- Distrowahl
- Linux Mint
- mikulas@Linux-Mint:~$ inxi -Fzxi
Kernel: 6.8.0-100-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
Desktop: Cinnamon v: 6.6.6 Distro: Linux Mint 22.3 Zena
base: Ubuntu 24.04 noble
Type: Desktop Mobo: ASUSTeK model: P8H61-M LE v: Rev x.0x
serial: <superuser required> BIOS: American Megatrends v: 0704
date: 07/18/2011
Info: quad core model: Intel Core i7-2600 bits: 64 type: MT MCP
arch: Sandy Bridge rev: 7 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
Speed (MHz): avg: 1873 high: 3800 min/max: 1600/3800 cores: 1: 1600
2: 1596 3: 1600 4: 3800 5: 1600 6: 1596 7: 1600 8: 1596 bogomips: 54264
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: NVIDIA GK208B [GeForce GT 730] vendor: ZOTAC driver: nvidia
v: 470.256.02 arch: Kepler bus-ID: 01:00.0
Device-2: Sunplus Innovation FHD Camera Microphone
driver: snd-usb-audio,uvcvideo type: USB bus-ID: 2-1.1:3
gpu: nvidia,nvidia-nvswitch resolution: 1680x1050~60Hz
API: EGL v: 1.5 drivers: kms_swrast,nvidia,swrast platforms:
active: gbm,x11,surfaceless,device inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 470.256.02
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GT 730/PCIe/SSE2
Device-1: Intel 6 Series/C200 Series Family High Definition Audio
vendor: ASUSTeK 6 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: ZOTAC driver: snd_hda_intel
v: kernel bus-ID: 01:00.1
Device-3: Creative Labs EMU10k2/CA0100/CA0102/CA10200 [Sound Blaster
Audigy Series] driver: snd_emu10k1 v: kernel bus-ID: 07:00.0
Device-4: Sunplus Innovation FHD Camera Microphone
API: ALSA v: k6.8.0-100-generic status: kernel-api
vendor: ASUSTeK P8P67 and other motherboards driver: r8169 v: kernel
port: d000 bus-ID: 04:00.0
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 931.51 GiB used: 210.43 GiB (22.6%)
ID-1: /dev/sda vendor: Western Digital model: WD10EZEX-60WN4A0
ID-1: / size: 415.84 GiB used: 210.43 GiB (50.6%) fs: ext4 dev: /dev/sda1
System Temperatures: cpu: 33.0 C mobo: N/A gpu: nvidia temp: 41 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 30%
Memory: total: 16 GiB available: 15.6 GiB used: 2.89 GiB (18.5%)
Processes: 320 Uptime: 1h 51m Init: systemd target: graphical (5)
Packages: 4360 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Die Festplatte ist in zwei Partitionen unterteilt. Heute ergab eine Überprüfung im Terminal ergab die Meldung, dass beide Partitionen nicht mit an einer physikalischen Sektorengrenze beginnen (siehe Screenshot). Habe im Internet nach Lösungen gesucht. Da wurde empfohlen die Festplatte neu zu formatieren. Na toll, dann ist ja alles weg.
Frage gibt es auch andere Möglichkeiten das Problem zu lösen, ohne das die Festplatte formatiert werden muss?![]()
