- Distrowahl
- Linux Mint
- System:
Kernel: 6.14.0-37-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
Desktop: Cinnamon v: 6.6.6 Distro: Linux Mint 22.3 Zena
base: Ubuntu 24.04 noble
Mobo: ASUSTeK model: PRIME B550-PLUS v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3001
date: 02/02/2023
Info: 8-core model: AMD Ryzen 7 5700X bits: 64 type: MT MCP arch: Zen 3+
rev: 2 cache: L1: 512 KiB L2: 4 MiB L3: 32 MiB
Speed (MHz): avg: 2545 high: 3600 min/max: 550/4665 boost: enabled cores:
1: 1742 2: 3598 3: 1742 4: 3599 5: 3546 6: 3599 7: 3596 8: 1742 9: 1742
10: 3517 11: 3600 12: 1742 13: 1742 14: 1742 15: 1742 16: 1742
bogomips: 108807
Device-1: NVIDIA AD104 [GeForce RTX 4070] vendor: CardExpert driver: nvidia
v: 590.48.01 arch: Lovelace bus-ID: 09:00.0
loaded: nvidia gpu: nv_platform,nvidia,nvidia-nvswitch resolution:
1: 1440x900~60Hz 2: 1920x1080~60Hz 3: 1920x1080~60Hz 4: 1800x1012~50Hz
API: EGL v: 1.5 drivers: nvidia platforms: active: gbm inactive: N/A
API: OpenGL v: 4.6.0 vendor: nvidia v: 590.48.01 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 4070/PCIe/SSE2
Device-1: NVIDIA vendor: CardExpert driver: snd_hda_intel v: kernel
bus-ID: 09:00.1
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0b:00.4
Device-3: Shure MV7 driver: hid-generic,snd-usb-audio,usbhid type: USB
bus-ID: 1-1:2
Device-4: SteelSeries ApS Arctis Nova 7
driver: hid-generic,snd-usb-audio,usbhid type: USB bus-ID: 1-3:4
API: ALSA v: k6.14.0-37-generic status: kernel-api
Device-1: Ralink RT5392 PCIe Wireless Network Adapter driver: rt2800pci
v: 2.3.0 bus-ID: 05:00.0
IF: wlp5s0 state: down mac: <filter>
vendor: ASUSTeK RTL8111H driver: r8169 v: kernel port: f000 bus-ID: 08:00.0
IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth:
Device-1: TP-Link Bluetooth USB Adapter driver: btusb v: 0.8 type: USB
bus-ID: 1-4:6
lmp-v: 10
Local Storage: total: 4.89 TiB used: 895.4 GiB (17.9%)
ID-1: /dev/nvme0n1 vendor: Lexar model: SSD NM790 4TB size: 3.73 TiB
temp: 44.9 C
ID-2: /dev/sda vendor: Samsung model: SSD 860 QVO 1TB size: 931.51 GiB
ID-3: /dev/sdb vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
ID-4: /dev/sdc vendor: SanDisk model: Ultra size: 28.64 GiB type: USB
ID-1: / size: 3.67 TiB used: 693.39 GiB (18.5%) fs: ext4 dev: /dev/nvme0n1p2
dev: /dev/nvme0n1p1
ID-1: swap-1 type: file size: 2 GiB used: 23.1 MiB (1.1%) file: /swapfile
System Temperatures: cpu: 43.6 C mobo: 33.5 C gpu: nvidia temp: 40 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Memory: total: 32 GiB available: 31.26 GiB used: 6.63 GiB (21.2%)
Processes: 442 Uptime: 18h 45m Init: systemd target: graphical (5)
Packages: 2538 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Hey zusammen,
ich möchte einmal ein paar Fragen stellen. Meine letzte Linux Erfahrung ist wohl doch so lange her, dass ich das komplett "neu" lernen muss, scheint nicht wie Fahrradfahren zu sein. Erst einmal möchte ich direkt vorab fragen, ob ich all meine weitere Fragen hier in den Thread schreiben oder für jede Frage einen neuen Thread aufmachen soll, damit z.B. andere Neulinge schneller eine Lösung finden und die Fragen nicht wiederholen müssten?
✅️ Gelöst | Frage 1 - Emojis
Unter Windows kann man ja mit der Windowstaste + Punkttaste ein Menü für Emojis öffnen. Wie funktioniert dies unter Linux Mint? Gibt es nativ etwas oder gibt es dafür eine extra App?
Lösung:
Ich nutze die Anwendung Emote nun aus der Anwendungsverwaltung.
✅️ Gelöst | Frage 2 - Screenshots (Flameshot)
Ich habe gestern bestimmt Stunden danach gesucht, wie man Flameshot mit einer Tastenbelegung ausführen kann, jedoch habe ich dazu nichts unter den nativen Hotkey Einstellungen von Flameshot gefunden. Kennt sich damit jemand aus?
Lösung:
Frage 3 - Die Taskleiste des Grauens
Nehmen wir als Beispiel einmal Minecraft, wenn ich Minecraft in Fullscreen offen habe und dann die Windowstaste drücke, komme ich zwar auf den Bildschirm, aber nur, wenn ich in Minecraft z.B. den Chat offen habe etc. und dann kann ich wiederum nur auf anderen Monitoren etwas anklicken, jedoch nichts in der Taskleiste auf dem Monitor, auf dem ich mich befinde.
Außerdem hätte ich gerne auf jedem Monitor genau die gleiche Taskleiste wie auf dem Hauptbildschirm, das scheint aber unter Linux gar nicht zu funktionieren? Ich weiß, dass man die Taskleiste anpassen kann mit diesen Applets, scheinbar, jedoch kann man manche Applets nur einmalig auf einer einzigen Taskleiste anzeigen lassen und ich habe auch noch nich herausgefunden, wie genau man in der Taskleiste einzelne Aspekte verschiebt. Ich klicke z.B. auf Leistenbearbeitungsmodus und versuche etwas zu verschieben, z.B. dass die Programme links angezeigt werden statt rechts, jedoch wird das immer wieder zurück gesetzt und es "heftet" sich nicht an.
✅️ Gelöst | Frage 4 - DaVinci Resolve - Der Kollaps meines Gehirns beginnt
Ich versuche DaVinci Resolve zu installieren, ein Programm zum cutten etc. von Videos, dort wird mir jedoch gesagt, dass mir scheinbar manche Packages fehlen, vom Namen her denke ich, dass es Libraries sind. Eines dieser Packages konnte ich sogar bereits installieren, 2 andere finde ich nirgends im Internet und das letzte Package braucht wiederum ein anderes Package, dass zuvor installiert werden muss, dass ich aber wiederum auch nirgends finde ![]()
Es geht um Folgende Packages:
- libaprutil1 - Diese benötigt wiederum das Package libgdbm5, das ich nirgends finde.
- libgdbm5 - Die Lib für die Lib darüber
- libasound2 - Kann ich nirgends im WWW finden
- libglib2.0-0 - Gleiches Problem wie davor, kann ich nirgends im WWW finden
Wo kann ich diese Packages herbekommen?
Lösung:
✅️ Gelöst | Frage 5 - Sound Cables - Mein Verstand reist zum Abgrund
Ich hatte mich auf die Suche nach einem Programm für virtuelle Sound Cables mit einem Equalizer etc., bzw. einem Programm wie Steel Series Sonar begeben, leider vergebens.
Auch bin ich eher darauf angewiesen, dass Programm über ein GUI bedienen zu können und nicht alles über das Terminal machen zu müssen. Bei so manchen Sachen ist das in Ordnung, wie z.B. bei AdGuard etc., für Aufgabenbereiche wie Sound etc. hätte ich jedoch gerne ein intuitives und übersichtliches GUI.
Lösung:
✅️ Gelöst | Frage 6 - Struktur rein bringen - Der Aufstieg aus dem Abgrund
Wie schaffe ich eine ordentliche Ordner Struktur? Dort wo ich meine weiteren Ordner etc. drauf aufbauen wollte kann man keinen Ordner erstellen und auch ist die Geräte Übersicht minimal unübersichtlich und null intuitiv.
Ich habe aktuell unter Geräte die folgende Struktur:
- Geräte
- USB Stick
- Volume | Typ: Ordner (inode/directory) | Ort: /media/tobi
- Ordner 1: $RECYCLE.BIN - enthält 1 Ordner mit einer Datei [Keine Ahnung was das ist]
- Ordner 2: System Volume Information - enthält 3 Dateien [Keine Ahnung was das ist]
- Volume 1 | Typ: Ordner (inode/directory) | Ort: /media/tobi
- Mein Rechner
- Dateisystem | Typ: Ordner (inode/directory) | Ort:
Ja, bei Ort steht wirklich nichts. Also nicht vorhanden? Bin ich am Ende des Universums angelangt? Bin ich in nem schwarzen Loch gefangen? Wo wie was, wieso weshalb warum? Außerdem ist der Ordner komplett Abseits von Geräte angezeigt
Wie bekomme ich also eine gescheite Struktur hin? Kann ich die beiden Volumen einfach löschen bzw. entfernen? Und wieso kann ich unter / keinen neuen eigenen Ordner erstellen, scheinbar geht das erst ab /home/tobi, also nicht einmal unter /home? Wie strukturiert ihr eure Ordner? Und wie kann ich anpassen, dass ein neuer Tab im Explorer eine andere Farbe hat oder wenigstens der Tab, auf dem man sich im Explorer befindet, wenigstens so hinterlegt ist, das man erkennt wo man gerade ist. Der ganze Aufbau des Explorers bereitet mir derzeit harte Kopfschmerzen.
Das folgende Bild sollte euch das besser aufzeigen können:
Ich bin mittlerweile echt am Verzweifeln und war gestern kurz davor, wieder auf den Virus zu wechseln. Vielleicht kann mir ja der ein oder andere bei dem ein oder anderen Problem helfen, da nicht unbedingt jeder sich mit allem auskennen kann.
Boah, das ist nun wirklich sehr viel geworden und ich möchte mich schon einmal herzlich bedanken, dass du es bis hier her gelesen hast. Ich musste die Fragen einfach in "Kapitel" aufteilen, damit mein Verstand wieder ein wenig "gereinigt" wird. Ich gehe nun mit meinem Affen im Kopf auf Trommeln spielen, bis dann!
Liebe Grüße, euch ein schönes Bergfest sowie restliche Woche.
Tobi
