Debian 13 - KDE Plasma Virtuelle Tastatur
    Sonstiges
    Kernel: 6.17.1-surface-2 arch: x86_64 bits: 64 compiler: gcc v: 11.4.0
    Desktop: KDE Plasma v: 6.3.6 Distro: Debian GNU/Linux 13 (trixie)
    Type: Laptop System: Microsoft product: Surface Pro 7+
    v: 124I:00058T:000M:0000000D:0B:15F:1C:01P:16Y:0L:0U:02
    serial: <superuser required>
    Mobo: Microsoft model: Surface Pro 7+ serial: <superuser required>
    UEFI: Microsoft v: 31.101.143 date: 07/21/2025
    Battery:
    ID-1: BAT1 charge: 28.3 Wh (68.2%) condition: 41.5/48.9 Wh (85.0%)
    volts: 7.8 min: 7.6 model: SMP M1139991 status: discharging
    Info: quad core model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
    arch: Tiger Lake rev: 1 cache: L1: 320 KiB L2: 5 MiB L3: 8 MiB
    Speed (MHz): avg: 1024 min/max: 400/4200 cores: 1: 1024 2: 1024 3: 1024
    4: 1024 5: 1024 6: 1024 7: 1024 8: 1024 bogomips: 38707
    sh: 0: getcwd() failed: No such file or directory
    Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Microsoft
    driver: i915 v: kernel arch: Xe bus-ID: 00:02.0
    Display: wayland server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6
    compositor: kwin_wayland driver: X: loaded: modesetting unloaded: fbdev,vesa
    dri: iris gpu: i915 resolution: 2736x1824~60Hz
    API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.0.7-2 glx-v: 1.4
    direct-render: yes renderer: Mesa Intel Iris Xe Graphics (TGL GT2)
    API: Vulkan v: 1.4.309 drivers: intel,llvmpipe surfaces: xcb,xlib,wayland
    devices: 2
    de: kscreen-console,kscreen-doctor wl: wayland-info x11: xdriinfo,
    xdpyinfo, xprop, xrandr
    Device-1: Intel Tiger Lake IPU6 driver: intel-ipu6 bus-ID: 00:05.0
    Device-2: Intel Tiger Lake-LP Smart Sound Audio driver: snd_hda_intel
    v: kernel bus-ID: 00:1f.3
    API: ALSA v: k6.17.1-surface-2 status: kernel-api
    Server-1: PipeWire v: 1.4.2 status: active
    Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
    IF: wlp0s20f3 state: up mac: <filter>
    IF-ID-1: lxcbr0 state: down mac: <filter>
    IP v4: <filter> scope: global
    IP v6: <filter> scope: global
    Bluetooth:
    Device-1: Intel AX201 Bluetooth driver: btusb v: 0.8 type: USB
    bus-ID: 3-10:3
    Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
    lmp-v: 11
    Local Storage: total: 595.96 GiB used: 21.17 GiB (3.6%)
    ID-1: /dev/nvme0n1 vendor: SK Hynix model: HFM128GDGTNG-87A0A
    size: 119.24 GiB temp: 31.9 C
    ID-2: /dev/sda vendor: Generic model: SD MMC size: 476.71 GiB type: USB
    ID-1: / size: 109.02 GiB used: 20.98 GiB (19.2%) fs: ext4 dev: /dev/dm-1
    mapped: debian--vg-root
    ID-2: /boot size: 943.2 MiB used: 193.3 MiB (20.5%) fs: ext4
    dev: /dev/nvme0n1p2
    ID-3: /boot/efi size: 974.1 MiB used: 8.8 MiB (0.9%) fs: vfat
    dev: /dev/nvme0n1p1
    ID-1: swap-1 type: partition size: 5.99 GiB used: 0 KiB (0.0%)
    dev: /dev/dm-2 mapped: debian--vg-swap_1
    System Temperatures: cpu: 31.0 C mobo: N/A
    Fan Speeds (rpm): N/A
    Memory: total: 8 GiB note: est. available: 7.61 GiB used: 4.17 GiB (54.8%)
    Processes: 290 Uptime: 10m Init: systemd
    Packages: 2305 Compilers: gcc: 14.2.0 Shell: Bash v: 5.2.37 inxi: 3.3.38
    Hallo in das Forum :)
    Ich habe derzeit Debian 13, mit KDE Plasma v6.3.6 installiert.
    Da es sich um ein Surface handelt, wäre eine Bildschirmtastatur sehr schön ^^
    -> Onboard gefällt mir ehrlich gesagt nicht, da es auch keine direkte Integrierung in KDE Plasma hat um es "Automatisch" anzuzeigen.
    Maliit funktioniert sehr gut, jedoch bekomme ich es nicht hin, dass das Layout auf Deutsch ist.
    Das Projekt wird soweit ich gesehen habe, auch seit 2022 nicht mehr ge-updatet.
    Deshalb nun die Frage, welche Vorschläge oder Alternativen hätte das Forum für eine Bildschirmtastatur mit Integration zu KDE Plasma (Virtuelle Tastatur).
    Die Locale ist de_AT.UTF-8
    Ich kenne mich zwar mit Debian aus, jedoch nicht in einer KDE/Wayland Umgebung, ein Wechsel wäre zwar möglich - aber möchte ich derzeit nicht.
    Danke und Liebe Grüße
    Krebell
  • Vorausgesetzt, dconf ist installiert, probier doch mal für Maliit Folgendes:
    Bash
    gsettings set org.maliit.keyboard.maliit enabled-languages "['de', 'emoji']"
    gsettings set org.maliit.keyboard.maliit active-languages "['de']"
    maliit-keyboard --restart
    Die KDE-Tastaturbelegung in den Systemeinstellungen (Eingabe - Tastatur - Tastatur) ist hoffentlich auch auf deutsch eingestellt; es kann sein, daß Maliit die dortige Einstellung erst nach den o.g. Aktionen übernimmt.
  • Krebell December 26, 2025 at 7:28 PM
    Bash
    Vielen Dank!
    Es hat tatsächlich mit dem Befehl
    funktioniert.
    Beim 2. Befehl hat er mir nur ausgegeben das es kein derartigen Schlüssel "active-languages" gibt.
