Nach Neustart Auflösung auf 800x600 blockiert
    Ubuntu
    hagi@BIG:~$ inxi -Fzr
    Kernel: 6.14.0-36-generic arch: x86_64 bits: 64
    Desktop: GNOME v: 46.0 Distro: Ubuntu 24.04.1 LTS (Noble Numbat)
    Type: Desktop System: Gigabyte product: N/A v: N/A
    serial: <superuser required>
    Mobo: Gigabyte model: H77-DS3H v: x.x serial: <superuser required>
    UEFI: American Megatrends v: F7 SG date: 11/14/2012
    Info: quad core model: Intel Core i7-3770 bits: 64 type: MT MCP cache:
    L2: 1024 KiB
    Speed (MHz): avg: 2651 min/max: 1600/3900 cores: 1: 1600 2: 3578 3: 1600
    4: 1889 5: 3229 6: 3715 7: 3102 8: 2497
    Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] driver: nvidia
    v: 580.105.08
    gpu: nvidia,nvidia-nvswitch resolution: 1: 1680x1050~60Hz
    2: 1920x1080~60Hz
    API: EGL v: 1.5 drivers: kms_swrast,nouveau,swrast,zink
    platforms: gbm,x11,surfaceless,device
    API: OpenGL v: 4.6 compat-v: 4.5 vendor: nvidia mesa v: 580.105.08
    renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
    Device-1: Intel 7 Series/C216 Family High Definition Audio
    driver: snd_hda_intel
    Device-2: NVIDIA GA106 High Definition Audio driver: snd_hda_intel
    API: ALSA v: k6.14.0-36-generic status: kernel-api
    Device-1: Qualcomm Atheros AR8161 Gigabit Ethernet driver: alx
    IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
    Local Storage: total: 2.73 TiB used: 309.9 GiB (11.1%)
    ID-1: /dev/sda vendor: Crucial model: CT500MX500SSD1 size: 465.76 GiB
    ID-2: /dev/sdb vendor: Western Digital model: WD10EURX-73FH1Y0
    ID-3: /dev/sdc vendor: Western Digital model: WD10EZRX-00A8LB0
    ID-4: /dev/sdd vendor: Toshiba model: MQ01UBD050 size: 465.76 GiB
    type: USB
    ID-1: / size: 456.35 GiB used: 122.02 GiB (26.7%) fs: ext4 dev: /dev/sda2
    ID-2: /boot/efi size: 1.05 GiB used: 6.1 MiB (0.6%) fs: vfat
    dev: /dev/sda1
    ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) file: /swap.img
    System Temperatures: cpu: 44.0 C mobo: N/A gpu: nvidia temp: 48 C
    Fan Speeds (rpm): N/A gpu: nvidia fan: 81%
    Repos:
    Active apt repos in: /etc/apt/sources.list.d/appimagelauncher-team-ubuntu-stable-noble.sources
    1: deb ppa.launchpadcontent.net/appim…ncher-team/stable/ubuntu/ noble main
    Active apt repos in: /etc/apt/sources.list.d/graphics-drivers-ubuntu-ppa-noble.sources
    1: deb ppa.launchpadcontent.net/graphics-drivers/ppa/ubuntu/ noble main
    Active apt repos in: /etc/apt/sources.list.d/ubuntu.sources
    1: deb ch.archive.ubuntu.com/ubuntu/ noble noble-updates noble-backports main restricted universe multiverse
    2: deb security.ubuntu.com/ubuntu/ noble-security main restricted universe multiverse
    Memory: total: 24 GiB available: 23.43 GiB used: 1.73 GiB (7.4%)
    Processes: 333 Uptime: 0m Shell: Bash inxi: 3.3.34
    Nach jedem Neustart ist die Auflösung auf 800x600 blockiert und kann nicht verändert werden. Der NVIDIA Driver ist weg.
     Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] driver: N/A
     Display: wayland server: X.Org v: 23.2.6 with: Xwayland v: 23.2.6
       compositor: gnome-shell driver: X: loaded: nvidia
       unloaded: fbdev,modesetting,nouveau,vesa dri: swrast gpu: N/A
       resolution: 800x600~60Hz
     API: EGL v: 1.5 drivers: swrast
       platforms: wayland,x11,surfaceless,device
     API: OpenGL v: 4.5 vendor: mesa v: 25.0.7-0ubuntu0.24.04.2
       renderer: llvmpipe (LLVM 20.1.2 256 bits)
    Ich kann das System aktualisieren, aber nach dem erforderlichen Neustart ist die Grafik wieder blockiert.
    Damit ich weiterarbeiten kann, hole ich den vorherigen Zustand mit Timeshift zurück.
    Was könnte die Ursache dieses mühsamen Zustandes sein? Danke für Tipps.
    Ruschco
  • Du hast keinen Treiber installiert.
    Zeigt dir eine Treiberliste an:
    ubuntu-drivers devices
    Installiert automatisch den passenden Treiber:
    sudo ubuntu-drivers autoinstall
    Überprüft den installierten Treiber:
    nvidia-smi
    Arbeite das mal durch
    MfG Nico
  • Ruschgo
    Probiere dies aus:
    Neumann
    December 31, 2025 at 1:25 PM
    Mein System
  • Für die Karte kriegste keinen proprietären Treiber mehr.:(
    What?
    die 10xx Karten sind raus, aber doch nicht die 30xx
    =O
    Wobei da ja auch der 580 Treiber weiterfunktioniert....
    Bei mir z.B.
    Liebe Grüsse
    Martin
    Mein altes Schlachtross:
    Thinkstation S30
    (MX 25.2 KDE)
    Mobil: Thinkpad X1 Yoga G4
    (Debian 13 KDE)
  • What?
    =O
    Bei mir z.B.
    Sorry, ich hatte das am Handy stümperhaft überflogen und mich am Alter der CPU orientiert. Du hast natürlich Recht.
  • Nur mal so Interesse halber. Secureboot ist deaktiviert? Das in Verbindung mit dem nouveau-Treiber bereitet manchmal Probleme
    MfG Nico
  • ... oder eben das, was Neumann zum nVidia-Treiber schrieb. Das ist in Beitrag #4 verlinkt.
    Es ist erforderlich, bestimmte Module/Dienste vor dem Neustart vorbereitend eingestellt werden.
    Mein System
  • Ruschgo
    Probiere dies aus:
    Neumann
    Fantastisch! Der 'initramfs'-Trick hat funktioniert. Danke!
  • Der Fehler ist zurück! Nach Aktualisierung (Kernel: 6.14.0-37-generic) wieder das gleiche Ungemach. Nach Neustart ist die Auflösung auf 800x600 blockiert.
    In /etc/initramfs-tools/ modules sind die Einträge immer noch da
    nvidia
    nvidia-modeset
    nvidia-drm
    ausgeführt: sudo update-initramfs -u
    Mit Timeshift konnte ich wieder zurückstellen ( 6.14.0-36-generic).
    Was kann man da machen?
    Ruschgo
  • Problem gelöst.
    Du meinst, Problem umgangen. Ich versuche immer den Nvidia-Treiber soweit als möglich nicht zu verwenden. Der Nouveau reicht völlig aus, wenn man keine extremen Grafikanwendungen laufen hat.
