Fingersensor nutzen
     ~  inxi -F  ✔
    Host: 20egs0580q Kernel: 6.18.8-1-MANJARO arch: x86_64 bits: 64
    Desktop: KDE Plasma v: 6.5.5 Distro: Manjaro Linux
    Type: Convertible System: Dell product: Inspiron 7706 2n1 v: N/A
    serial: <superuser required>
    Mobo: Dell model: 0VVX48 v: A00 serial: <superuser required>
    Firmware: UEFI vendor: Dell v: 1.35.0 date: 02/13/2025
    Battery:
    ID-1: BAT0 charge: 23.4 Wh (80%) condition: 29.2/68 Wh (43%) volts: 15.21
    min: 15.2
    Info: quad core model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
    cache: L2: 5 MiB
    Speed (MHz): avg: 2347 min/max: 400/4200 cores: 1: 2347 2: 2347 3: 2347
    4: 2347 5: 2347 6: 2347 7: 2347 8: 2347
    Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] driver: i915 v: kernel
    Device-2: Microdia Integrated_Webcam_HD driver: uvcvideo type: USB
    Display: wayland server: X.org v: 1.21.1.21 with: Xwayland v: 24.1.9
    compositor: kwin_wayland driver: X: loaded: modesetting dri: iris gpu: i915
    resolution: 2560x1600~60Hz
    API: EGL v: 1.5 drivers: iris,swrast
    platforms: gbm,wayland,x11,surfaceless,device
    API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.3.4-arch1.1
    renderer: Mesa Intel Iris Xe Graphics (TGL GT2)
    API: Vulkan v: 1.4.335 drivers: intel surfaces: N/A
    de: kscreen-console,kscreen-doctor wl: wayland-info x11: xdpyinfo,xprop
    Device-1: Intel Tiger Lake-LP Smart Sound Audio
    driver: sof-audio-pci-intel-tgl
    API: ALSA v: k6.18.8-1-MANJARO status: kernel-api
    Server-1: PipeWire v: 1.4.10 status: active
    Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi
    IF: wlp0s20f3 state: up mac: e0:2b:e9:f4:36:cf
    Bluetooth:
    Device-1: Intel AX201 Bluetooth driver: btusb type: USB
    Report: rfkill ID: hci0 state: up address: see --recommends
    RAID:
    Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    Local Storage: total: 1.82 TiB used: 11.49 GiB (0.6%)
    ID-1: /dev/nvme0n1 vendor: Western Digital model: WDS100T2B0C-00PXH0
    ID-2: /dev/sda vendor: Samsung model: PSSD T7 size: 931.51 GiB type: USB
    ID-1: / size: 464.8 GiB used: 11.48 GiB (2.5%) fs: btrfs dev: /dev/sda3
    ID-2: /boot/efi size: 1.05 GiB used: 6 MiB (0.6%) fs: vfat dev: /dev/sda2
    ID-3: /home size: 464.8 GiB used: 11.48 GiB (2.5%) fs: btrfs
    dev: /dev/sda3
    ID-4: /var/log size: 464.8 GiB used: 11.48 GiB (2.5%) fs: btrfs
    dev: /dev/sda3
    System Temperatures: cpu: 46.0 C mobo: 43.0 C sodimm: 35.0 C
    Fan Speeds (rpm): cpu: 0
    Memory: total: 32 GiB note: est. available: 31.07 GiB used: 3.33 GiB (10.7%)
    Processes: 262 Uptime: 1h 9m Shell: Zsh inxi: 3.3.40
    Hallo alle,
    vermutlich ganz einfach. Mein Dell Inspiron 7706 hat einen Fingersensor. Den möchte nutzen, um mich anmelden oder auch adminisstrative Sachen genehmigen zu können. Nur habe ich dieses Mal null Ahnung, wie ich das einrichte.
    Wie mach' ich das?
    Grüße
    Proz. 11th Gen Intel(R) Core(TM) i5-1135G7
    RAM 32,0 GB - Grafikkarte Intel(R) Iris(R) Xe Graphics (128 MB)
    Stift- und Fingereingabe Unterstützung
  • Wenn in den Systemeinstellungen bei der Benutzerverwaltung die Option für Registrierung der Fingerabdrücke fehlt, gibt es für dein Fingerabdruckgerät keinen Treiber.
  • Moin,
    diese Frage an die KI gerichtet
    "dell latitude 7706 erkennt nach installation von linux manjaro den fingerabdrucksensor nicht."
    ergibt folgende Antwort:
    1. Hardware-ID prüfen
    Stellen Sie zunächst sicher, dass der Sensor vom System überhaupt gesehen wird. Öffnen Sie ein Terminal und geben Sie ein:
    lsusb
    Suchen Sie nach einem Eintrag wie 0a5c:5834 (Broadcom) oder 27c6:xxxx (Goodix).
    2. Unterstützung abgleichen
    Prüfen Sie Ihre ID in der Liste der unterstützten Geräte von libfprint.
    fprintd +1
    • Wichtig: Viele Latitude-Modelle nutzen Dell ControlVault 3. Diese Sensoren gelten unter Linux oft als "unsupported", da die Hersteller keine Spezifikationen für Open-Source-Treiber bereitstellen.
    3. Installation notwendiger Pakete
    Falls Ihr Gerät gelistet ist oder Sie es testen möchten, installieren Sie die Basis-Software:
    1. Software laden: sudo pacman -S fprintd.
    2. PAM-Konfiguration: Damit der Fingerabdruck für Logins genutzt wird, führen Sie sudo pam-auth-update aus und aktivieren Sie die Fingerabdruck-Authentifizierung (falls verfügbar).
    3. AUR nutzen: Für spezielle Dell-Sensoren gibt es im Manjaro AUR (Arch User Repository) oft Pakete wie libfprint-2-tod1-broadcom.
    4. BIOS-Check
    Stellen Sie sicher, dass der Fingerabdruckleser im BIOS unter Integrated Devices oder Security aktiviert ist.
    Hinweis: Sollte Ihr Sensor ein Broadcom-Modell (z.B. 0a5c:5834) sein, gibt es aktuell leider oft keine funktionierende Lösung für Linux.
    Welche ID wird Ihnen nach dem Befehl lsusb für den Sensor angezeigt?
    Ich hatte dieses Problem mit einem Dell Latitude 5530 und dort einem Broadcom und konnte das Problem dort mit der KI lösen.
    Gruß Andreas
  • ein distributionsbezogenes wiki ist i.d.R. zuverlässiger als jede KI :)
  • Ne, sieht irgendwie nix gut aus:
    ID 27c6:538d Shenzhen Goodix Technology Co.,Ltd. FingerPrint
    Zwar konnte ich sudo pacman -S fprintd ausführen, brachte aber nichts, weil
    ~  sudo pam-auth-update         ✔  25s 
    sudo: pam-auth-update: Befehl nicht gefunden
    Demnach habe ich hier keinen Erfolg. Wäre auch nicht schlimm. Gibt wichtigeres.
    Richtig.
    Trotzdem zeig uns doch mal das.
    lsusb -t
  • schau mal nach, ob das Fingerabdruckgerät im System erkannt wird mit
    inxi -J
  • ich hab hier ein
    Bus 001 Device 004: ID 27c6:6092 Shenzhen Goodix Technology Co.,Ltd. Goodix USB2.0 MISC
    nach der Anleitung vom Arch Wiki laufen. Ok, nicht exakt die gleiche ID.
    pam-auth-update gibt es bei mir auch nicht, wurde nicht gebraucht.
    in lsusb -t sehe ich das Gerät nicht
    in inxi -J schaut es so aus wie in lsusb wie oben gezeigt
    EndeavourOS mit KDE & Wayland auf verschiedenen Geräten mit AMD & Nvidia in diversen Kombinationen
