Leistenprobleme ;)
    Linux Mint
    Kernel: 6.8.0-90-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
    Desktop: Cinnamon v: 6.6.5 Distro: Linux Mint 22.3 Zena
    base: Ubuntu 24.04 noble
    Type: Desktop System: Gigabyte product: B450M S2H v: N/A
    serial: <superuser required>
    Mobo: Gigabyte model: B450M S2H serial: <superuser required> UEFI: American
    Megatrends LLC. v: F64 date: 06/08/2023
    Battery:
    Device-1: hidpp_battery_0 model: Logitech K850 Performance Wireless Keyboard
    charge: 100% (should be ignored) status: discharging
    Device-2: hidpp_battery_1 model: Logitech M720 Triathlon Multi-Device
    Mouse charge: 10% (should be ignored) status: discharging
    Info: quad core model: AMD Ryzen 3 3200G with Radeon Vega Graphics bits: 64
    type: MCP arch: Zen/Zen+ note: check rev: 1 cache: L1: 384 KiB L2: 2 MiB
    L3: 4 MiB
    Speed (MHz): avg: 1397 min/max: 1400/3600 boost: enabled cores: 1: 1397
    2: 1397 3: 1397 4: 1397 bogomips: 28746
    Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
    Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
    vendor: Gigabyte driver: amdgpu v: kernel arch: GCN-5 bus-ID: 0a:00.0
    temp: 35.0 C
    resolution: 1920x1080~60Hz
    Radeon Vega 8 Graphics (radeonsi raven ACO DRM 3.57 6.8.0-90-generic)
    Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
    v: kernel bus-ID: 0a:00.1
    Device-2: AMD Family 17h/19h HD Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel bus-ID: 0a:00.6
    API: ALSA v: k6.8.0-90-generic status: kernel-api
    vendor: Gigabyte driver: r8169 v: kernel port: f000 bus-ID: 08:00.0
    IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
    Local Storage: total: 1.92 TiB used: 1.17 TiB (60.9%)
    ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 1TB
    size: 931.51 GiB temp: 32.9 C
    ID-2: /dev/sda vendor: SanDisk model: SDSSDA240G size: 223.57 GiB
    ID-3: /dev/sdb vendor: SanDisk model: SSD PLUS 240 GB size: 223.58 GiB
    ID-4: /dev/sdc vendor: Toshiba model: MQ01ABF050 size: 465.76 GiB
    ID-5: /dev/sdd vendor: Generic model: Flash Disk size: 117.19 GiB
    type: USB
    ID-1: / size: 38.15 GiB used: 23.75 GiB (62.3%) fs: ext4 dev: /dev/sda2
    ID-2: /boot/efi size: 96 MiB used: 37.2 MiB (38.8%) fs: vfat
    dev: /dev/nvme0n1p1
    ID-3: /home size: 164.48 GiB used: 57.96 GiB (35.2%) fs: ext4
    dev: /dev/sda3
    ID-1: swap-1 type: partition size: 15.82 GiB used: 0 KiB (0.0%)
    dev: /dev/sda4
    System Temperatures: cpu: 34.0 C mobo: 21.0 C gpu: amdgpu temp: 34.0 C
    Fan Speeds (rpm): N/A
    Memory: total: 16 GiB note: est. available: 13.56 GiB used: 2.67 GiB (19.7%)
    Processes: 264 Uptime: 39m Init: systemd target: graphical (5)
    Packages: 2520 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
    ich lasse bestimme Applets (Netzwerk & solaar) unsichtbar bzw. wenn den Pfeil betätige erscheinen Sie. Leider werden die je nach Lust und Laune angezeigt :(
    und gibt es eine Möglichkeit eine Leiste nur bei Bedarf anzeigen zu lassen oder diese als kleine Ecknotiz oben rechts einzubinden, als diese nicht einen komplett über den Monitor geht.
    Grüsse
  • Leisteneinstellungen. Da kannst Du einstellen, ob und wie die Leiste ausgeblendet wird. Ecknotiz geht nicht. Aber Du kannst die Leiste verkleinern. Du kannst in den Ecken aber Programme einbinden, die starten, wenn Du mit der Maus drüber gehst.
