Partition beginnt nicht an einer physikalischen Sektorgrenze
    Linux Mint
    mikulas@Linux-Mint:~$ inxi -Fzxi
    Kernel: 6.8.0-100-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
    Desktop: Cinnamon v: 6.6.6 Distro: Linux Mint 22.3 Zena
    base: Ubuntu 24.04 noble
    Type: Desktop Mobo: ASUSTeK model: P8H61-M LE v: Rev x.0x
    serial: <superuser required> BIOS: American Megatrends v: 0704
    date: 07/18/2011
    Info: quad core model: Intel Core i7-2600 bits: 64 type: MT MCP
    arch: Sandy Bridge rev: 7 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
    Speed (MHz): avg: 1873 high: 3800 min/max: 1600/3800 cores: 1: 1600
    2: 1596 3: 1600 4: 3800 5: 1600 6: 1596 7: 1600 8: 1596 bogomips: 54264
    Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
    Device-1: NVIDIA GK208B [GeForce GT 730] vendor: ZOTAC driver: nvidia
    v: 470.256.02 arch: Kepler bus-ID: 01:00.0
    Device-2: Sunplus Innovation FHD Camera Microphone
    driver: snd-usb-audio,uvcvideo type: USB bus-ID: 2-1.1:3
    gpu: nvidia,nvidia-nvswitch resolution: 1680x1050~60Hz
    API: EGL v: 1.5 drivers: kms_swrast,nvidia,swrast platforms:
    active: gbm,x11,surfaceless,device inactive: wayland,device-1
    API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 470.256.02
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GT 730/PCIe/SSE2
    Device-1: Intel 6 Series/C200 Series Family High Definition Audio
    vendor: ASUSTeK 6 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    Device-2: NVIDIA GK208 HDMI/DP Audio vendor: ZOTAC driver: snd_hda_intel
    v: kernel bus-ID: 01:00.1
    Device-3: Creative Labs EMU10k2/CA0100/CA0102/CA10200 [Sound Blaster
    Audigy Series] driver: snd_emu10k1 v: kernel bus-ID: 07:00.0
    Device-4: Sunplus Innovation FHD Camera Microphone
    API: ALSA v: k6.8.0-100-generic status: kernel-api
    vendor: ASUSTeK P8P67 and other motherboards driver: r8169 v: kernel
    port: d000 bus-ID: 04:00.0
    IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
    Local Storage: total: 931.51 GiB used: 210.43 GiB (22.6%)
    ID-1: /dev/sda vendor: Western Digital model: WD10EZEX-60WN4A0
    ID-1: / size: 415.84 GiB used: 210.43 GiB (50.6%) fs: ext4 dev: /dev/sda1
    System Temperatures: cpu: 33.0 C mobo: N/A gpu: nvidia temp: 41 C
    Fan Speeds (rpm): N/A gpu: nvidia fan: 30%
    Memory: total: 16 GiB available: 15.6 GiB used: 2.89 GiB (18.5%)
    Processes: 320 Uptime: 1h 51m Init: systemd target: graphical (5)
    Packages: 4360 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
    Die Festplatte ist in zwei Partitionen unterteilt. Heute ergab eine Überprüfung im Terminal ergab die Meldung, dass beide Partitionen nicht mit an einer physikalischen Sektorengrenze beginnen (siehe Screenshot). Habe im Internet nach Lösungen gesucht. Da wurde empfohlen die Festplatte neu zu formatieren. Na toll, dann ist ja alles weg.
    Frage gibt es auch andere Möglichkeiten das Problem zu lösen, ohne das die Festplatte formatiert werden muss?
    "Darf" mich seit 1975 mit allen möglichen Computern und Betriebssystemen herumärgern. :)
  • Wenn du das wirklich weg haben willst, musst du die Platte neu formatieren. Aber ... stört das irgendwie im Betrieb? Falls nicht, würde ich es ignorieren.
  • Frage gibt es auch andere Möglichkeiten das Problem zu lösen,
    als Problem würde ich das nicht bezeichnen, eher als Hinweis.
    Normal sollte das den Betrieb nicht beeinträchtigen und wäre höchstens als "Schönheitsfehler" einzustufen?
  • Helmfuss Dank für die Meldung.
    Peppino Nein stört nicht. Dann kann man die Meldungen des Terminals wohl ignorieren
  • Archy Danke für den Hinweis, dass es sich um einen Schönheitsfehler handelt.
  • Wenn Daten oder der beginn einer Partition über Sektorgrenzen verteilt sind muss eine Drehende Festplatte zum lesen oder Schreiben mehr Umdrehungen machen als wenn es korrekt ausgerichtet wäre, also hat man minimal längere Zugriffszeiten.
