Installation auf USB-Stick überschreibt den bootloader auf der Festplatte
    Linux Mint
    Kernel: 6.14.0-37-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
    base: Ubuntu 24.04 noble
    Type: Desktop System: Acer product: Aspire XC-1780 v: 1.0
    serial: <superuser required>
    Mobo: Acer model: Aspire XC-1780 v: 2.0 serial: <superuser required>
    UEFI: American Megatrends v: R01-B1 date: 10/21/2024
    Info: 10-core (6-mt/4-st) model: 13th Gen Intel Core i5-13400 bits: 64
    type: MST AMCP arch: Raptor Lake rev: 2 cache: L1: 864 KiB L2: 9.5 MiB
    L3: 20 MiB
    Speed (MHz): avg: 811 high: 900 min/max: 800/4600:3300 cores: 1: 800
    2: 800 3: 900 4: 800 5: 833 6: 800 7: 800 8: 801 9: 821 10: 800 11: 800
    12: 800 13: 800 14: 800 15: 831 16: 800 bogomips: 79872
    Device-1: Intel Alder Lake-S GT1 [UHD Graphics 730]
    vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-12.2
    bus-ID: 0000:00:02.0
    resolution: 1920x1080~60Hz
    v: 25.0.7-0ubuntu0.24.04.2 glx-v: 1.4 direct-render: yes renderer: Mesa
    Intel UHD Graphics 730 (ADL-S GT1)
    Device-1: Intel Alder Lake-S HD Audio vendor: Acer Incorporated ALI
    driver: snd_hda_intel v: kernel bus-ID: 0000:00:1f.3
    API: ALSA v: k6.14.0-37-generic status: kernel-api
    Device-1: Intel Alder Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 0000:00:14.3
    IF: wlp0s20f3 state: up mac: <filter>
    vendor: Acer Incorporated ALI RTL8111/8168/8411 driver: r8169 v: kernel
    port: 3000 bus-ID: 0000:01:00.0
    IF: enp1s0 state: down mac: <filter>
    IF-ID-1: virbr0 state: down mac: <filter>
    IP v4: <filter> scope: global
    Bluetooth:
    Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB
    bus-ID: 1-14:7
    Report: hciconfig ID: hci0 rfk-id: 0 state: down bt-service: disabled
    rfk-block: hardware: no software: yes address: <filter>
    RAID:
    Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 bus-ID: 0000:00:0e.0
    Local Storage: total: 591.54 GiB used: 192.2 GiB (32.5%)
    ID-1: /dev/nvme0n1 vendor: Micron model: 2450 MTFDKBA512TFK
    size: 476.94 GiB temp: 32.9 C
    ID-2: /dev/sda vendor: SanDisk model: USB 3.2Gen1 size: 114.6 GiB
    type: USB
    ID-1: / size: 225.48 GiB used: 90.52 GiB (40.1%) fs: ext4
    dev: /dev/nvme0n1p7
    ID-2: /boot/efi size: 244.2 MiB used: 18.9 MiB (7.7%) fs: vfat
    dev: /dev/nvme0n1p5
    ID-1: swap-1 type: partition size: 7.45 GiB used: 2.7 MiB (0.0%)
    dev: /dev/nvme0n1p6
    System Temperatures: cpu: 29.0 C mobo: N/A
    Fan Speeds (rpm): N/A
    Memory: total: 16 GiB note: est. available: 15.32 GiB used: 4.08 GiB (26.6%)
    Processes: 434 Uptime: 6d 17h 34m Init: systemd target: graphical (5)
    Packages: 4234 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
    Ich habe einen PC mit Linux Mint Cinnamon 22.2 und einen USB-Stick mit Linux Bodhi.
    Als Installationsziel für den Bootloader (Grub) habe ich den USB-Stick ausgewählt.
    Wenn der Stick eingesteckt ist und ich von diesen boote, dann habe ich im Grub-Menü die Wahl zwischen dem internen Linux und dem Linux vom Stick (beides läuft).
    Wenn der Stick nicht eingesteckt ist, dann ist der Eintrag von meinem internen System noch im Bootmenü meines UEFI, läßt sich jedoch nicht starten.
    Gruß
    Thomas
  • Du hast vermutlich den Bootloader bei der Installation von Bodhi auf den USB Stick geschrieben. Jetzt versucht dein UEFI die Systeme über den Bootloader auf dem Stick zu starten was ohne Stick nicht geht. Bei einem Dualboot würde ich immer die nicht benötigte Festplatte abklemmen und dann zu installieren. Aber noch ist nichts verloren, ähnliches wurde hier schon behandelt.
    Mal durchlesen und nach Anleitung vorgehen, dann startet Mint wieder.
    LMDE7 - HP Elitebook 840 G4, Intel Core I5vPro, 16 GB Ram, SSD 256 GB
  • Hallo Cm69,
    Ja, den Bootloader von Bodhi.
    Jetzt versucht dein UEFI die Systeme über den Bootloader auf dem Stick zu starten ...
    Warum ?
    Ich habe eine EFI-Partition der Festplatte mit dem Eintrag "ubuntu" (Linux Mint).
    Bei ausgestecktem Stick rufe ich das UEFI-Bootmenü mit [F12] auf und wähle "ubuntu" (d.h. von der unveränderten EFI-Partition meiner Festplatte) auf.
    Es erscheint "grub:> ".
    Bei einem Dualboot ...
    Es ist kein Dualboot, das Bodhi ist auf dem USB-Stick (extern) und hat den eigenen Bootloader nicht in der EFI-Partition.
    Über das Grub-Menü des Sticks habe ich die Möglichkeit beide Systeme auszuwählen und beide Systeme laufen.
    An der EFI-Partition sollte nichts geändert worden sein.
    Beide Systeme laufen sehr gut.
    Der angeheftete Beitrag trifft auf mich nicht zu (die Installationen sind fehlerfrei).
  • Ich weiß nicht wie genau, aber es scheint so das der letzte efi Eintrag auf dem Stick halt den Grub der Mint Version "überschrieben nicht direkt, aber enteigne quasi" hat. Wenn du im Bootmenü den Ubuntu Eintrag an erster Stelle schiebst ?
    MfG Nico
  • Hallo nkn80,
    Dann bekomme ich:
    grub:>
    Ich hatte das Szenario früher schon einmal mit Linux Mint und ZorinOS, leider weiß ich nicht den Grund.
    Repariert hatte ich es indem ich Linux Mint mit Supergrub gestartet hatte und dann mit Timeshift zurückgesetzt hatte (wäre eine Notlösung).
    Ich möchte jedoch auch lernen und deshalb die Ursache wissen.
  • Dann stecke mal den Stick ein und starte Mint. Dann zeigst du mal die Ausgabe von:
    lsblk
    MfG Nico
  • Code
    NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
    sda           8:0    1 114,6G  0 disk
    ├─sda1        8:1    1   247M  0 part
    └─sda2        8:2    1 114,4G  0 part /media/ths/065fb78c-910c-4a34-a704-100ffce34314
    sr0          11:0    1  1024M  0 rom
    nvme0n1     259:0    0 476,9G  0 disk
    ├─nvme0n1p1 259:1    0 239,1G  0 part /media/ths/Allg1
    ├─nvme0n1p5 259:2    0   248M  0 part /boot/efi
    ├─nvme0n1p6 259:3    0   7,5G  0 part [SWAP]
    └─nvme0n1p7 259:4    0 230,1G  0 part /
  • Dann erstelle dir mal einen bootfähigen Mint 22.2 USB-Stick und dann machen wir mal einen Bootrepair
    MfG Nico
