- Distrowahl
- Ubuntu
- System:
Kernel: 6.17.0-14-generic arch: x86_64 bits: 64 compiler: gcc v: 15.2.0
Desktop: KDE Plasma v: 6.4.5 Distro: Kubuntu 25.10 (Questing Quokka)
base: Ubuntu
Type: Desktop Mobo: ASRock model: B650M-H/M.2+ serial: <superuser required>
UEFI: American Megatrends LLC. v: 3.10 date: 10/25/2024
Info: 12-core model: AMD Ryzen 9 7900 bits: 64 type: MT MCP arch: Zen 4
rev: 2 cache: L1: 768 KiB L2: 12 MiB L3: 64 MiB
Speed (MHz): avg: 3007 min/max: 430/5485 boost: enabled cores: 1: 3007
2: 3007 3: 3007 4: 3007 5: 3007 6: 3007 7: 3007 8: 3007 9: 3007 10: 3007
11: 3007 12: 3007 13: 3007 14: 3007 15: 3007 16: 3007 17: 3007 18: 3007
19: 3007 20: 3007 21: 3007 22: 3007 23: 3007 24: 3007 bogomips: 177262
Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a
ssse3 svm
Device-1: Advanced Micro Devices [AMD/ATI] Navi 32 [Radeon RX 7700 XT /
7800 XT] vendor: XFX driver: amdgpu v: kernel arch: RDNA-3 bus-ID: 03:00.0
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: ASRock
driver: amdgpu v: kernel arch: RDNA-2 bus-ID: 12:00.0 temp: 2.0 C
Display: wayland server: X.org v: 1.21.1.18 with: Xwayland v: 24.1.6
unloaded: fbdev,modesetting,radeon,vesa dri: radeonsi gpu: amdgpu
resolution: 3840x2160~60Hz
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.3-1ubuntu1
glx-v: 1.4 direct-render: yes renderer: AMD Ryzen 9 7900 12-Core Processor
(radeonsi raphael_mendocino LLVM 20.1.8 DRM 3.64 6.17.0-14-generic)
API: Vulkan v: 1.4.321 drivers: radv,llvmpipe surfaces: xcb,xlib,wayland
devices: 3
de: kscreen-console,kscreen-doctor wl: wayland-info x11: xdriinfo,
xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
driver: snd_hda_intel v: kernel bus-ID: 03:00.1
Device-2: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
[Rembrandt/Strix] driver: snd_hda_intel v: kernel bus-ID: 12:00.1
Device-3: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
vendor: ASRock driver: snd_hda_intel v: kernel bus-ID: 12:00.6
API: ALSA v: k6.17.0-14-generic status: kernel-api
Server-1: PipeWire v: 1.4.7 status: active
vendor: ASRock driver: r8169 v: kernel port: e000 bus-ID: 09:00.0
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 3.65 TiB used: 22.96 GiB (0.6%)
ID-1: /dev/nvme0n1 vendor: Kingston model: SNV3S4000G size: 3.64 TiB
temp: 36.9 C
ID-2: /dev/sda vendor: SanDisk model: USB 3.2Gen1 size: 14.61 GiB
type: USB
ID-1: / size: 150 GiB used: 22.92 GiB (15.3%) fs: btrfs dev: /dev/nvme0n1p5
ID-2: /boot/efi size: 96 MiB used: 38.8 MiB (40.4%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 150 GiB used: 22.92 GiB (15.3%) fs: btrfs
dev: /dev/nvme0n1p5
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%)
file: /swap/swapfile
System Temperatures: cpu: 34.1 C mobo: N/A
Fan Speeds (rpm): N/A
GPU: device: amdgpu temp: 3.0 C device: amdgpu temp: 36.0 C fan: 120
Memory: total: 32 GiB note: est. available: 30.43 GiB used: 3.93 GiB (12.9%)
Processes: 520 Uptime: 4m Init: systemd
Packages: 2300 Compilers: N/A Shell: Bash v: 5.2.37 inxi: 3.3.39
Ich richte gerade einen neuen PC ein (Kubuntu 25.10, Plasma 6.4.5, KDE-Framework 6.17.0, Qt 6.9.2, Wayland).
Dolphin und Kate halten sich an die Fensterregeln (Grösse, Position, Arbeitsfläche). Brave wird immer in Arbeitsfläche 4 statt 1 geöffnet, Vollbild wird beachtet. Ich habe auch Angeforderte Geometrie ignorieren aktiviert, das änderte nichts.
Was mache ich falsch?
