Minisforum UM750L Slim - BLuetooth-Problem mit neuer WIFI-Karte
    Linux Mint
    Kernel: 6.14.0-37-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
    Desktop: Cinnamon v: 6.6.3 Distro: Linux Mint 22.3 Zena
    base: Ubuntu 24.04 noble
    Type: Mini-pc System: Micro (HK) Tech product: EliteMini Series v: 1.0
    serial: <superuser required>
    Mobo: Shenzhen Meigao Equipment model: F7BSL v: 1.0
    serial: <superuser required> UEFI: American Megatrends LLC. v: 1.00
    date: 04/02/2025
    Info: 6-core model: AMD Ryzen 5 7545U bits: 64 type: MT MCP arch: Zen 4c
    rev: 0 cache: L1: 384 KiB L2: 6 MiB L3: 16 MiB
    Speed (MHz): avg: 1301 high: 1996 min/max: 400/4979 boost: enabled cores:
    1: 1117 2: 1117 3: 1395 4: 1891 5: 1117 6: 1117 7: 1117 8: 1397 9: 1117
    10: 1117 11: 1996 12: 1117 bogomips: 76661
    Device-1: AMD Phoenix2 driver: amdgpu v: kernel arch: RDNA-3 bus-ID: c5:00.0
    temp: 27.0 C
    resolution: 1920x1080~120Hz
    Ryzen 5 7545U (radeonsi phoenix2 LLVM 20.1.2 DRM 3.61 6.14.0-37-generic)
    Device-1: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
    v: kernel bus-ID: c5:00.1
    Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_pci_ps
    v: kernel bus-ID: c5:00.5
    Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel v: kernel
    bus-ID: c5:00.6
    API: ALSA v: k6.14.0-37-generic status: kernel-api
    Device-1: Realtek RTL8125 2.5GbE driver: r8169 v: kernel port: f000
    bus-ID: 02:00.0
    IF: enp2s0 state: down mac: <filter>
    Device-2: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
    v: kernel bus-ID: 03:00.0
    Bluetooth:
    Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB bus-ID: 1-5:3
    address: <filter>
    Local Storage: total: 2.75 TiB used: 648.17 GiB (23.0%)
    ID-1: /dev/nvme0n1 vendor: Fanxiang model: S880E 2TB size: 1.82 TiB
    temp: 23.9 C
    ID-2: /dev/nvme1n1 vendor: Kingston model: OM8TAP41024K1-A00
    size: 953.87 GiB temp: 24.9 C
    ID-1: / size: 868.58 GiB used: 14.45 GiB (1.7%) fs: ext4 dev: /dev/nvme1n1p2
    dev: /dev/nvme1n1p1
    System Temperatures: cpu: 31.5 C mobo: N/A gpu: amdgpu temp: 28.0 C
    Fan Speeds (rpm): N/A
    Memory: total: 32 GiB note: est. available: 29.16 GiB used: 2.34 GiB (8.0%)
    Processes: 370 Uptime: 4m Init: systemd target: graphical (5)
    Packages: 2227 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
    Hallo.
    Ich habe mir einen Mini-PC Minisforum UM750L angeschafft. Ich musste für Linux Mint allerdings eine neue WIFI-Karte einbauen, da darunter weder WLAN noch Bluetooth ging. Die neue Karte hat auf Anhieb super funktioniert, WLAN war sofort eingerichtet. Ich habe jetzt aber das Kuriosum, dass ich unter Bluetooth fast kein Gerät gekoppelt bekomme, außer einem bisher. Mir ist auf einem Vergleichsgerät mit Linux Mint 22.2 aufgefallen, dass zum Koppeln eine Nutzerbestätigung angefordert wird, auf dem Mini-PC unter der Beta LM 22.3 nicht. Das scheint eine dauerhafte Verbindung zu verhindern. Da im Suchmodus Geräte sofort erkannt werden, muss es meiner Meinung nach ein Problem bei den Diensten sein. Oder kann das evtl. ein Problem der Beta sein?
    Kann jemand helfen? Danke.
  • Go to Best Answer
  • Aus eigener Erfahrung kann ich nur sagen, dass die (Wieder-)Einbindung von Bluetooth-Geräten am Computer (wie auch am Fernseher) eine zähe Angelegenheit sein kann. In manchen Fällen musste x-mal herumprobiert werden, bis die Verbindung endlich stand. Wehe, man ist mit eventuell erforderlichen Nutzeraktionen nicht genau im Zeitfenster drin.
    Vielleicht ist aber die Beta-Version in dem Punkt auch noch nicht ausgereift.
  • Sehe ich da jetzt was falsches ?
    Zeigst du uns das mal nur zur Information.
    rfkill list
    Das Betriebssystem kann den Bluetooth-Adapter "softwareseitig" aktivieren/deaktivieren. Besser gesagt, KDE, Gnome, Xfce usw.. können es.
    „Das Beste in der Musik steht nicht in den Noten.“ (Gustav Mahler)
  • Dachte ich auch einen Moment aber rfkill bringt ein positives, freies Ergebnis.
    Das hat damit nichts zu tun. Bluetooth kann in rfkill per Software blockiert sein, aber das heißt nicht, dass man die Freigabe unbedingt manuell erzwingen muss. Man kann es zwar tun, aber normalerweise übernimmt das Betriebssystem diese Steuerung automatisch.
  • Ich hab das gerade nochmal probiert, es handelt sich um ein Gamepad. Gerät wird bei der Suche gefunden, ich drücke auf koppeln. Schlüsselsymbol erscheint, auch Meldung "ist gekoppelt". Ich vertraue dem Gerät und ein paar Sekunden später ist das Schlüsselsymbol weg. Kann nicht mehr verbunden werden. Auch das kleine Fenster zum Bestätigen des Koppelns erscheint nicht.
  • Weisst du denn aus dem Kopf wo da anzusetzen ist ?
    Ich müsste mich da erst Grundsätzlich einlesen.
    Angefangen beim DE.
    Das ist dasselbe wie bei dem User, dessen WLAN nicht funktioniert..
    Ohne Infos wie z.B. Logfiles kann man da nur schlecht helfen. Wo soll man da zuerst ansetzen? Deswegen halte ich mich da meistens raus. Außerdem stellt sich beim Tausch des Moduls auch die Frage, ob die Notebook-Firmware dieses überhaupt voll unterstützt? :/ Keine Ahnung.
  • Sorry Mintbonbon
    Mit der normalen Kopplung komme ich noch zurecht wenn was geblocked wurde aber hier bin ich überfragt.
    Hast du den mal eine Taste des Pad nach erfolgreicher Kopplung gedrückt.
    Bzw. wie lange dauert es bis das alles im Nirvana verschwiendet ?
    Ich denke da kommt das vorhin beschriebene Problem mit dem Zeitfenster zu tragen.
  • Hi /su,
    leider konnte ich das Pad noch nicht testen, der Zustand hält nur ein paar Sekunden an. Zuwenig um zu testen. Ich konnte jetzt aber meine Bluetooth-Ohrstöpsel problemlos koppeln, ohne Bestätigung. Die sind aber auch paarungswillig, wie nichts anderes es sein könnte. Vielleicht ist der Controller einfach Sch..... ?
  • Möglich das die Hardware einen Knick hat.
    Bitte editiere deinen Beitrag hier lesen auch Leute mit die solchen Ton abstossend finden (wie ich auch)
    Das muss doch nicht sein.
    thx
    Problem ist behoben. Habe heute einige Updates installiert u.a. "Linux Firmware". Nach erneutem Versuch zu Koppeln kam endlich das Bestätigungsfenster. Nach Bestätigung war der Controller endlich dauerhaft verbunden.
    Danke für die Hilfe und nochmal sorry. Wollte keinem zu nahe treten.
  • Mintbonbon January 11, 2026 at 7:26 AM
  • OK
    Dann werde ich mal im laufe des Tages einen eigenen Thread daraus machen
    Wo nur die Terminal Befehle und der Hinweis auf Manny_K Tipp drin sind.
    Es tauchen ja gerade da vermehrt Probleme auf und so kann man direkt darauf verweisen.
    Dir alles gute 👍
