- Distrowahl
- Linux Mint
- System:
Kernel: 6.17.0-14-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
Desktop: Cinnamon v: 6.6.7 Distro: Linux Mint 22.3 Zena
base: Ubuntu 24.04 noble
Type: Desktop System: MEDION product: P63007 v: N/A
serial: <superuser required>
Mobo: MEDION model: B460H6-EM v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: 460H6W0X.105 date: 05/19/2020
Battery:
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
charge: 55% (should be ignored) status: discharging
Info: 6-core model: Intel Core i5-10400 bits: 64 type: MT MCP
arch: Comet Lake rev: 3 cache: L1: 384 KiB L2: 1.5 MiB L3: 12 MiB
Speed (MHz): avg: 3516 high: 4101 min/max: 800/4300 cores: 1: 3800 2: 4086
3: 800 4: 4087 5: 4099 6: 4058 7: 4099 8: 4098 9: 800 10: 4101 11: 4100
12: 4074 bogomips: 69597
Device-1: Intel CometLake-S GT2 [UHD Graphics 630] vendor: MEDION AG
driver: i915 v: kernel arch: Gen-9.5 bus-ID: 00:02.0
resolution: 1920x1080~60Hz
v: 25.2.8-0ubuntu0.24.04.1 glx-v: 1.4 direct-render: yes renderer: Mesa
Intel UHD Graphics 630 (CML GT2)
Device-1: Intel Comet Lake PCH-V cAVS vendor: MEDION AG
API: ALSA v: k6.17.0-14-generic status: kernel-api
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 02:00.0
IF: wlp2s0 state: up mac: <filter>
vendor: MEDION AG RTL8111/8168/8411 driver: r8169 v: kernel port: 3000
bus-ID: 03:00.0
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-3: Ralink MT7610U (Archer T2U 2.4G+5G WLAN Adapter driver: mt76x0u
type: USB bus-ID: 1-8.4:8
IF: wlx8416f91ced14 state: up mac: <filter>
Bluetooth:
Device-1: Intel AX200 Bluetooth driver: btusb v: 0.8 type: USB
bus-ID: 1-10:5
Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
lmp-v: 11
Local Storage: total: 3.66 TiB used: 1.34 TiB (36.7%)
ID-1: /dev/nvme0n1 vendor: Phison model: E12-1TB-SSD-B27-BB1
size: 953.87 GiB temp: 29.9 C
ID-2: /dev/sda vendor: Toshiba model: MQ04ABD200 size: 1.82 TiB type: USB
ID-3: /dev/sdc vendor: Toshiba model: MQ01UBD100 size: 931.51 GiB
type: USB
ID-1: / size: 239.25 GiB used: 47.92 GiB (20.0%) fs: ext4
dev: /dev/nvme0n1p7
ID-2: /boot/efi size: 96 MiB used: 31.6 MiB (32.9%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: file size: 2 GiB used: 8 KiB (0.0%) file: /swapfile
System Temperatures: cpu: 53.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 16 GiB note: est. available: 15.36 GiB used: 7.31 GiB (47.6%)
Processes: 390 Uptime: 1d 8h 49m Init: systemd target: graphical (5)
Packages: 2716 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Moin zusammen,
ich habe hier schon alles durchforstet, aber entweder nutze ich die falschen Suchbegriffe oder ich habe eine neue Technik erfunden:
Ich habe für mein Mint /home nachträglich in eine Partition mit ext4 auf einer externen USB-Festplatte erstellt. (Warum extern und USB? Sollte nur vorübergehend sein, bis ich die noch vorhandene Windows 10-Partition endgültig lösche und daraus mein /home erstelle - so ich denn Mint erstmal in den Griff bekomme). Darin sind natürlich auch alle Ordner (wie Downloads, Dokumente, Bilder etc... - außer Schreibtisch natürlich), die in der Systempartition von Mint nur als Verknüpfung vorhanden sind.
Auf dieser Festplatte ist auch noch eine zweite Partition mit Fat (s. Bilder).
Nun mein Problem:
Alle Nase lang und ohne (reproduzierbaren) Anlass verliert die ext4-Partition Zugriffsrechte (nur noch lesen möglich), die Fat-Partition aber behält alle Rechte. Damit - und mit dem Versuch, verschiedene USB-Ports zu nutzen - kann ich Hardwareprobleme ausschließen.
Hat jemand eine Idee, wie ich das beheben kann? Bis jetzt sieht die Lösung so aus:
Nemo aufrufen -> Partition aushängen -> Partition einhängen -> Nemo schließen -> abwarten bis es wieder passiert... Das ist für mich keine echte Lösung.
Für Hilfe wäre ich echt dankbar, denn das ist wirklich ein sehr, sehr nerviger Fehler.
Lasst oich nicht ärgern!
LG Joe
