d b1 fd 65 aa 66 10 1d c5 02 02 / 04 04 34 00 5c 00 45 00 46 00 49 00 5c 00 55 00 42 00 55 00 4e 00 54 00 55 00 5c 00 53 00 48 00 49 00 4d 00 58 00 36 00 34 00 2e 00 45 00 46 00 49 00 00 00 / 7f ff 04 00
data: 00 00 42 4f
Boot000C* Hard Drive BBS(HD,,0x0)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
dp: 05 01 09 00 02 00 00 00 00 / 7f ff 04 00
data: 00 00 47 4f 00 00 4e 4f bd 00 00 00 01 00 00 00 75 00 4b 00 49 00 4e 00 47 00 53 00 54 00 4f 00 4e 00 20 00 52 00 42 00 55 00 53 00 4e 00 53 00 38 00 31 00 38 00 30 00 53 00 33 00 35 00 31 00 32 00 47 00 4a 00 00 00 05 01 09 00 02 00 00 00 00 7f ff 04 00 02 01 0c 00 d0 41 03 0a 00 00 00 00 01 01 06 00 02 01 01 01 06 00 01 00 03 12 0a 00 04 00 ff ff 00 00 7f ff 04 00 01 04 3e 00 ef 47 64 2d c9 3b a0 41 ac 19 4d 51 d0 1b 4c e6 30 00 35 00 32 00 30 00 42 00 36 00 36 00 37 00 33 00 38 00 36 00 39 00 42 00 33 00 46 00 44 00 20 00 20 00 20 00 20 00 00 00 7f ff 04 00 00 00 42 4f 00 00 4e 4f ad 00 00 00 01 00 00 00 73 00 4b 00 49 00 4e 00 47 00 53 00 54 00 4f 00 4e 00 20 00 53 00 4e 00 56 00 32 00 53 00 31 00 30 00 30 00 30 00 47 00 00 00 05 01 09 00 02 00 00 00 00 7f ff 04 00 02 01 0c 00 d0 41 03 0a 00 00 00 00 01 01 06 00 01 01 01 01 06 00 00 00 03 17 10 00 01 00 00 00 00 26 b7 38 2e 82 26 85 7f ff 04 00 01 04 36 00 ef 47 64 2d c9 3b a0 41 ac 19 4d 51 d0 1b 4c e6 35 00 30 00 30 00 32 00 36 00 42 00 37 00 33 00 38 00 32 00 45 00 38 00 32 00 32 00 36 00 38 00 00 00 7f ff 04 00 00 00 42 4f
Boot000D* Fedora HD(1,GPT,42471ba7-478e-4d85-b1fd-65aa66101dc5,0x800,0x100000)/File(\EFI\FEDORA\SHIM.EFI)0000424f
dp: 04 01 2a 00 01 00 00 00 00 08 00 00 00 00 00 00 00 00 10 00 00 00 00 00 a7 1b 47 42 8e 47 85 4d b1 fd 65 aa 66 10 1d c5 02 02 / 04 04 2e 00 5c 00 45 00 46 00 49 00 5c 00 46 00 45 00 44 00 4f 00 52 00 41 00 5c 00 53 00 48 00 49 00 4d 00 2e 00 45 00 46 00 49 00 00 00 / 7f ff 04 00
data: 00 00 42 4f
Wie entkopple ich sda1/sda4 am saubersten von der NVMe, ohne dass beim nächsten Boot der Bildschirm schwarz bleibt? Danke für eure Expertise!
