- Distrowahl
- Linux Mint
- irk@Mint-NB:~$ inxi -Fzxi
Kernel: 6.8.0-100-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
Desktop: Cinnamon v: 6.6.7 Distro: Linux Mint 22.3 Zena
base: Ubuntu 24.04 noble
Type: Laptop System: Wortmann_AG product: 1220680;1470327 v: 1716;1470327
serial: <superuser required>
Mobo: Clevo model: NJ70CU serial: <superuser required> UEFI: INSYDE
v: 1.07.17ITWO8 date: 10/24/2019
Battery:
ID-1: BAT0 charge: 33.9 Wh (100.0%) condition: 33.9/40.1 Wh (84.5%)
volts: 16.6 min: 14.6 model: Notebook BAT status: full
Info: quad core model: Intel Core i5-10210U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check rev: C cache: L1: 256 KiB L2: 1024 KiB
L3: 6 MiB
Speed (MHz): avg: 800 high: 805 min/max: 400/4200 cores: 1: 800 2: 800
3: 805 4: 800 5: 799 6: 800 7: 800 8: 800 bogomips: 33599
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: CLEVO/KAPOK
driver: i915 v: kernel arch: Gen-9.5 bus-ID: 00:02.0
Device-2: Bison BisonCam NB Pro driver: uvcvideo type: USB bus-ID: 1-1:2
resolution: 1920x1080~60Hz
v: 25.2.8-0ubuntu0.24.04.1 glx-v: 1.4 direct-render: yes renderer: Mesa
Intel UHD Graphics (CML GT2)
Device-1: Intel Comet Lake PCH-LP cAVS vendor: CLEVO/KAPOK
API: ALSA v: k6.8.0-100-generic status: kernel-api
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3
IF: wlp0s20f3 state: up mac: <filter>
Device-2: Intel Ethernet I219-V vendor: SAP driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6
IF: enp0s31f6 state: down mac: <filter>
Bluetooth:
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb
v: 0.8 type: USB bus-ID: 1-10:4
lmp-v: 10
Local Storage: total: 931.52 GiB used: 416.03 GiB (44.7%)
ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB
ID-2: /dev/sdb vendor: Western Digital model: WDS500G2B0B-00YS70
ID-1: / size: 456.89 GiB used: 416.02 GiB (91.1%) fs: ext4 dev: /dev/sdb2
ID-2: /boot/efi size: 511 MiB used: 6.1 MiB (1.2%) fs: vfat dev: /dev/sdb1
System Temperatures: cpu: 40.0 C pch: 39.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 16 GiB available: 15.44 GiB used: 3.02 GiB (19.6%)
Processes: 294 Uptime: 21m Init: systemd target: graphical (5)
Packages: 2951 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
dirk@Mint-NB:~$
bin erst kurz dabei, und habe folgende Probleme.
1. VLC Player erkennt im Netztwerk mein Technisat Digitradio 143 CD nicht. Mit Kodi kann ich ohne Probleme Musik vom Laptop an das Radio senden, bekomme es aber nicht hin mit VLC.
2. VLC Player Filme abspielen mit Chromecaststick am TV geht sehr gut und einfach. Wird die Firewall eingeschaltet geht gar nix. Keine Ahnung warum. Einige Regeln in der Firewall freigegeben, nützt aber nix.
LG
Dirk
