- Distrowahl
- Sonstiges
- System:
Kernel: 6.18.2-200.nobara.fc43.x86_64 arch: x86_64 bits: 64 compiler: gcc
v: 15.2.1
Desktop: KDE Plasma v: 6.5.4 Distro: Nobara Linux 43 (KDE Plasma Desktop
Edition) base: Fedora 43
Mobo: ASUSTeK model: TUF GAMING B850-PLUS WIFI v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 0806
date: 10/09/2024
Battery:
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M315/M235
charge: 55% (should be ignored) status: discharging
Info: 6-core model: AMD Ryzen 5 9600X bits: 64 type: MT MCP arch: Zen 5
rev: 0 cache: L1: 480 KiB L2: 6 MiB L3: 32 MiB
Speed (MHz): avg: 3008 min/max: 628/5486 boost: enabled cores: 1: 3008
2: 3008 3: 3008 4: 3008 5: 3008 6: 3008 7: 3008 8: 3008 9: 3008 10: 3008
11: 3008 12: 3008 bogomips: 93599
Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a
ssse3 svm
Device-1: Advanced Micro Devices [AMD/ATI] Navi 44 [Radeon RX 9060 XT]
vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-4 bus-ID: 03:00.0
Device-2: Advanced Micro Devices [AMD/ATI] Granite Ridge [Radeon Graphics]
vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2 bus-ID: 0f:00.0
temp: 40.0 C
Display: wayland server: Xwayland v: 24.1.9 compositor: kwin_wayland
driver: gpu: amdgpu resolution: 2560x1440~240Hz
API: EGL v: 1.5 drivers: radeonsi,swrast platforms:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.2 glx-v: 1.4
direct-render: yes renderer: AMD Radeon Graphics (radeonsi gfx1200 LLVM
21.1.7 DRM 3.64 6.18.2-200.nobara.fc43.x86_64)
API: Vulkan v: 1.4.328 drivers: radv,llvmpipe surfaces: N/A devices: 3
de: kscreen-console,kscreen-doctor wl: wayland-info x11: xdriinfo,
xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 HDMI/DP Audio
driver: snd_hda_intel v: kernel bus-ID: 03:00.1
Device-2: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 0f:00.1
Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0f:00.6
Device-4: Logitech G435 Wireless Gaming Headset
driver: hid-generic,snd-usb-audio,usbhid type: USB bus-ID: 1-2:2
API: ALSA v: k6.18.2-200.nobara.fc43.x86_64 status: kernel-api
Server-1: PipeWire v: 1.4.9 status: active
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
port: e000 bus-ID: 0a:00.0
Device-2: MEDIATEK MT7925 802.11be 160MHz 2x2 PCIe Wireless Network
Adapter [Filogic 360] vendor: AzureWave driver: mt7925e v: kernel
bus-ID: 0b:00.0
IF: wlp11s0 state: up mac: <filter>
Bluetooth:
Device-1: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB
bus-ID: 1-6:4
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.4
lmp-v: 13
Local Storage: total: 2.73 TiB used: 551.03 GiB (19.7%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 990 EVO Plus 1TB
size: 931.51 GiB temp: 31.9 C
ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 990 PRO 2TB size: 1.82 TiB
temp: 26.9 C
ID-1: / size: 1.78 TiB used: 550.46 GiB (30.1%) fs: btrfs
dev: /dev/nvme1n1p3
ID-2: /boot size: 1.9 GiB used: 566 MiB (29.1%) fs: ext4
dev: /dev/nvme1n1p2
ID-3: /boot/efi size: 598.8 MiB used: 19.3 MiB (3.2%) fs: vfat
dev: /dev/nvme1n1p1
ID-4: /home size: 1.78 TiB used: 550.46 GiB (30.1%) fs: btrfs
dev: /dev/nvme1n1p3
ID-1: swap-1 type: zram size: 8 GiB used: 0 KiB (0.0%) dev: /dev/zram0
ID-2: swap-2 type: partition size: 33.53 GiB used: 0 KiB (0.0%)
dev: /dev/nvme1n1p4
System Temperatures: cpu: 46.6 C mobo: 38.0 C
Fan Speeds (rpm): N/A
GPU: device: amdgpu temp: 41.0 C device: amdgpu temp: 36.0 C fan: 0
Memory: total: 32 GiB note: est. available: 30.48 GiB used: 5.4 GiB (17.7%)
Processes: 398 Uptime: 37m Init: systemd
Packages: 16 note: see --rpm Compilers: gcc: 15.2.1 Shell: Bash v: 5.3.0
inxi: 3.3.39
ckb-next:
ckb-next-dev-detect - Mon Dec 29 18:20:50 CET 2025
Kernel: Linux nobara-pc 6.18.2-200.nobara.fc43.x86_64 #1 SMP PREEMPT_DYNAMIC Fri Dec 19 07:58:09 UTC 2025 x86_64 GNU/Linux
OS Version:
LSB Version: n/a
Distributor ID: NobaraLinux
Description: Nobara Linux 43 (KDE Plasma Desktop Edition)
Release: 43
Codename: n/a
USB Devices:
Bus 005 Device 004: ID 1b1c:1bfd Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard
Negotiated speed: Full Speed (12Mbps)
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 [unknown]
bDeviceSubClass 0 [unknown]
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x1b1c Corsair
idProduct 0x1bfd CORSAIR K70 CORE RGB Mechanical Gaming Keyboard
bcdDevice 1.17
iManufacturer 1 Corsair
iProduct 2 CORSAIR K70 CORE RGB Mechanical Gaming Keyboard
iSerial 3 08019005AFC99CA963D96787F5001BC6
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x0074
bNumInterfaces 4
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 500mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 1 Boot Interface Subclass
bInterfaceProtocol 1 Keyboard
iInterface 0
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.11
bCountryCode 0 Not supported
bNumDescriptors 1
bDescriptorType 34 (null)
wDescriptorLength 125
Report Descriptors:
** UNAVAILABLE **
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
bInterfaceSubClass 0 [unknown]
bInterfaceProtocol 0
iInterface 0
bLength 9
bDescriptorType 33
bcdHID 1.11
bNumDescriptors 1
wDescriptorLength 27
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x04 EP 4 OUT
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 9
bDescriptorType 33
bcdHID 1.11
bNumDescriptors 1
wDescriptorLength 21
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 1
bInterfaceProtocol 2 Mouse
iInterface 0
bLength 9
bDescriptorType 33
bcdHID 1.11
bNumDescriptors 1
wDescriptorLength 75
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 1
Device Status: 0x0000
(Bus Powered)
Dmesg on current boot:
Dec 29 18:06:05.845024 nobara-pc kernel: usb 5-2: New USB device found, idVendor=1b1c, idProduct=1bfd, bcdDevice= 1.17
Dec 29 18:06:05.845112 nobara-pc kernel: usb 5-2: Product: CORSAIR K70 CORE RGB Mechanical Gaming Keyboard
Dec 29 18:06:05.845154 nobara-pc kernel: usb 5-2: Manufacturer: Corsair
Dec 29 18:06:05.845202 nobara-pc kernel: input: Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard as /devices/pci0000:00/0000:00:08.1/0000:0f:00.4/usb5/5-2/5-2:1.0/0003:1B1C:1BFD.0001/input/input2
Dec 29 18:06:05.845269 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.0001: input,hidraw0: USB HID v1.11 Keyboard [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.4-2/input0
Dec 29 18:06:05.845334 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.0002: hiddev96,hidraw1: USB HID v1.11 Device [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.4-2/input1
Dec 29 18:06:05.845398 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.0003: hiddev97,hidraw2: USB HID v1.11 Device [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.4-2/input2
Dec 29 18:06:05.845402 nobara-pc kernel: input: Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard as /devices/pci0000:00/0000:00:08.1/0000:0f:00.4/usb5/5-2/5-2:1.3/0003:1B1C:1BFD.0004/input/input3
Dec 29 18:06:05.845465 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.0004: input,hidraw3: USB HID v1.11 Mouse [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.4-2/input3
Dec 29 18:11:24.561592 nobara-pc kernel: usb 1-4.3: New USB device found, idVendor=1b1c, idProduct=1bfd, bcdDevice= 1.17
Dec 29 18:11:24.561950 nobara-pc kernel: usb 1-4.3: Product: CORSAIR K70 CORE RGB Mechanical Gaming Keyboard
Dec 29 18:11:24.562020 nobara-pc kernel: usb 1-4.3: Manufacturer: Corsair
Dec 29 18:11:24.626533 nobara-pc kernel: input: Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard as /devices/pci0000:00/0000:00:02.1/0000:05:00.0/0000:06:0c.0/0000:0c:00.0/usb1/1-4/1-4.3/1-4.3:1.0/0003:1B1C:1BFD.000C/input/input35
Dec 29 18:11:24.696528 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.000C: input,hidraw0: USB HID v1.11 Keyboard [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0c:00.0-4.3/input0
Dec 29 18:11:24.714540 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.000D: hiddev96,hidraw1: USB HID v1.11 Device [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0c:00.0-4.3/input1
Dec 29 18:11:24.731519 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.000E: hiddev97,hidraw2: USB HID v1.11 Device [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0c:00.0-4.3/input2
Dec 29 18:11:24.752531 nobara-pc kernel: input: Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard as /devices/pci0000:00/0000:00:02.1/0000:05:00.0/0000:06:0c.0/0000:0c:00.0/usb1/1-4/1-4.3/1-4.3:1.3/0003:1B1C:1BFD.000F/input/input36
Dec 29 18:11:24.752618 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.000F: input,hidraw3: USB HID v1.11 Mouse [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0c:00.0-4.3/input3
Dec 29 18:12:58.299514 nobara-pc kernel: usb 3-2: New USB device found, idVendor=1b1c, idProduct=1bfd, bcdDevice= 1.17
Dec 29 18:12:58.299579 nobara-pc kernel: usb 3-2: Product: CORSAIR K70 CORE RGB Mechanical Gaming Keyboard
Dec 29 18:12:58.299699 nobara-pc kernel: usb 3-2: Manufacturer: Corsair
Dec 29 18:12:58.321509 nobara-pc kernel: input: Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard as /devices/pci0000:00/0000:00:08.1/0000:0f:00.3/usb3/3-2/3-2:1.0/0003:1B1C:1BFD.0010/input/input37
Dec 29 18:12:58.417539 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.0010: input,hidraw0: USB HID v1.11 Keyboard [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.3-2/input0
Dec 29 18:12:58.424507 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.0011: hiddev96,hidraw1: USB HID v1.11 Device [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.3-2/input1
Dec 29 18:12:58.431517 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.0012: hiddev97,hidraw2: USB HID v1.11 Device [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.3-2/input2
Dec 29 18:12:58.439517 nobara-pc kernel: input: Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard as /devices/pci0000:00/0000:00:08.1/0000:0f:00.3/usb3/3-2/3-2:1.3/0003:1B1C:1BFD.0013/input/input38
Dec 29 18:12:58.440507 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.0013: input,hidraw3: USB HID v1.11 Mouse [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.3-2/input3
Dec 29 18:13:34.603517 nobara-pc kernel: usb 5-1: New USB device found, idVendor=1b1c, idProduct=1bfd, bcdDevice= 1.17
Dec 29 18:13:34.603567 nobara-pc kernel: usb 5-1: Product: CORSAIR K70 CORE RGB Mechanical Gaming Keyboard
Dec 29 18:13:34.603581 nobara-pc kernel: usb 5-1: Manufacturer: Corsair
Dec 29 18:13:34.625517 nobara-pc kernel: input: Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard as /devices/pci0000:00/0000:00:08.1/0000:0f:00.4/usb5/5-1/5-1:1.0/0003:1B1C:1BFD.0014/input/input39
Dec 29 18:13:34.709584 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.0014: input,hidraw0: USB HID v1.11 Keyboard [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.4-1/input0
Dec 29 18:13:34.716523 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.0015: hiddev96,hidraw1: USB HID v1.11 Device [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.4-1/input1
Dec 29 18:13:34.724523 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.0016: hiddev97,hidraw2: USB HID v1.11 Device [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.4-1/input2
Dec 29 18:13:34.732509 nobara-pc kernel: input: Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard as /devices/pci0000:00/0000:00:08.1/0000:0f:00.4/usb5/5-1/5-1:1.3/0003:1B1C:1BFD.0017/input/input40
Dec 29 18:13:34.732537 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.0017: input,hidraw3: USB HID v1.11 Mouse [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.4-1/input3
Dec 29 18:16:40.377538 nobara-pc kernel: usb 5-2: New USB device found, idVendor=1b1c, idProduct=1bfd, bcdDevice= 1.17
Dec 29 18:16:40.377826 nobara-pc kernel: usb 5-2: Product: CORSAIR K70 CORE RGB Mechanical Gaming Keyboard
Dec 29 18:16:40.377916 nobara-pc kernel: usb 5-2: Manufacturer: Corsair
Dec 29 18:16:40.399528 nobara-pc kernel: input: Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard as /devices/pci0000:00/0000:00:08.1/0000:0f:00.4/usb5/5-2/5-2:1.0/0003:1B1C:1BFD.0018/input/input41
Dec 29 18:16:40.478753 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.0018: input,hidraw0: USB HID v1.11 Keyboard [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.4-2/input0
Dec 29 18:16:40.484516 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.0019: hiddev96,hidraw1: USB HID v1.11 Device [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.4-2/input1
Dec 29 18:16:40.492520 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.001A: hiddev97,hidraw2: USB HID v1.11 Device [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.4-2/input2
Dec 29 18:16:40.500521 nobara-pc kernel: input: Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard as /devices/pci0000:00/0000:00:08.1/0000:0f:00.4/usb5/5-2/5-2:1.3/0003:1B1C:1BFD.001B/input/input42
Dec 29 18:16:40.500583 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.001B: input,hidraw3: USB HID v1.11 Mouse [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.4-2/input3
Dmesg on last boot:
Dec 07 22:59:52.689362 nobara-pc kernel: usb 1-2: New USB device found, idVendor=1b1c, idProduct=1bfd, bcdDevice= 1.17
Dec 07 22:59:52.689618 nobara-pc kernel: usb 1-2: Product: CORSAIR K70 CORE RGB Mechanical Gaming Keyboard
Dec 07 22:59:52.689660 nobara-pc kernel: usb 1-2: Manufacturer: Corsair
Dec 07 22:59:52.738358 nobara-pc kernel: input: Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard as /devices/pci0000:00/0000:00:02.1/0000:05:00.0/0000:06:0c.0/0000:0c:00.0/usb1/1-2/1-2:1.0/0003:1B1C:1BFD.0008/input/input33
Dec 07 22:59:52.816367 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.0008: input,hidraw4: USB HID v1.11 Keyboard [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0c:00.0-2/input0
Dec 07 22:59:52.823378 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.0009: hiddev99,hidraw6: USB HID v1.11 Device [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0c:00.0-2/input1
Dec 07 22:59:52.832360 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.000A: hiddev100,hidraw7: USB HID v1.11 Device [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0c:00.0-2/input2
Dec 07 22:59:52.842352 nobara-pc kernel: input: Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard as /devices/pci0000:00/0000:00:02.1/0000:05:00.0/0000:06:0c.0/0000:0c:00.0/usb1/1-2/1-2:1.3/0003:1B1C:1BFD.000B/input/input34
Dec 07 22:59:52.842368 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.000B: input,hidraw8: USB HID v1.11 Mouse [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0c:00.0-2/input3
Dec 08 15:58:01.378628 nobara-pc kernel: usb 1-2: New USB device found, idVendor=1b1c, idProduct=1bfd, bcdDevice= 1.17
Dec 08 15:58:01.378820 nobara-pc kernel: usb 1-2: Product: CORSAIR K70 CORE RGB Mechanical Gaming Keyboard
Dec 08 15:58:01.378850 nobara-pc kernel: usb 1-2: Manufacturer: Corsair
Dec 08 15:58:01.427618 nobara-pc kernel: input: Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard as /devices/pci0000:00/0000:00:02.1/0000:05:00.0/0000:06:0c.0/0000:0c:00.0/usb1/1-2/1-2:1.0/0003:1B1C:1BFD.000C/input/input36
Dec 08 15:58:01.529619 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.000C: input,hidraw4: USB HID v1.11 Keyboard [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0c:00.0-2/input0
Dec 08 15:58:01.536626 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.000D: hiddev99,hidraw6: USB HID v1.11 Device [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0c:00.0-2/input1
Dec 08 15:58:01.545617 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.000E: hiddev100,hidraw7: USB HID v1.11 Device [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0c:00.0-2/input2
Dec 08 15:58:01.555617 nobara-pc kernel: input: Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard as /devices/pci0000:00/0000:00:02.1/0000:05:00.0/0000:06:0c.0/0000:0c:00.0/usb1/1-2/1-2:1.3/0003:1B1C:1BFD.000F/input/input37
Dec 08 15:58:01.555642 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.000F: input,hidraw8: USB HID v1.11 Mouse [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0c:00.0-2/input3
Dec 29 16:48:10.500801 nobara-pc kernel: usb 5-2: New USB device found, idVendor=1b1c, idProduct=1bfd, bcdDevice= 1.17
Dec 29 16:48:10.501039 nobara-pc kernel: usb 5-2: Product: CORSAIR K70 CORE RGB Mechanical Gaming Keyboard
Dec 29 16:48:10.501086 nobara-pc kernel: usb 5-2: Manufacturer: Corsair
Dec 29 16:48:10.522796 nobara-pc kernel: input: Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard as /devices/pci0000:00/0000:00:08.1/0000:0f:00.4/usb5/5-2/5-2:1.0/0003:1B1C:1BFD.0016/input/input63
Dec 29 16:48:10.615852 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.0016: input,hidraw4: USB HID v1.11 Keyboard [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.4-2/input0
Dec 29 16:48:10.621803 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.0017: hiddev99,hidraw6: USB HID v1.11 Device [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.4-2/input1
Dec 29 16:48:10.629802 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.0018: hiddev100,hidraw7: USB HID v1.11 Device [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.4-2/input2
Dec 29 16:48:10.637792 nobara-pc kernel: input: Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard as /devices/pci0000:00/0000:00:08.1/0000:0f:00.4/usb5/5-2/5-2:1.3/0003:1B1C:1BFD.0019/input/input64
Dec 29 16:48:10.637810 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.0019: input,hidraw8: USB HID v1.11 Mouse [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.4-2/input3
Dec 29 16:48:58.420798 nobara-pc kernel: usb 5-2: New USB device found, idVendor=1b1c, idProduct=1bfd, bcdDevice= 1.17
Dec 29 16:48:58.421031 nobara-pc kernel: usb 5-2: Product: CORSAIR K70 CORE RGB Mechanical Gaming Keyboard
Dec 29 16:48:58.421074 nobara-pc kernel: usb 5-2: Manufacturer: Corsair
Dec 29 16:48:58.442794 nobara-pc kernel: input: Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard as /devices/pci0000:00/0000:00:08.1/0000:0f:00.4/usb5/5-2/5-2:1.0/0003:1B1C:1BFD.001A/input/input65
Dec 29 16:48:58.519813 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.001A: input,hidraw4: USB HID v1.11 Keyboard [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.4-2/input0
Dec 29 16:48:58.525827 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.001B: hiddev99,hidraw6: USB HID v1.11 Device [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.4-2/input1
Dec 29 16:48:58.533802 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.001C: hiddev100,hidraw7: USB HID v1.11 Device [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.4-2/input2
Dec 29 16:48:58.541793 nobara-pc kernel: input: Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard as /devices/pci0000:00/0000:00:08.1/0000:0f:00.4/usb5/5-2/5-2:1.3/0003:1B1C:1BFD.001D/input/input66
Dec 29 16:48:58.541808 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.001D: input,hidraw8: USB HID v1.11 Mouse [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.4-2/input3
Dec 29 16:49:37.174810 nobara-pc kernel: usb 5-2: New USB device found, idVendor=1b1c, idProduct=1bfd, bcdDevice= 1.17
Dec 29 16:49:37.175166 nobara-pc kernel: usb 5-2: Product: CORSAIR K70 CORE RGB Mechanical Gaming Keyboard
Dec 29 16:49:37.175244 nobara-pc kernel: usb 5-2: Manufacturer: Corsair
Dec 29 16:49:37.196794 nobara-pc kernel: input: Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard as /devices/pci0000:00/0000:00:08.1/0000:0f:00.4/usb5/5-2/5-2:1.0/0003:1B1C:1BFD.001E/input/input67
Dec 29 16:49:37.277818 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.001E: input,hidraw4: USB HID v1.11 Keyboard [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.4-2/input0
Dec 29 16:49:37.283817 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.001F: hiddev99,hidraw5: USB HID v1.11 Device [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.4-2/input1
Dec 29 16:49:37.291808 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.0020: hiddev100,hidraw6: USB HID v1.11 Device [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.4-2/input2
Dec 29 16:49:37.299797 nobara-pc kernel: input: Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard as /devices/pci0000:00/0000:00:08.1/0000:0f:00.4/usb5/5-2/5-2:1.3/0003:1B1C:1BFD.0021/input/input68
Dec 29 16:49:37.299840 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.0021: input,hidraw7: USB HID v1.11 Mouse [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.4-2/input3
Dec 29 17:39:01.389798 nobara-pc kernel: usb 5-2: New USB device found, idVendor=1b1c, idProduct=1bfd, bcdDevice= 1.17
Dec 29 17:39:01.390017 nobara-pc kernel: usb 5-2: Product: CORSAIR K70 CORE RGB Mechanical Gaming Keyboard
Dec 29 17:39:01.390064 nobara-pc kernel: usb 5-2: Manufacturer: Corsair
Dec 29 17:39:01.410797 nobara-pc kernel: input: Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard as /devices/pci0000:00/0000:00:08.1/0000:0f:00.4/usb5/5-2/5-2:1.0/0003:1B1C:1BFD.0023/input/input70
Dec 29 17:39:01.497856 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.0023: input,hidraw4: USB HID v1.11 Keyboard [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.4-2/input0
Dec 29 17:39:01.504796 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.0024: hiddev99,hidraw5: USB HID v1.11 Device [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.4-2/input1
Dec 29 17:39:01.512794 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.0025: hiddev100,hidraw6: USB HID v1.11 Device [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.4-2/input2
Dec 29 17:39:01.520794 nobara-pc kernel: input: Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard as /devices/pci0000:00/0000:00:08.1/0000:0f:00.4/usb5/5-2/5-2:1.3/0003:1B1C:1BFD.0026/input/input71
Dec 29 17:39:01.520846 nobara-pc kernel: hid-generic 0003:1B1C:1BFD.0026: input,hidraw7: USB HID v1.11 Mouse [Corsair CORSAIR K70 CORE RGB Mechanical Gaming Keyboard] on usb-0000:0f:00.4-2/input3
Daemon on current boot:
Dec 29 18:06:10.850408 nobara-pc systemd[1]: Started ckb-next-daemon.service - Corsair Keyboards and Mice Daemon.
Dec 29 18:06:10.852173 nobara-pc ckb-next-daemon[1257]: ckb-next-daemon 0.6.2
Dec 29 18:06:10.852309 nobara-pc ckb-next-daemon[1257]: [I] Root controller ready at /dev/input/ckb0
Daemon on last boot:
Dec 29 17:33:41.642162 nobara-pc systemd[1]: Started ckb-next-daemon.service - Corsair Keyboards and Mice Daemon.
Dec 29 17:33:41.665462 nobara-pc ckb-next-daemon[792777]: ckb-next-daemon 0.6.2
Dec 29 17:33:41.665684 nobara-pc ckb-next-daemon[792777]: [I] Root controller ready at /dev/input/ckb0
Dec 29 17:59:46.357635 nobara-pc ckb-next-daemon[792777]: [I] Caught signal 15
Dec 29 17:59:46.357635 nobara-pc ckb-next-daemon[792777]: [I] Closing root controller
Dec 29 17:59:46.357635 nobara-pc ckb-next-daemon[792777]: [I] Removed device path /dev/input/ckb0
Dec 29 17:59:46.354547 nobara-pc systemd[1]: Stopping ckb-next-daemon.service - Corsair Keyboards and Mice Daemon...
Dec 29 17:59:46.373135 nobara-pc systemd[1]: ckb-next-daemon.service: Deactivated successfully.
Dec 29 17:59:46.373250 nobara-pc systemd[1]: Stopped ckb-next-daemon.service - Corsair Keyboards and Mice Daemon.
Dev nodes:
/dev/input/ckb0
/dev/input/ckb0/pid
1257
/dev/input/ckb0/version
0.6.2
/dev/input/ckb0/connected
Kernel command line:
BOOT_IMAGE=(hd0,gpt2)/vmlinuz-6.18.2-200.nobara.fc43.x86_64 root=UUID=c28c74eb-3b50-4b64-9469-baff9a7d1cb4 ro rootflags=subvol=@ quiet splash resume=UUID=9e9073ca-004e-4bd5-9dce-44238932fc07
GUI ldd:
linux-vdso.so.1 (0x00007fb899bfe000)
libQt6Network.so.6 => /lib64/libQt6Network.so.6 (0x00007fb899400000)
libQt6OpenGLWidgets.so.6 => /lib64/libQt6OpenGLWidgets.so.6 (0x00007fb899bc8000)
libxcb-ewmh.so.2 => /lib64/libxcb-ewmh.so.2 (0x00007fb899bba000)
libxcb.so.1 => /lib64/libxcb.so.1 (0x00007fb899b90000)
libxcb-screensaver.so.0 => /lib64/libxcb-screensaver.so.0 (0x00007fb899b8a000)
libpulse.so.0 => /lib64/libpulse.so.0 (0x00007fb899b3a000)
libquazip1-qt6.so.1.4.0 => /lib64/libquazip1-qt6.so.1.4.0 (0x00007fb899af9000)
libQt6Widgets.so.6 => /lib64/libQt6Widgets.so.6 (0x00007fb898c00000)
libQt6Gui.so.6 => /lib64/libQt6Gui.so.6 (0x00007fb898000000)
libQt6DBus.so.6 => /lib64/libQt6DBus.so.6 (0x00007fb899725000)
libQt6Core.so.6 => /lib64/libQt6Core.so.6 (0x00007fb897800000)
libstdc++.so.6 => /lib64/libstdc++.so.6 (0x00007fb897400000)
libm.so.6 => /lib64/libm.so.6 (0x00007fb899630000)
libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007fb899acb000)
libc.so.6 => /lib64/libc.so.6 (0x00007fb89720d000)
libzstd.so.1 => /lib64/libzstd.so.1 (0x00007fb898b3d000)
libgssapi_krb5.so.2 => /lib64/libgssapi_krb5.so.2 (0x00007fb899a75000)
libbrotlidec.so.1 => /lib64/libbrotlidec.so.1 (0x00007fb899a67000)
libz.so.1 => /lib64/libz.so.1 (0x00007fb898b15000)
libproxy.so.1 => /lib64/libproxy.so.1 (0x00007fb899a61000)
libcrypto.so.3 => /lib64/libcrypto.so.3 (0x00007fb896c00000)
libQt6OpenGL.so.6 => /lib64/libQt6OpenGL.so.6 (0x00007fb898a65000)
libXau.so.6 => /lib64/libXau.so.6 (0x00007fb899a5c000)
libpulsecommon-17.0.so => /usr/lib64/pulseaudio/libpulsecommon-17.0.so (0x00007fb897f7c000)
libdbus-1.so.3 => /lib64/libdbus-1.so.3 (0x00007fb897f28000)
libQt6Core5Compat.so.6 => /lib64/libQt6Core5Compat.so.6 (0x00007fb8977a1000)
libbz2.so.1 => /lib64/libbz2.so.1 (0x00007fb89961a000)
libEGL.so.1 => /lib64/libEGL.so.1 (0x00007fb898a54000)
libfontconfig.so.1 => /lib64/libfontconfig.so.1 (0x00007fb897ed8000)
libX11.so.6 => /lib64/libX11.so.6 (0x00007fb896abb000)
libglib-2.0.so.0 => /lib64/libglib-2.0.so.0 (0x00007fb896965000)
libxkbcommon.so.0 => /lib64/libxkbcommon.so.0 (0x00007fb897748000)
libGLX.so.0 => /lib64/libGLX.so.0 (0x00007fb898a23000)
libOpenGL.so.0 => /lib64/libOpenGL.so.0 (0x00007fb897724000)
libpng16.so.16 => /lib64/libpng16.so.16 (0x00007fb8976e9000)
libharfbuzz.so.0 => /lib64/libharfbuzz.so.0 (0x00007fb896831000)
libfreetype.so.6 => /lib64/libfreetype.so.6 (0x00007fb897143000)
libicui18n.so.77 => /lib64/libicui18n.so.77 (0x00007fb896400000)
libicuuc.so.77 => /lib64/libicuuc.so.77 (0x00007fb896000000)
libsystemd.so.0 => /lib64/libsystemd.so.0 (0x00007fb8962d9000)
libdouble-conversion.so.3 => /lib64/libdouble-conversion.so.3 (0x00007fb8976d3000)
libb2.so.1 => /lib64/libb2.so.1 (0x00007fb8976c9000)
libpcre2-16.so.0 => /lib64/libpcre2-16.so.0 (0x00007fb896792000)
/lib64/ld-linux-x86-64.so.2 (0x00007fb899c00000)
libkrb5.so.3 => /lib64/libkrb5.so.3 (0x00007fb89620f000)
libk5crypto.so.3 => /lib64/libk5crypto.so.3 (0x00007fb8976b2000)
libcom_err.so.2 => /lib64/libcom_err.so.2 (0x00007fb897ed2000)
libkrb5support.so.0 => /lib64/libkrb5support.so.0 (0x00007fb8976a2000)
libkeyutils.so.1 => /lib64/libkeyutils.so.1 (0x00007fb89769c000)
libresolv.so.2 => /lib64/libresolv.so.2 (0x00007fb89768a000)
libbrotlicommon.so.1 => /lib64/libbrotlicommon.so.1 (0x00007fb895fdd000)
libpxbackend-1.0.so => /usr/lib64/libproxy/libpxbackend-1.0.so (0x00007fb89767a000)
libgobject-2.0.so.0 => /lib64/libgobject-2.0.so.0 (0x00007fb895f7e000)
libsndfile.so.1 => /lib64/libsndfile.so.1 (0x00007fb895efe000)
libasyncns.so.0 => /lib64/libasyncns.so.0 (0x00007fb89678b000)
libGLdispatch.so.0 => /lib64/libGLdispatch.so.0 (0x00007fb895e86000)
libxml2.so.2 => /lib64/libxml2.so.2 (0x00007fb895d28000)
libpcre2-8.so.0 => /lib64/libpcre2-8.so.0 (0x00007fb895c7b000)
libXext.so.6 => /lib64/libXext.so.6 (0x00007fb895c67000)
libgraphite2.so.3 => /lib64/libgraphite2.so.3 (0x00007fb895c48000)
libicudata.so.77 => /lib64/libicudata.so.77 (0x00007fb893c00000)
libcap.so.2 => /lib64/libcap.so.2 (0x00007fb895c3c000)
libgomp.so.1 => /lib64/libgomp.so.1 (0x00007fb895be4000)
libselinux.so.1 => /lib64/libselinux.so.1 (0x00007fb895bb3000)
libcurl.so.4 => /lib64/libcurl.so.4 (0x00007fb895ad4000)
libgio-2.0.so.0 => /lib64/libgio-2.0.so.0 (0x00007fb893a2d000)
libduktape.so.207 => /lib64/libduktape.so.207 (0x00007fb895a89000)
libffi.so.8 => /lib64/libffi.so.8 (0x00007fb895a79000)
libgsm.so.1 => /lib64/libgsm.so.1 (0x00007fb893a1f000)
libFLAC.so.14 => /lib64/libFLAC.so.14 (0x00007fb8939cd000)
libvorbis.so.0 => /lib64/libvorbis.so.0 (0x00007fb89399e000)
libvorbisenc.so.2 => /lib64/libvorbisenc.so.2 (0x00007fb893906000)
libopus.so.0 => /lib64/libopus.so.0 (0x00007fb89389b000)
libogg.so.0 => /lib64/libogg.so.0 (0x00007fb896781000)
libmpg123.so.0 => /lib64/libmpg123.so.0 (0x00007fb89383e000)
libmp3lame.so.0 => /lib64/libmp3lame.so.0 (0x00007fb8937c5000)
liblzma.so.5 => /lib64/liblzma.so.5 (0x00007fb893790000)
libnghttp2.so.14 => /lib64/libnghttp2.so.14 (0x00007fb893768000)
libidn2.so.0 => /lib64/libidn2.so.0 (0x00007fb893718000)
libldap.so.2 => /lib64/libldap.so.2 (0x00007fb8936b1000)
liblber.so.2 => /lib64/liblber.so.2 (0x00007fb8936a0000)
libssh.so.4 => /lib64/libssh.so.4 (0x00007fb893623000)
libpsl.so.5 => /lib64/libpsl.so.5 (0x00007fb89360f000)
libssl.so.3 => /lib64/libssl.so.3 (0x00007fb893524000)
libgmodule-2.0.so.0 => /lib64/libgmodule-2.0.so.0 (0x00007fb896205000)
libmount.so.1 => /lib64/libmount.so.1 (0x00007fb8934cf000)
libunistring.so.5 => /lib64/libunistring.so.5 (0x00007fb893322000)
libevent-2.1.so.7 => /lib64/libevent-2.1.so.7 (0x00007fb8932cb000)
libsasl2.so.3 => /lib64/libsasl2.so.3 (0x00007fb8932ac000)
libblkid.so.1 => /lib64/libblkid.so.1 (0x00007fb893272000)
libcrypt.so.2 => /lib64/libcrypt.so.2 (0x00007fb89323d000)
Environment:
XDG_SESSION_DESKTOP=KDE
XDG_SESSION_TYPE=wayland
QT_BEARER_POLL_TIMEOUT=-1
XDG_CURRENT_DESKTOP=KDE
WAYLAND_DISPLAY=wayland-0
QT_WAYLAND_RECONNECT=1
DISPLAY=:0
Hallo Zusammen
Ich möchte meine neue Tastatur Corsair K70 Core RGB mit meinem Nobara Linux PC verwenden. Leider reagiert der PC auf keine Tastatureingabe. Ich habe sie bereits unter Windows getestet, da funktioniert sie normal, auch mit der ICUE Software. Da es diese Software leider nicht für Linux gibt, habe ich mich Informiert, was es für Möglichkeiten gibt, und bin auf das Programm ckb-next gestossen, das die Corsair Geräte unter Linux steuern soll. die Software zeigt mir an, dass kein Gerät gefunden wurde. Die Tastatur leuchtet jedoch, und ein Drehrad für die Mediensteuerung auf der Tastatur, funktioniert auch problemlos. Des weiteren wird sie beim einstecken auch als Corsair K70 Core RGB erkannt. Als Vermutung habe ich noch, dass die Tastatur nicht als Tastatur, sondern als "Mediensteuerung" erkannt wird, kann das sein? Ich habe in der ckb-next Software mal ein Report erstellt, vielleicht hilft das. Die Angaben dazu habe ich ins obere Feld unter den Systeminfos eingefügt.
Vielen Dank und beste Grüsse
manabu
