DVB-C Sender von der Fritzbox mit VLC anschauen
    Linux Mint
    Kernel: 6.14.0-37-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
    clocksource: tsc
    Desktop: Cinnamon v: 6.4.8 tk: GTK v: 3.24.41 wm: Muffin v: 6.4.1 vt: 7
    dm: LightDM v: 1.30.0 Distro: Linux Mint 22.2 Zara base: Ubuntu 24.04 noble
    Type: Laptop System: Packard Bell product: EasyNote TM85 v: V1.21
    serial: <superuser required>
    Mobo: Packard Bell model: EasyNote TM85 v: V1.21
    serial: <superuser required> part-nu: Calpella_CRB
    uuid: <superuser required> BIOS: Packard Bell v: 1.21 date: 02/24/2011
    Battery:
    ID-1: BAT0 charge: 15.6 Wh (100.0%) condition: 15.6/47.5 Wh (32.8%)
    volts: 12.4 min: 10.8 model: SANYO Li_Ion_4000mA type: Li-ion
    serial: <filter> status: full
    Info: dual core model: Intel Core i5 M 450 bits: 64 type: MT MCP
    smt: enabled arch: Westmere rev: 5 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
    Speed (MHz): avg: 1796 high: 2394 min/max: 1199/2399 cores: 1: 1199
    2: 2394 3: 2394 4: 1199 bogomips: 19153
    Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
    Device-1: NVIDIA GF108M [GeForce GT 420M] vendor: Acer Incorporated ALI
    driver: nouveau v: kernel arch: Fermi pcie: speed: 2.5 GT/s lanes: 16 ports:
    active: LVDS-1 empty: HDMI-A-1,VGA-1 bus-ID: 01:00.0 chip-ID: 10de:0df1
    class-ID: 0300 temp: 68.0 C
    Device-2: Chicony 1.3M Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 bus-ID: 1-1.1:3 chip-ID: 04f2:b1d8 class-ID: 0e02
    loaded: modesetting unloaded: fbdev,vesa dri: nouveau gpu: nouveau
    display-ID: :0 screens: 1
    Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
    s-diag: 414mm (16.31")
    Monitor-1: LVDS-1 model: AU Optronics 0x22ec res: 1366x768 hz: 60 dpi: 101
    size: 344x193mm (13.54x7.6") diag: 394mm (15.5") modes: max: 1366x768
    min: 640x350
    API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
    device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau x11:
    drv: nouveau inactive: wayland
    API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 25.0.7-0ubuntu0.24.04.2
    glx-v: 1.4 direct-render: yes renderer: NVC1 device-ID: 10de:0df1
    Device-1: Intel 5 Series/3400 Series High Definition Audio
    vendor: Acer Incorporated ALI 5 driver: snd_hda_intel v: kernel
    bus-ID: 00:1b.0 chip-ID: 8086:3b56 class-ID: 0403
    Device-2: NVIDIA GF108 High Definition Audio vendor: Acer Incorporated ALI
    driver: snd_hda_intel v: kernel pcie: speed: 2.5 GT/s lanes: 16
    bus-ID: 01:00.1 chip-ID: 10de:0bea class-ID: 0403
    API: ALSA v: k6.14.0-37-generic status: kernel-api
    Server-1: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
    status: active 2: wireplumber status: active 3: pipewire-alsa type: plugin
    Device-1: Broadcom NetLink BCM57780 Gigabit Ethernet PCIe
    vendor: Acer Incorporated ALI driver: tg3 v: kernel pcie: speed: 2.5 GT/s
    lanes: 1 port: N/A bus-ID: 02:00.0 chip-ID: 14e4:1692 class-ID: 0200
    IF: enp2s0 state: down mac: <filter>
    Device-2: Realtek RTL8192SE Wireless LAN driver: rtl8192se v: kernel pcie:
    speed: 2.5 GT/s lanes: 1 port: 1000 bus-ID: 03:00.0 chip-ID: 10ec:8174
    class-ID: 0280
    IF-ID-1: virbr0 state: down mac: <filter>
    Bluetooth:
    Device-1: USB2.0-BT driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 bus-ID: 2-1.2:4 chip-ID: 33fa:0001 class-ID: e001
    lmp-v: 10 sub-v: 89 hci-v: 10 rev: 89 class-ID: 7c010c
    Local Storage: total: 223.57 GiB used: 114.4 GiB (51.2%)
    ID-1: /dev/sda vendor: Crucial model: CT240BX500SSD1 size: 223.57 GiB
    speed: 3.0 Gb/s tech: SSD serial: <filter> fw-rev: 041 scheme: GPT
    ID-1: / size: 218.51 GiB used: 114.4 GiB (52.4%) fs: ext4 dev: /dev/sda3
    ID-2: /boot/efi size: 512 MiB used: 6.1 MiB (1.2%) fs: vfat dev: /dev/sda2
    ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
    System Temperatures: cpu: 67.0 C mobo: N/A gpu: nouveau temp: 69.0 C
    Fan Speeds (rpm): N/A
    Memory: total: 8 GiB available: 7.62 GiB used: 2.56 GiB (33.6%)
    Processes: 267 Power: uptime: 2h 4m states: freeze,mem,disk suspend: deep
    wakeups: 0 hibernate: platform Init: systemd v: 255 target: graphical (5)
    default: graphical
    Packages: 2551 pm: dpkg pkgs: 2526 pm: flatpak pkgs: 25 Compilers:
    gcc: 13.3.0 Shell: Bash v: 5.2.21 running-in: gnome-terminal inxi: 3.3.34
    Hallo Zusammen,
    bin Linux newbie und habe z.Zt. folgendes Problem (hole etwas weiter aus):
    Habe die Fritzbox 6670 Cable. Meine TV-Programme laufen beim Fernseher einwandfrei. Bei der Fritzbox kann ich ja unter den Sendern ein Programm auswählen und mir anschauen. Unter Windows wurde mein VLC geladen und den Film. Es lief.
    Auch unter Linux Mint wird der VLC geladen und gibt dann folgende Fehlermeldung aus (Bild 1):
    Nach Recherchen im Internet geht das lt. AVM. Da gibt es sogar eine Anleitung wie das mit der FB 6670 zu bewerkstelligen ist. Genauso habe ich das auch gehandhabt. Aber chatgpt schreibt mir, dass AVM die "rtsp" Übertragung eingestellt hätte ?
    Auf der anderen Seite kann ich aber für mein Android-Tablet die Fritz-TV-App downloaden und mir die Filme anschauen !?!
    Muss ich beim VLC noch irgendeinen Codec nachladen oder eine andere Einstellung vornehmen ? Bin echt ratlos.
    Danke im voraus für Eure Hilfe.
    Grüße Axel
  • Noch ein Nachtrag.
    Habe einen Sender ausgewählt. In dem Live-TV - Button sehe ich Folgendes:
    Ok, aber manchmal -bei einigen Tests- sehe ich plötzlich einen grünen Punkt bei der Übertragung. Also der stream steht höchstwahrscheinlich. Aber der VLC beharrt auf seine Fehlermeldung.
    Grüße Axel
    Grüße aus dem Schwabenländle
    Axel
  • Wow, danke Helmfuss. Kleine Sache große Wirkung. Darauf wäre ich nicht gekommen. Es funzt wunderbar (bis jetzt ;) )
    Kann ich dann eigentlich die firewall ausgeschaltet lassen, oder wieder einschalten und als Ausnahme den stream angeben ?
    Axel
  • Aber chatgpt schreibt mir, dass AVM die "rtsp" Übertragung eingestellt hätte ?
    Da kann man sehen, was manchmal eine KI für einen "Schotter" schreibt.
    Axel
    Du solltet dafür eine neue Regel eintragen. Dann läuft es auch mit Firewall.
  • Du solltet dafür eine neue Regel eintragen. Dann läuft es auch mit Firewall.
    Daran dachte ich auch schon. Habe das auch mit dem UDP 1234 port versucht. Wieder die gleiche Fehlermeldung. Muss ich denn in der Fritzbox auch den port gem. dieser Bechreibung:
    Google Search
    freigeben ?
    Aber auf der anderen Seite hat schon Helmfuss recht. Die Firewall in der Fritzbox ist schon gut. Ausserdem möchte ich auch nicht von außerhalb zugreifen. Also nur im Heimnetz.
    Axel
  • Lumo sagt:
    Realtime Service (RTS) – Firewall‑Port‑Requirements
    RichtungProtokoll / PortZweck
    EingehendTCP 10002Standard‑Port, über den das RTS‑Backend (z. B. Resource Central) von Exchange/Office 365 erreicht wird (Push‑Benachrichtigungen).
    EingehendTCP 443 (optional)Wenn Sie die HTTPS‑Variante des Dienstes (RTS‑Web‑API) nutzen.
    AusgehendTCP 443Kommunikation mit den Office 365‑ bzw. Azure‑Diensten (Exchange Online, Azure AD, Graph‑API usw.).
    AusgehendTCP 80Falls HTTP‑Endpunkte von Microsoft verwendet werden (z. B. Lizenz‑ oder Update‑Abfragen).
    AusgehendTCP 587 (SMTP‑Submission)Für E‑Mail‑Benachrichtigungen, wenn das System selbst Mails versendet.
    AusgehendDNS (UDP 53)Auflösung der Microsoft‑ und Add‑On‑DNS‑Namen, die vom RTS verwendet werden (z. B. *.protonmail.ch, *.office365.com, *.microsoftonline.com).
    Hinweise
    • Der einzige zwingende eingehende Port ist TCP 10002 – das ist der Standard‑Port, über den das RTS‑System von außen erreichbar sein muss.
    • Wenn Sie das RTS‑Frontend über HTTPS bereitstellen, öffnen Sie zusätzlich TCP 443.
    • Alle ausgehenden Verbindungen laufen über die üblichen Internet‑Ports (443 / 80 / 587) zu den Microsoft‑ bzw. Add‑On‑Servern. Die konkreten Ziel‑DNS‑Namen finden Sie in der Dokumentation von RealTime Service (z. B. *.protonmail.ch, outlook.office365.com usw.).
    • Stellen Sie sicher, dass DNS‑Auflösung (UDP 53) erlaubt ist, damit die dynamischen IP‑Adressen der Microsoft‑Cloud‑Dienste korrekt ermittelt werden können.
    Damit sind die notwendigen Firewall‑Regeln für eine funktionierende RTS‑Installation abgedeckt.
    Vorherige Nachricht
    2 / 2
    Nächste Nachricht
  • Danke Euch für die Infos. Das Thema werde ich jetzt als "gelöst" kennzeichnen.
    Es ist zwar jetzt OT aber passt zu dem Threadverlauf. Vllt. kann ich jetzt einigen usern mit dem gleichen Problem helfen. Der Verursacher meines Problems war ja die Firewall (gufw). Habe gem. Internet diverse ports freigegeben, aber ohne Erfolg. Aber wenn was nicht funzt, werde ich wach und versuche das Problem zu lösen ;)
    Als Erstens sollte man vom flatpak die neueste VLC (3.0.21) downloaden. Beim Aufruf von der Firewall kann man unter Anwendungen ein Fenster öffnen mit diversen Software-Portfreigaben.
    Da habe ich 3 Versionen die unter VLC zu finden sind eine Regel erstellt. Diese sehen dann so aus:
    Es läuft jetzt mit den Portfreigaben wunderbar. In der Anwendungsverwaltung ist noch die alte Version (3.0.20) von VLC zu finden. Mit den gleichen Portfreigaben blockiert die Firewall den stream.
    Axel
  • Lumo sagt:
    Unpassendes Ki zeugs
    Kannst du das bitte wieder löschen? Ist total am Thema vorbei. Hier geht es nicht um Exchange, Office oder sonstige Microsoft Produkte
    EndeavourOS mit KDE & Wayland auf verschiedenen Geräten mit AMD & Nvidia in diversen Kombinationen
